| DIY Subwoofers - Sealed and Ported My Port QuestionDiscuss My Port Question in the DIY Speakers and Subwoofers forum; My Port Question I have a Q logic enclosure for a car that I am planing on modifying and turing around to sell.
| | #1 (Link) | |||
| My Port Question I have a Q logic enclosure for a car that I am planing on modifying and turing around to sell. It is 1.25 cuft with a single port. The port is 4" internal diameter, and 11" long What frequency is this tuned to? The port is made of a cardboard tube...I plan to change that to a PVC pipe...I want to tune this enclosure as low as possible...so should I use an elbow and another tube to extend it or drill another hole in the top and add a second port? Just so you know its a hatcback box (picture a triangle shape thats flat across the top) its about 16" high x 17" wide x 9" top depth x 15" bottom depth | |||
| | #4 (Link) | |||
| | Re: My Port Question As long as the bends are smooth there won't be a problem. See post #9 in this build thread for an example. http://www.hometheatershack.com/foru...-im-again.html We're all in this together! | |||
| Thread Tools | |
Similar Threads | ||||
| Port Material? | bumpnzx3 | DIY Subwoofers - Sealed and Ported | 4 | 03-18-08 04:50 PM |
| subwoofer port help | ringbearer3791 | DIY Subwoofers - Sealed and Ported | 3 | 02-21-08 11:29 AM |
| Slot port? | mgboy | DIY Subwoofers | 6 | 12-31-07 06:56 PM |
| Port location? | aceinc | DIY Speakers | 3 | 05-10-07 05:01 PM |
| Port Resonance | Zene | DIY Subwoofers - Sealed and Ported | 16 | 02-01-07 09:38 PM |
