imputs for win isd - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
imputs for win isd
Discuss imputs for win isd in the DIY Speakers and Subwoofers forum; imputs for win isd I cannt find nor no one will answer the question of the signal tab. Whats the power and whats the ...
Old 04-17-08, 02:31 PM   #1 (Link)
Alias: Jodean
Loc: Tea SD
User: #15615
Since: Jan 2008
Jodean is offline
imputs for win isd
Whats the power and whats the series resistance? How does DVC apply to this? how does this apply when using two channels of an amp or reciever? And all that to DVC?
Win ISD loads at no power and .1 ohm at startup
Old 04-17-08, 02:57 PM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: imputs for win isd
Series resistance is for other "non-driver" resistances, i.e. cabling, connectors, amplifier output resistance, possible crossover coil resistances etc. 0.1 ohm is quite reasonable estimate for those. However, in some cases (crossover coils) it might be on the low side.
Power is for how much power is being applied to you model. Left click once in the box and use the up arrow key to increase the amount of power applied. Or highlight the "1.0" and type in any amount you want. Use this along with the cone excursion graph to see when maximun excursion is reached. Then switch to the SPL graph to see the result.
We're all in this together!
Old 04-17-08, 05:31 PM   #3 (Link)
Alias: Jodean
Loc: Tea SD
User: #15615
Since: Jan 2008
Jodean is offline
ok thats what i figured....but do i put 80w for each voice coil and imput the 160w then?
Old 04-17-08, 06:00 PM   #4 (Link)
Alias: Collo
Loc: Newcastle, Australia
User: #5027
Since: Dec 2006
collo is offline
The power is the total power for the subwoofer. In your case, you enter 160w.
The DVC side of things is defined when you enter the driver parameters into the database.
Old 04-17-08, 06:03 PM   #5 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
When you enter the parameters for a DVC sub you enter "2" voice coils. Then input however much power the sub can handle, or as much power to cause maximum excursion to be reached.
Old 04-17-08, 06:06 PM   #6 (Link)
Alias: Jodean
Loc: Tea SD
User: #15615
Since: Jan 2008
Jodean is offline
Mike P. wrote: View Post
See now SteveCallas was telling me to imput 1 for voice coils?
Where do i put the max power rating at?
Oh, it also says under 2 coils.....series or parallel....im using two channels of one amp, one on each coil, so i imput parallel?
Old 04-17-08, 06:14 PM   #7 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
According to WinISD, you input 1 coil for a SVC and 2 coils for a DVC.
In the Signal tab. See post #2.
Old 04-17-08, 06:21 PM   #8 (Link)
Alias: Jodean
Loc: Tea SD
User: #15615
Since: Jan 2008
Jodean is offline
I thought that was for the power im applying to the sub??
Old 04-17-08, 07:32 PM   #9 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
It is. I thought that's what you meant by "Where do i put the max power rating at". If you meant where to enter it into the parameters, then it goes in the Pe: box. Are we on the same page now?
Yes, 2 coils, parallel. That would be an 8 ohm load. Input 160 watts in the signal tab.
Old 04-25-08, 12:21 AM   #10 (Link)
Alias: Dan
aktiondan's Avatar
User: #6736
aktiondan is offline
Sorry I don't have anything to add directly relating to this post, other than the title caught my eye with the misspelling of the word "imput". I knew an audiophile guy years ago, he was into music and speakers and vinyl just a bit more than the average person, and this one day he comes into work showing off this tube amp he had just spent several thousand dollars being refurbished. All the caps replaced, new tubes, and a new shiny polished case. He was so proud of this thing. It put out some 10W class A, I can't remember, but as I'm looking at this thing, I notice underneath each gold plate RCA jack is a word that has been nicely etched below it that says IMPUT. I asked him, hey what's this imput deal all about? He's like, that's where the input is. I said yes I understand that's where the inputs go, but what is an iMput?? He looked at me with a blank face. I finally just had to tell him, dude, you spelled input wrong. He about died, he was so mad at himself. All this work, all this time, and money, his super-sweet tube amp, labeled IMPUT for life. Anyway, I haven't thought about that in ages, but seeing the title for this post just made me think of it. Thought some of you guys might be able to appreciate the story.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
What to look for in Win ISD graphs? darrenh DIY Subwoofers - Sealed and Ported 16 03-17-08 06:53 AM
Fusion NV-15 sub for HT? Win-ISD struggles cynical2 DIY Subwoofers 17 03-10-08 07:50 PM
What is it going to take to win the format war? HDBeat Home Theater, Audio and Video News 0 09-08-06 03:20 PM
Win Big! Win SVS! Sonnie SVSound 0 06-12-06 12:58 AM
Win Big! Win SVS! Sonnie Home Audio Speakers 0 06-12-06 12:57 AM
Mach 5 Audio
