| DIY Subwoofers - Sealed and Ported Best value LLTDiscuss Best value LLT in the DIY Speakers and Subwoofers forum; Best value LLT DS-21 wrote:
You and Andrew seem to spout this "perceptual research" line in every post, so how about this: would ... |
| | #26 (Link) | ||||
| Re: Best value LLT Quote:
As previously mentioned there is a burden of proof found in science without which one cannot justifiably make any assumptions. Your anecdotes are a perfect example of such a case where, in your experience, high inductance drivers typically perform at a relatively lower level when compared to low inductance drivers. As I have said previously it is your prerogative to hold this belief, but as of now there is no evidence of it in any credible publication, of which I am aware, that would make this a sound generalization. Due to this I stand by my suggestion that you make this known when urging others to seek out low inductance drivers. With regards to a specific article analyzing the benefits of certain inductance levels there is nothing that I am aware of which proceeds in this endeavor. This is due, in part to reasons as mentioned by Chris, but also for another reason. There have been studies that do compare listener preference to overall loudspeaker performance as it relates to measurement in controlled circumstances. Within these studies various characteristics of drivers can be deduced none of which are related to inductance for reasons stated above. Hope this is civilized enough for you Jim. Also, do let me know what your thoughts are in regards to my previous suggestion of two smaller, higher tuned, units that would likely result in a overall superior response. -Andrew | ||||
| | #27 (Link) | ||||
-Chris | ||||
| | #28 (Link) | ||||
And at the typical 80Hz HT xover, it is not compensated for. One would have to drop the xover point quite low for it to have zero impact. | ||||
| | #29 (Link) | ||||
Looks like a passionate debate, but still friendly. I just didn't want it to escalate into anything personal.As far as the 2 driver solution recommended...as far as I can tell, it looked great (and like it would go beyond meeting my needs/expectations). I want to spend some time tonight modeling all of the different options and overlaying their response (if I can figure out how to do that). To be honest, when I look at any of the options mentioned, they all look to me (from the model, at least) like they will blow me away. But, I think I can more easily understand the differences by overlaying the plots. One thing that I have to keep in mind is that I will not be able to use a particularly low x-over. I have some NHT L5's that I'm auditioning for the mains and center. I haven't decided yet if I'm keeping them, but even if I don't I'll likely use bookshelf speakers up front. So, either way, I'm probably going to want to x-over at 80Hz (and, possibly even higher). | ||||
| | #30 (Link) | |||
| Re: Best value LLT I'm trying to model the options listed in this thread, and can't come up with a reasonable port configuration for the IXL-18's...as I understand it, I want the port velocity < 17. I can't seem to get it below 22 or 23...and that's with 2 6" diameter 50" ports. Anyone else made it work with the 12.5cuft, 15Hz configuration? If so, would you be willing to attach your driver file, in case that's the issue? | |||
| | #31 (Link) | |||
| Re: Best value LLT you have to limit your port to 36", the program should tell you this but it doesnt......i think the box is too small....see what it comes up with when you open that driver..... | |||
| | #32 (Link) | ||||
I also modeled it as a member on another forum suggested...slightly larger box (14.2cuft) and lower (11.5Hz)...results in a 36" port that's 6" in diameter. For that configuration, a velocity of 17 is reached at about 15.5Hz, and the port velocity increases STEEPLY as the frequency goes down. So...over what frequency range should I target port velocities < 17? Is it important throughout the frequency range, or only above some value (like 15Hz)? My apologies for the questions that everyone else probably already knows the answer to... | ||||
| | #34 (Link) | |||
| Re: Best value LLT Im just figuring out stuff myself so im just sharing what i learned. My port velocity is 23 at 20 hz on the one i built. Thats probrably why i can hear it chuffing......but i have to put my head right next to it to hear it. I havent yet heard or found info on port velocity so im awaiting someones reply as well. | |||
| | #35 (Link) | |||
| Re: Best value LLT Thanks, Mike. That's what the difference is...I was using the full 800W rating for the signal. I guess in reality I shouldn't dwell on what the absolute worst case is...at 360W you're still in excess of 110dB (without room gain). And, I don't think I'd ever go that loud. | |||
| | #36 (Link) | |||
| Re: Best value LLT Jim, I have dual RL-P18 LLTs in my 1800 cu ft room. Don't be afraid to have a lot of headroom...It is alway a good thing, you might need it anytime. Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #37 (Link) | ||||
| Re: Best value LLT You can easily calculate the attenuation at any given frequency with a simple mathematical model considering the impedance value at frequency vs. inductance value. Quote:
-Chris | ||||
| Thread Tools | |
Similar Threads | ||||
| LLT Explained | SteveCallas | DIY Subwoofers - Sealed and Ported | 145 | 05-30-08 12:33 AM |
| Another 18" LLT | mlstrass | SoundSplinter | 9 | 04-27-08 12:07 PM |
| TC 2K LLT | NateTTU | DIY Subwoofers - Sealed and Ported | 16 | 12-26-07 11:39 PM |
| IB and LLT in one | g75 | DIY Subwoofers | 10 | 08-30-07 04:17 PM |
| Which is ultimately better, IB or LLT? | bonehead848 | DIY Subwoofers | 3 | 06-16-07 11:42 PM |
