Sealed or Ported - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Sealed or Ported
Discuss Sealed or Ported in the DIY Speakers and Subwoofers forum; Sealed or Ported I've modeled the Soundsplinter RLP-15 in WinISD. The picture shows the response for sealed and ported...as well as the T/S ...
Old 09-14-06, 09:39 PM   #1 (Link)
Alias: mcwhorter
Loc: STL Area
User: #2429
Since: Sep 2006
mcwhorter is offline
Sealed or Ported
The picture shows the response for sealed and ported...as well as the T/S parameters I used. (Do my T/S parameters look correct?)
Question... Why would I want to used a sealed box when the ported one goes MUCH lower? I know the box is bigger, but its for my Home Theater, so size isn't important. I have a BFD for EQing. A ported box seams like a no brainer...
Am I missing something?
Old 09-14-06, 10:17 PM   #2 (Link)
Shack City Slicker
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
Re: Sealed or Ported
Well, you're not missing anything really... what you're noticing is the advantage of a vented allignment over a sealed allignment. Sealed boxes have only 1 source of spl, being the driver. Vented speakers have two sources, 1 being the port, the other being the driver.
In some smaller rooms, it makes more sense to go with a sealed subwoofer because they generally(w/o highpass) exhibit a 2nd-order roll-off after Fb (tuning frequency or enclosure resonance). Vented systems have a 4th order roll-off after Fb and an increasing danger of exceeding xmax after the tuning frequency. Smaller rooms will help the sealed subwoofer in the lower frequencies with its own contribution to spl called room gain. Also, since the roll-off is more gradual with the sealed subwoofer it may mesh better with the room gain. Vented boxes roll-off twice as fast below the tuning frequency.
You'll need some sort of highpass protection to prevent the driver from over excursion with the vented speaker. If the sealed speaker is designed to be amp-limited (to simplify this), the air-spring inside of the sealed box will help prevent ever exceeding excursion.
In order to get the same or similar results from a sealed system one has to spend a lot more than a vented system. You'll simply need more power, more drivers, and a form of LinkwitzTransform (special eq to bring up the lower frequencies in a sealed system) to reach a ported system in outout with the same driver.
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
Old 09-14-06, 10:46 PM   #3 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
You can get much better results with a ported sub than that. Exocer is right about the rolloffs meshing with room gain, but if you use a large enough enclosure with a low enough tune, you can create a FR that will have a shallow rolloff below ~30hz pushing the 4th order rolloff down into the low teens, and the shallow rolloff will mesh extremely well with typical room gain, better than a traditional sealed or ported, giving you solid extension down to the low teens.
Old 09-15-06, 10:37 PM   #4 (Link)
Alias: mrogowski
Loc: Winnipeg
User: #2503
Since: Sep 2006
mrogowski is offline
Go ported. You always have the option to seal it if you don't like the results.
Best,
Mark
Old 09-16-06, 12:44 PM   #5 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
I built both, a 4cf sealed and an 8.5cf ported for my RL-P15 and there was no comparison. The the ported blew it away so much that Im never going to look back.
Old 09-16-06, 07:05 PM   #6 (Link)
Alias: mcwhorter
Loc: STL Area
User: #2429
Since: Sep 2006
So ported it is...
How does this look? A 13.5cuft bot tuned to 22Hz. -3db @ 19.5HZ
Could someone check my TS parameters to see if they look right for a dual 4 ohm RLP15
Old 09-17-06, 10:05 AM   #7 (Link)
Alias: brandon
Loc: Murfreesboro, Tn
brandonnash's Avatar
User: #2533
Since: Sep 2006
brandonnash is offline
how about larger enclosure still ported with a lower tune. say somewhere between 11 and 15 hz so the roll off is nice and slow and that should take up for room gain.
Old 09-17-06, 10:37 AM   #8 (Link)
Alias: Steve
User: #263
RLp15 D2 in 260 effective liters with a 6" port that is 30" long using a 3/4" roundover being fed by 600-900 watts. Proven performer
Old 09-17-06, 11:24 AM   #9 (Link)
Alias: mcwhorter
Loc: STL Area
User: #2429
Since: Sep 2006
brandonnash wrote: View Post
13.5 cuft is about as big as I can go in the the room. I figure 20HZ was low enough. I certainly can't hear anything that low, although I can certainly feel it. The problem is port size. For a 22Hz tune, a single 4" port is only 2.15" long. That doesn't seem right to me. Two 4" ports need to be 7.23" long. A single 6" port need to be 7.04" long. Do these numbers seem right?
SteveCallas wrote: View Post
I'm stuck with a Dual 4 ohm sub due to my Amp. I would need 2 of the Dual 2's, which I dont want.
Do my T/S parameters look correct on post #1?
Old 09-17-06, 11:29 AM   #10 (Link)
Alias: Steve
User: #263
What amp for sub use are you using that can't handle a 4 ohm load?
Old 09-17-06, 11:32 AM   #11 (Link)
Alias: mcwhorter
Loc: STL Area
User: #2429
Since: Sep 2006
I'm using a Carver TFM-35. It's rated at 350Wx2 at 4ohms. OR 700@ Bridged at 8ohms. So I need a single 8ohm load or a Dual 4ohm load.
I may end up selling the Carver and getting an EP2500. But I'm not leaning that way yet.
Old 09-17-06, 09:11 PM   #12 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
This design is a winner. Mine is very close to this(8.5cf and even less watts 450w So 700w @ 8ohm should be good) and I could not be happier. I realy would not use a 4" port though.
Old 09-18-06, 09:17 AM   #13 (Link)
Alias: Mr. Lamb Fries
Loc: Pittsburgh
Mr. Lamb Fries's Avatar
User: #2639
Since: Sep 2006
Mr. Lamb Fries is offline
I plugged that into WinISD and the reading looked awful. it showed -10db at about 23 hz...Is this right? I am sure I am reading something wrong or not using the program correctly, but every time I plug a driver into that thing (WinISD)...it looks like I will just be wasting my time. I was trying to attach a picture of the graph but I am not sure how to capture a screen shot.
Old 09-18-06, 11:35 AM   #14 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
Yes you are doing somithing wrong. With 260l and a 30" long port I get -5 at 23hz
Old 09-18-06, 12:01 PM   #15 (Link)
Loc: Pittsburgh
User: #2639
Since: Sep 2006
Jerm357 wrote: View Post
I cant get the screen shot loaded here. What Tuning Freq are you set at. Mine auto adjusted to approx 14hz. I am sure I am doing something wrong...every driver I have tried looks like it would be a waste of time. Ill check the tutorial again on WinIsd
Searching for DIY Sub...Driver, Amp, and Box Design!
Old 09-18-06, 05:31 PM   #16 (Link)
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
WillyD is offline
Mr. Lamb Fries wrote: View Post
Try the 15" TC-2000 SVC.
http://www.tcsounds.com/tc2000.htm
Make sure you're using the Pro version of WinISD. Try 320liters, with a 15Hz tune, and 900W.
That shouldn't look like a waste of time.
Old 09-18-06, 05:43 PM   #17 (Link)
Alias: mcwhorter
Loc: STL Area
User: #2429
Since: Sep 2006
Here is what I get with a 260L box tuned with a 6" port 20in long (15.38Hz). If you compare that to the box I'm thinking about (13.5cuft, 22Hz tune), I think the 13.5cuft box has a nicer looking curve atleast down to 17HZ.
Could someone check my T/S parameters...PLEASE?
Old 09-18-06, 06:32 PM   #18 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
Thats not what Im getting. Are you using the D2? 260l with a tune of 15 using the d2 I get -6 at 15.68hz. I have never modeled the D4 so It might be right for that driver.
Old 09-18-06, 06:37 PM   #19 (Link)
Alias: Steve
User: #263
The response of the D2 in 260 liters with a 6" port that is 30" long is quite good. The high Le and medium Bl are what would be causing the -3db point to be reached early on in simulations, but in real life, the output is pretty **** flat. I think the published Le is a bit high.
mchorter, the design I mentioned is for a D2, you'll want to go bigger with a D4.....though I would personally stick to the D2.
Old 09-19-06, 08:40 PM   #20 (Link)
Shack City Slicker
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
I'd definitely ignore that highish -3db point...In-room it'll probably be WAY lower than the simulations suggest with room gain and all.
Old 04-13-08, 06:43 AM   #21 (Link)
Alias: Synthsayer
Loc: Lexington, KY
User: #14503
Since: Dec 2007
Synthsayer is offline
I would suggest an Infinity 1230W Reference Series in a 3.7 cubic ft. box with 4" by 11.7" port. This plots with F3 of 25Hz. Heavily brace cabinet and reduce panel vibration. I used self-adhesive vibration damping sheet cut to size and concrete half blocks from Lowe's. Weight=85lbs. and on spikes. Also seal woofer into box with Mortite caulking putty. Do not use silicone as it can damage glues used for making your speaker.
Use an OAudio 500W BASH Plate amp with 24db X-Over, Parametric EQ, Gain Control, and Low fr EQ.
This worked very well. Lows that will make you sick. Seriously.
Good luck and enjoy:-)
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
