| DIY Subwoofers - Sealed and Ported JL Audio 13w7 in prowedge boxDiscuss JL Audio 13w7 in prowedge box in the DIY Speakers and Subwoofers forum; JL Audio 13w7 in prowedge box Has anyone tried JL Audio 13W7 in the prowedge JL Audio (sealed) box for HT application?
I have 12W7 ProWedge ... |
| | #1 (Link) | |||
| JL Audio 13w7 in prowedge box Has anyone tried JL Audio 13W7 in the prowedge JL Audio (sealed) box for HT application? I have 12W7 ProWedge in the car for some years and have been always impressed with the way it sounds. I can get a good deal on 13w7 in the pro wedge box and thought about using it at home. I wonder how different would it be from their fathom line assuming I get a comparable amp and room equalization (not sure if I can rely on Audyssey). | |||
| | #2 (Link) | |||
| Re: JL Audio 13w7 in prowedge box Forget the sealed box. That is an utter waste of the driver's capabilities. If you use this driver in a 4.5 ft^3 enclosure with a folded slot vent that is 4.25" x 12" and 51" in length, you will have incredible output level, with minimal port compression. You can also use two high excursion 15" PRs if the added cost is not issue. In an average size room, you would yield well over 120dB in the 20-25 Hz range. It would yield a -3db at 20Hz and -6db at 17Hz. 1st port resonance would be at about 107Hz; no issue if you cross at 80Hz or below using a 4th order crossover. Note: with this driver and it's unusual output abilities - you should design the cabinet to be 2-3x more densely braced as compared to the average subwoofer. I recommend cabinet grade hardwood ply as opposed to MDF for construction; the ply is considerably stiffer/stronger. You can not reduce the port cross section area I have suggested above; if you do, it will result in appreciable port compression(loss of SPL around the port tuning frequency). An amplifier delivering a minimum of 1000 watts at the driver's nominal load impedance should be used. -Chris | |||
| | #3 (Link) | |||
| Re: JL Audio 13w7 in prowedge box Chris, thanks a lot for the design ideas. I was thinking more of using this sub in original ProWedge box. I don't have any cabinet design skills but I do know some people that could help. Though I know that once I build a first sub I'll be doing this for the rest of my life (it would be my new hobby). So I'm trying to stay away from the cabinet design piece. Also the real estate could be an issue with 4.5^3 ft. I'm not looking for 120dB at 20-25Hz. In fact I'm not looking for high SPL at all. I like the quality that W7 offer. I haven't heard this sort of quality in HT setups. Being a 2 channel guy (I have dedicated room for music) I haven't heard many full range speakers/subs that would offer similar low end quality. I wouldn't buy another Parasound JC-1 just to drive this sub but I would be interested to know what would be a good amplifier candidate to pair with this sub. Another concern that I've got is wether dynamating the insight of the box would help with shielding problems. I have CRT RPTV monitor that I don't want to be affected by this humonguos magnet. One would be to place the sub in the opposite side of the room behind the couch. Thanks in advance. | |||
| | #4 (Link) | |||
| Re: JL Audio 13w7 in prowedge box I disagree that a sealed design is an "utter waste of the driver's capabilities". The Fathom uses a tweaked 13W7 (13HT7?) in a sealed enclosure and tests as one of the best commercial subwoofers out there. It totally depends on a person's goals. | |||
| | #5 (Link) | |||
| Re: JL Audio 13w7 in prowedge box Woah, that would be a 4.5 ft^3 enclosure with a 1.5+ cubic foot port (not counting the port walls!). Another way to put it is the port volume would increase the total volume of the cabinet by 33%. Also, even crossed at 80Hz the ~100Hz first port resonance can be excited. Much like blowing air over a bottle excites the first port resonance regardless of the frequency you blow over the bottle. | |||
| | #6 (Link) | ||||
| Re: JL Audio 13w7 in prowedge box Quote:
As a side note, I do find it interesting that some are so worried about a port resonance that is substantially attenuated on a subwoofer such as in the use I suggested above, when it is so common to build ported midbass hi-fi speakers that place the port resonance, with no attenuation of signal, right into the passband. -Chris | ||||
| | #7 (Link) | |||
| Re: JL Audio 13w7 in prowedge box Perhaps the real question here is should one limit them self to using such a high quality, low distortion, driver in a sealed enclosure. If one's goal is to build a high quality, small subwoofer then the JL 13W7 is a good option, but far superior results as compared to a sealed enclosure could be had using a properly designed vented enclosure. WinISD modeling: ![]() Green: 4.5 cubic foot enclosure with a 4.25x12x63" port Yellow: Ideal, sealed, 4 cubic foot enclosure Blue: More typical, sealed, 1.5 cubic foot enclosure There is a significant amount of output loss by using even the larger sealed enclosure with an F3 of 34Hz as compared to one at 20Hz in the ported enclosure (F3 in the smaller enclosure is about 38Hz). One could perhaps make the argument for parametric equalization of the lower octaves with the sealed enclosure to achieve a lower reaching linear response, but this would result in increased distortion along with loss of overall output. It is also important to note that while the Fathom series subwoofers are low distortion for a sealed subwoofer it is extremely likely that this distortion would be far lessened by using a properly designed ported enclosure. As far as the sealed sounds better than a ported subwoofer that is simple lack of knowledge. With proper use of a quality equalizer one can tailor virtually any response with a sufficiently linear subwoofer such as the ported example above. The only reason I could see someone building a sealed enclosure with such a superb driver is if they must utilize minimal floor space otherwise the drivers true capabilities are not being used. -Andrew | |||
| | #8 (Link) | ||||
-Chris | ||||
| | #9 (Link) | |||
| Re: JL Audio 13w7 in prowedge box Well I'm going to agree with Geoff here. The 13W7 is a great driver for sealed or ported apps. Sealed is hardly a waste of the drivers capabilities. I for one would not build the 4.5ft slot ported enclosure mentioned. In that size enclosure, just PR it. The slot port mentioned will tune to approx. 23hz which is quite high for HT with a driver of this caliber. Also the port resonance at 107hz could be a problem that I'm not confident will be addressed totally by the bends in the port, and definitely not by an 80hz low-pass. What if a 100hz LP is needed to match better with smallish main speakers? If you can go with a bigger enclosure 7.5ft tuned to 17hz looks way better. You can either use a heavily flared 6" port, or use a 3.25" x 12" x 42.75" slot for a bit more port area. The port air speed isn't too bad until over 1000watts. | |||
| | #10 (Link) | |||
| Re: JL Audio 13w7 in prowedge box Since size matters to the OP, Passives would be the way to go on this baby. Dual opposing 15's at 4.6 hz 1050 grams each would come very close to ported output without the threat of compression, reduced box size for about $100 for the PR's from acoustic elegance. If SQ is what he's looking for-give it to him. | |||
| | #11 (Link) | ||||
![]() Warmon - "know what I mean Vern" | ||||
| | #12 (Link) | ||||
We're all in this together! | ||||
| | #13 (Link) | |||
| Re: JL Audio 13w7 in prowedge box Actually EBP is slightly less, but my point is that the JL 13W7 is not optimized for ported. With Qts > 0.40, the driver is a better sealed sub than it will be a ported one. With so many good drivers available for less or similar money, it shouldn't be on anybody's short list for a ported design. For that kind of money, it would make more sense to locate a driver that has parameters better optimized for ported. Warmon - "know what I mean Vern" | |||
| | #15 (Link) | |||
| Re: JL Audio 13w7 in prowedge box There's a reason JL put the 13w7 in a sealed enclosure and the results of the marriage put the combination in the top all time performers and they call it the Fathom An adequate amp would be a Crown XTi 4000 or a Behringer 2500. The 13w7 in a sealed enclosure will have to be EQed of course just like the JL Fathom sub is. Size of the sealed box can be adjusted to your liking. Last edited by ISLAND1000; 04-10-08 at 09:14 PM. | |||
| | #17 (Link) | |||
| Re: JL Audio 13w7 in prowedge box You stated: "I disagree that a sealed design is an "utter waste of the driver's capabilities". The Fathom uses a tweaked 13W7 (13HT7?) in a sealed enclosure and tests as one of the best commercial subwoofers out there. It totally depends on a person's goals." My statement was in regards to relative performance of the driver in a sealed vs. ported/PR system. Your statement is a factoid of commercial subwoofer system performance standing. But how is the Fathom being one of the best commercially produced subwoofer systems mean that a sealed design is not a waste of the driver's potential performance? It is clear that the output SPL capability in the range of about 18Hz-35Hz can be, on average, doubled, with the proper ported/PR cabinet, as compared to a sealed design. This also means lowered distortion, as the driver will be working less, and with less movement and power compression, in this range. You essentially cut the LF performance in half by using a sealed design in this particular example. -Chris | |||
| | #18 (Link) | ||||
-Chris | ||||
| | #19 (Link) | ||||||
-Chris | ||||||
| | #20 (Link) | |||
| Re: JL Audio 13w7 in prowedge box Ok for the sake of the argument i modeled the JL in 120L with 2 PR's 4.6hz 15" 1050 grams and the output is stunning at 2500 watts. 120db at 20hz and at 63hz 130db!!! and still not at xmax for the driver or PRs above 18hz. All in a two foot cube. Given the SQ of a properly designed PR, this should lend to the discussion of sealed vs PORTED. | |||
| | #21 (Link) | ||||
-Chris | ||||
