Push-pull sealed subwoofer - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss Push-pull sealed subwoofer in the DIY Speakers and Subwoofers forum; Push-pull sealed subwoofer Design: Sealed push-pull (non-isobarik) using a 90 litre box with a pair of Eminence Lab 12. Design reminiscent of M&K. ...
Old 04-26-08, 05:43 AM   #1 (Link)
Alias: Roland Gama
Loc: Daman- India
User: #19781
Since: Apr 2008
Roland Gama is offline
Design reminiscent of M&K. Bass Box Pro simulated F3 to be around 45Hz with 107 dB at 20hz full power.
How would this design work with actively equalizing the sub to flatter response.
Any suggestions???
Old 04-26-08, 06:27 PM   #2 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
Re: Push-pull sealed subwoofer
Is there a particular reason that you want to use a pair of Lab 12s in a sealed box that small? I think that there are better drivers for the money and if you're using the Lab 12s because you already have them, then I think a larger box would be better. The smallest I would go with a pair of Lab 12s would be 105 L (.707 Qtc).
Also, I don't see how you're going to get 107 dB/1m @ 20 Hz out of a pair of Lab 12s in a sealed enclosure. They're excursion limited to about 103 dB/1m.
Old 04-26-08, 09:13 PM   #3 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is online now
I agree with you Goeff.
Roland,
Why do you chose such a configutration? Are you limited with space?
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 04-26-08, 10:31 PM   #4 (Link)
Alias: Roland Gama
Loc: Daman- India
User: #19781
Since: Apr 2008
Yes, I have a pair of Lab 12s.
Bass Box Pro simulation gave me the figures. Infact with typical stuffing in a 90 litre box the QTC is under .7
Space is not a definite factor but subwoofer choice is a big problem here in India.
JBL Pro are available. Do they have any you would suggest even if I have to go ported?
I constructed a rough prototype of the push pull design I had in mind. It sounds loud but I have not yet done any RTA on it yet. Photo attached.
Thanks for your reply.
Old 04-27-08, 12:01 AM   #5 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
mdrake is offline
I agree with the other dudes. You might want to consider a larger box or put the woofers in an isobaric configuration, which would then require half the enclosure volume.
Matt
Old 04-27-08, 02:48 AM   #6 (Link)
Alias: Sparky
Loc: North Dakota
User: #17212
Since: Feb 2008
sparky77 is online now
In the push pull configuration you could actually go a bit smaller with a 60L enclosure and have pretty flat response depending on your room. I have a garage full of lab12's and have done quite a few experiments, and an isobaric configuration would be a waste fo the available cone area, stick with push pull you put together, and maybe try a few different sizes between 40 and 90L. That is unless you want to go larger and use a long slot port where you can easily dig down to less than 16hz in room response.
Old 04-27-08, 02:50 AM   #7 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
thxgoon is online now
Isobaric would also limit output compared to a push pull setup. I lived with an MK sub for years and I can confidently say that I've never heard it's equal for sound quality. I ultimately gave it up when I started to crave massive sub 20hz output and initially considered a large push pull design, I ended up going LLT. Since you already have the drivers I'd say go push pull if max output is not your primary concern. I'd take that 107db at 20hz with a grain of salt.
Old 04-27-08, 03:30 AM   #8 (Link)
Alias: Roland Gama
Loc: Daman- India
User: #19781
Since: Apr 2008
Thank you all for the supportive replies.
A pair of these would improve things in the 20 hz range by about 6dB.
I will try simulating the push pull design in LLT. The Labs are not a great choice and I may end up with a box too big as compromise.
Old 04-29-08, 10:01 PM   #9 (Link)
Alias: Roland Gama
Loc: Daman- India
User: #19781
Since: Apr 2008
Hello Sparky,
The box could go smaller than 90 litres and more liberal use of polyfill. However, I have noticed that in the simulations there is a slight drop in SPL in direct proportion to the amount of fill.
What does this imply?
In your opinion what size of box did you prefer?
Thank you.
Old 04-29-08, 10:32 PM   #10 (Link)
Alias: Sparky
Loc: North Dakota
User: #17212
Since: Feb 2008
For a sealed enclosure I would go with the 60L stuffed about 1/3 of the way with polyfill, for a ported enclosure it would be 290L so I would probably expect you to stick with the sealed unless you have the room. What do you plan to power this with, you'll need an amp thats either two channeled or stable to 2 ohms.
Old 04-30-08, 01:26 AM   #11 (Link)
Alias: Roland Gama
Loc: Daman- India
User: #19781
Since: Apr 2008
You are spot on Sparky!
Since a pair of Lab12 in parallel will present a 3ohm load an amplifier with 2 ohms load is desired.
And since I am considering building a pair of boxes (total of 4 Lab12's) I am considering an amplifier capable of 1000watts per channel at 2ohms stability.
Harman Pro group do market their stuff here and I would probably find something from the Crown stable.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
Sealed subwoofer project Farmer DIY Subwoofers - Sealed and Ported 11 04-27-08 09:26 AM
SEALED Subwoofer Q? Ricci DIY Subwoofers - Sealed and Ported 9 12-07-07 12:11 PM
Tang Band Dual 8 : Push Push Design Warmon DIY Subwoofers 22 09-05-07 01:50 AM
Any advice on dual sealed subwoofer for HT use? Geoff St. Germain DIY Subwoofers - Sealed and Ported 6 05-31-07 10:39 PM
Sealed Sonotube Subwoofer Josuah DIY Subwoofers - Sealed and Ported 16 01-24-07 12:05 AM
Mach 5 Audio
