Newbie looking for advice on DIY sub (~$600) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss Newbie looking for advice on DIY sub (~$600) in the DIY Speakers and Subwoofers forum; Newbie looking for advice on DIY sub (~$600) Hi everyone. I've recently started doing a bit of research on DIY subwoofers and think I might be interested in ...
Old 04-19-08, 04:25 PM   #1 (Link)
New Member
Alias: Melvin
User: #19795
Since: Apr 2008
Melvin is offline
Hi everyone.
I've recently started doing a bit of research on DIY subwoofers and think I might be interested in building one. I've been reading quite a bit here the last few days, but I'm very new to this, so there's a lot I don't know or understand yet.
I'm looking to spend around $600 total (willing to go up a bit if I need to). It will be mostly for HT use (some music too, though). I'd like to get as much low end extension as possible with a reasonable size cabinet. Something around 200 L would be ideal. I'm assuming a vented cabinet would be the best choice for me? The room it would be in is about 14' x 20' x 8'.
Any suggestions on what driver(s) and amp would fit my requirements? I've looked at the Mach5Audio IXL-18.4 in WinISD and it looks like I can get a pretty good looking frequency response in a 200 L cabinet tuned to 17 Hz. But, like I say, I'm very inexperienced with this, so maybe I don't know what I'm looking at. I've also looked at the Tempest X 15 in WinISD, but it seemed like I needed a much larger volume to get a similar frequency response to the IXL 18.4. For the amp, would something like the O Audio 500W BASH amp be a good option or something from parts express? Or should I be looking at something else?
I could probably ask a bunch more questions but I'll leave it at this for now. Any help would be appreciated very much. Thanks.
Old 04-19-08, 06:01 PM   #2 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
Re: Newbie looking for advice on DIY sub (~$600)
Melvin wrote: View Post
Hi Melvin. Before you do anything else, go read this page. Since every alignment has pros and cons, you need to know what they are - decide on an alignment and then find a sub that has parameters suited for it. Since I am a firm believer in multiple subs, I would urge you to build more than one and at least two. The Oaudio is a good amp. If you are inclined to go sealed, two of those amps with six of the onsale 10" NHT Sub2's [3 10" drivers per 4.5cf box] would be in budget and have more output than two 18's.
Warmon - "know what I mean Vern"
Old 04-20-08, 02:07 AM   #3 (Link)
New Member
Alias: Melvin
User: #19795
Since: Apr 2008
Melvin is offline
Hi Warmon, thanks for the reply.
From reading that page, I think a vented design is best suited to what I want. I'd like the sub to play as low as possible (I'd like good response down to at least 20 Hz or lower if possible). I don't need super high levels of output. The cabinet can be relatively large (at least compared to retail subs), 200 liters would be ok, or a little bigger if need be.
What would be some good drivers to consider. Are the few I've mentioned (Mach5Audio IXL-18.4, Tempest X 15) good options for the type of sub I want or are there other drivers better suited for this type of subwoofer?
Unfortunately, due to room layout, I'll probably have to stick with just one subwoofer.
Old 04-20-08, 10:34 AM   #4 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
Okay, you will have to do some homework then. Best results are going to be with subs that have higher EBP [50-100], Qts < .40 and lower to moderate Vas to keep box size reasonable. EBP is calculated as Fs/Qes - the higher number the better. I would develop a short list based on Qts first and go from there. Assuming you are going to go with the Oaudio amp, you would want 2 - 12" drivers in a single box with 4ohm DVC's and if you go with a single 15 or 18; you would want a 4ohm SVC or a 2ohm DVC.
I think a good match for what you are wanting to do might be a single CSS SDX15.
Old 04-20-08, 11:11 AM   #5 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Another option to consider would be the Mach5Audio IXL-15. For HT applications it works in a 170 liter cabinet tuned to 17 hz. It's on sale for $210 shipping included.
We're all in this together!
Old 04-20-08, 09:21 PM   #6 (Link)
Alias: HJ
Loc: Algonquin, IL
User: #18151
Since: Mar 2008
hjmiller is offline
If you are willing to go with 200l cabinet and want dual 12" drivers. One suggested to me and which I bought (just starting my design) is this the 13OV2 D4 at elemental design on sale still for $70 (their website seems to indicate they still have stock as they are a clearance item). Two of those will be less than a single Shiva-X or Tempest
Old 04-23-08, 07:35 PM   #7 (Link)
Alias: anthony
User: #16309
Since: Feb 2008
mayhem13 is offline
hjmiller wrote: View Post
I like the price on those too but the high Le makes it impossible to tune them flat. WAAY loud from 60hz on up IMO. I like the SDX15 with the Oaudio amp idea. Keeps within budget and should have no problem sub 20Hz.
Old 06-24-08, 04:07 PM   #8 (Link)
Alias: Zuki
Loc: Lawrenceville, Ga
User: #22340
Since: Jun 2008
AudioZuki is offline
Question is would they sound noticibly better then
HSU $600 sub
SVS $600 sub
I am looking for sound quality. Same price range. I want to see the mallet hit the base drum in the music. Rumble is secondary but really important as well.
I am quite interested in this thread.
Old 06-24-08, 09:29 PM   #9 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
What sub do you have now? I ask because it may help us give better advice. I don't think you can realistically tune an 18" driver below 20hz in 200L, with a port, without getting into some serious design issues. PR's maybe but that adds a lot to your total cost. Sealed 18" has a much better shot in 200L.
For $600 you may want to look at the Rhythmik servo 15" kit, or maybe even the dual 12" version. They aren't known for wallcracking out-put, but they go DEEP and are said to have great SQ. Illka tested the 12" version in a tiny little sealed box and it did quite well. The 15" should be easily more powerful.
Old 06-25-08, 05:41 PM   #10 (Link)
Alias: Mike
Loc: Chattanooga, TN
User: #5740
Since: Jan 2007
mgboy is online now
Why not a LT'ed TempestX or SDX with an EP2500 to back it up? Would be under/around budget, and should still rock the house. I'm kind of on a LT "run" right now - but it seems like a good choice all around, if you like things small. *shrug*
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
Newbie Needs Advice on Basement HT radunne Home Theater System Recommendations 11 07-16-08 01:17 PM
Newbie need advice/suggestion for 1st HT orchitis01 Home Audio Speakers 4 04-13-08 07:28 AM
Newbie - looking for some HT room advice scyce Home Theater Design and Construction 10 03-27-08 12:32 PM
Newbie needing projector advice... cmoneyt8ker Home Theater Projectors 6 12-18-07 04:40 PM
Newbie question for SPL advice & 1124ps oris98 BFD Forum 4 01-24-07 02:30 AM
Mach 5 Audio
