| DIY Subwoofers - Sealed and Ported Port Length RecommendationsDiscuss Port Length Recommendations in the DIY Speakers and Subwoofers forum; Port Length Recommendations avaserfi wrote:
.... I have been unable to find any information on this subject.....I will look into building two cabinets ... |
Views: 1914 - Replies: 62
| | #26 | |||||
| Re: Port Length Recommendations Quote:
![]() As part of the testing, I evaluated the effectivenes of inserting damping pads inside the turns as a means of reducing the amplitude of the port resonance. They didn't help... | |||||
| | #27 | ||||||||
Should be a pretty potent performer.Quote:
That said, if this first resonance peak does reach the same amplitude as the output being created from the drivers - "0db" as you put it, displacement at that frequency is doubled and it would correspond to a 6db peak in your frequency response. Quote:
| | #28 | ||||
| Re: Port Length Recommendations umm that would be a "House half empty" view... | ||||
| | #29 | |||||
As far as a combined response, I realize that one was not provided, but rather I noted that the peak representing port resonance reached the average output (perhaps slightly below) of the driver output graphs. This is where the relative port resonance level of 0dB was derived and relates directly to the definitions in the papers I have mentioned. Either way, this is a moot point as the argument is purely based on your feelings of port resonance and its audibility. I suggest you read the previously linked articles which deal in depth with audibility of resonances such that you have a foundation with regard to what resonances and its audibility. Andrew | |||||
| | #30 | |||||
| | #31 | ||||||
The chart shows spl vs frequency - yes, there is a 20db peak, as the amplitude ~100hz is down to ~65db, then shoots up to ~85db at the first resonance. The average of the port output over the entire frequency range of the measurement is not significant or related to anything we are talking about. I don't understand why you are using that as a frame of reference in regards to a first resonance peak. And as I stated, take away driver background noise form the port measurement, and you'll see that the peak is even more extreme. Quote:
| | #32 | |||||
At the same time it seems this discussion is departing from audibility of said port resonances to other semi related subjects further reducing the likelihood that a consensus will be formed. Andrew | |||||
| | #33 | |||||
| | #34 | |||||||
As far as the references to port output and subwoofer output they are incredibly significant to the audibility of resonances. Resonances thresholds have been developed relative to SPL of the original [non-resonant] source. This is why claiming the maxima of 20dB above average as the the actual amount of created resonance is grossly misleading. Also, please remember this discussion is not about whether or not these resonances exist, but rather if they are or are not audible. Quote:
I do not see the point in arguing this subject further at no point in time did I ever recommend use of a long port without a crossover yet this is your chosen exemplar. I concede that if no crossover is used there is the possibility* of audible port resonance in a subwoofer system; just as there is the possibility of audible panel resonance as well. *This is dependent on the natural roll off of the subwoofer system as well as the frequencies involved as audibility of resonance is frequency dependent among other things. Andrew | |||||||
| | #35 | ||||||
Can I bring up several sources to try and back my position? No, and I'd care not to search. If someone wants to try for themself though, it's a pretty simple test. If you hear an odd sound like blowing over a bottle with bass notes in music, you would be wise to shorten the port - 36" or less and you'll be safe. | ||||||
| | #36 | |||||
| | #37 | |||||||
It also seems your recommendation of a 36" or less port recommendation is based on no credible research, but rather a guess at what is safe. I see no reason to heed such a baseless warning. You have made it very clear at an unwillingness to look at the actual credible data with regard to the phenomenon of port resonance thusly, I see no point in continuing in repeating myself. If there are any new issues raised I will be more than willing to reply, but I have no interest in continuing a debate of credible research versus one mans personal opinion. Quote:
Either way, if I have time tonight I will try to do this test with the subwoofer I built. Andrew | |||||||
| | #38 | ||||
| Re: Port Length Recommendations You can link to thousands of pages of research if you like - if the resonance is audible, but the research tells me I shouldn't be hearing it, do I just pretend I'm not hearing it? That's silly. Lighten up. Mike's proposed experiment is absolutely valid. Use a 55" long port (~122hz first port resonance) with a 4th order crossover at 80hz, take some measurements, and do some critical listening. If he notices an odd bump in the measurements and hears a repetitive one note tone during bass notes, it will be obvious that the first port resonance is within the audible (and annoyable) range. My 36" length recommendation is based on actual user experiences. People have built ported subs under my direction with port lengths in the low 40" range and have reported hearing a repetitive resonance with bass in music. It went away when they shortened the port. In designs which I have suggested 36" port lengths, no such resonances were heard. Is 36.00" the precise length not to be exceeded? Probably not, but I'd say it's quite close to the threshold, and it makes some logical sense in that it makes the first resonance more than an octave higher than the crossover point, meaning output from the sub will be at least 24db down. | ||||
| | #39 | ||||
| Re: Port Length Recommendations I just finished taking the measurements using my Kappa VQ build (port length approximately 55" with cross section of 37.5 square inches). Maroon is the subwoofer measured from 1" with no crossover. Blue is the subwoofer measured from 1" with a 4th order Linkwitz-Riley crossover at 80Hz. Purple is the port measured from 1" from the opening with no crossover. Green is the port measured from 1" from the opening with a 4th order Linkwitz-Riley crossover at 80Hz. ![]() Clearly the baseline of reference for these measurements is about 110dB with the crossover activated the port resonance [Q value approximately 37*] located at 111Hz is attenuated approximately 20-22dB. With regard to audibility of this resonance the handful of research papers on this topic have come to remarkably similar conclusions. At a Q of this value and frequency in this span the relative [to baseline frequency] level of audibility is approximately 2-3dB above that of the baseline using the Olive et al paper** or using the Fryer paper (summarized thoroughly in Toole's work) and a linear transform of the resulting data it seems with a music source resonance audibility would need to be 2-3dB above baseline while for it to be audible with pink noise it would likely be a few dB below baseline . Please look to my referenced articles for expanded information on this subject. Clearly the attenuation achieved via the recommended crossover achieves a value far lower than that of defined [by credible research] resonance thresholds. *Formula used: Q = F0 / (delta F) where F0 is center of resonant frequency and delta F is f2 - f1, where f2 is the upper and f1 the lower cutoff frequency (-3dB point in relation to the resonant peak). **It should also be noted that these levels are in reference to pink/white noise it has been shown that resonance is typically less audible with actual music signals. Do note measurements were taken in room with a calibrated ECM8000 microphone situated on a boom mic stand using a Xenyx 802 as a power supply all via a Soundblaster external USB sound card. Pictures of these measurements follow: ![]() ![]() ![]() Andrew | ||||
| | #40 | ||||||
I can see longer ports having an effect on music. But my goals are the use of longer ports in HT subs only. Some experimentation should give us more information on the matter. I'm looking forward to getting started on this. | ||||||
| | #41 | ||||
| Re: Port Length Recommendations Mike, if it's for movies only, it will be much harder to notice, as the resonance won't stand out as much. I didn't catch that earlier. | ||||
| | #42 | ||||||
I only have one interest music if there is any coloration at all to the signal other than something I intentionally introduce via equalization I will be unsatisfied... Andrew | ||||||
| | #43 | ||||
| Re: Port Length Recommendations Thanks for doing the measurements and posting the results. This is a step forward for my original intension's. I have no doubt my own experiments with HT applications will verify your findings. The goal of small box, long port is looking good. ![]() | ||||
| | #44 | ||||
| Re: Port Length Recommendations No problem at all. I see you have modeled the IXL-12 in a small box with a round port [posted in this thread] have you begun to model the unit with a slotted port yet? Before you begin construction I believe it would be beneficial if I overlook your plans. I am about to head to work, but after I am done I will model the driver and make my recommendations for ideal cabinet/port size as well as a small box solution. Andrew | ||||
| | #45 | ||||
| Re: Port Length Recommendations The IXL-12 in a small box with a round port was just preliminary modeling to get things going here. I will have to draw up plans with a slot port as that would save more space over a round port. I'll try to model with a maximum airspeed of around 28 m/s at the tuning frequency to avoid most of the effects of port compression. | ||||
| | #46 | |||||
| | #47 | ||||
| Re: Port Length Recommendations Not a problem Steve. I'll gladly test both HT and music. ![]() | ||||
| | #48 | ||||||
As far as perception I have used myself, others and far more credible sources such as peer reviewed JAES articles related to actual real world measurements to prove my point. I fail to see why you are unwilling to accept that this resonance is not audible if properly crossed over as I recommend. *It is clear that a -10dB attenuation is a much higher value than that actually obtained from my measurements. Furthermore, it is likely that if resonance was only attenuated by -5dB it would be inaudible in the same circumstances as shown by credible perceptual research. Andrew | ||||||
| | #49 | |||||
*It is important to note that modeling is only accurate with the assumption that the driver and system as a whole will act in a linear fashion. This is a highly unlikely case with most drivers once moderate to high power/excursion is achieved due to lack of linearity with the drivers motor [suspension and motor force]. With regard to this linearity relating to air velocity modeled in your attached file I would expect port compression near tuning which would result in less overall output at 18Hz as compared to my offered model despite modeled results showing the opposite. Andrew | |||||
| | #50 | ||||
| Re: Port Length Recommendations Whats up fellas, I am also using a 55 inch slot port on my current build. http://www.hometheatershack.com/foru...v-2-build.html Unfortunately, this project has to take a backseat for about a month. I am hoping my crossover takes care of any issues. If not, can someone post a link to that notch filter that was mentioned in one of the first posts. I did a google search, but i dont know exactly what I am looking for. Also, why wouldnt you be able to tame down the peak at the first port resonance with an EQ? | ||||
| Bookmarks |
| Tags |
| moderators, subwoofer |
| Thread Tools | |
