Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
scrap sonotube
Discuss scrap sonotube in the DIY Speakers and Subwoofers forum; scrap sonotube this seemed like the best place for this thread because it primarily deals with sono subs... anyone have a scrap ...
Views: 370 - Replies: 9
Old 12-24-08, 01:07 PM   #1
Alias: Binger
Loc: Omaha
User: #18424
Since: Mar 2008
  SQCherokee is offline
scrap sonotube
anyone have a scrap section of sonotube that I could purchase?
I need either
20" dia 5ft long
or 30" dia 2ish ft long
this will be for a sealed enclosure...sonosub calculator tells me this will give me just shy of 8cubic ft.
this is the first step in changing the current curve of the WAF
thanks in advance.
Brian
Old 12-24-08, 01:18 PM   #2
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: scrap sonotube
I don't know about others, but when I got my Sonotube I bought the exact size I need it
This is the company where I got mine, if you're located in Omaha, NE here is the link to the stores near you http://www.whitecapdirect.com/locati...zip=&radius=25 ...Good Luck.
Old 12-24-08, 01:50 PM   #3
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Re: scrap sonotube
20" dia 5ft long minus endcaps would have an internal volume of 10.6 cu.ft.
30" dia 2ft long minus endcaps would have an internal volume of 9.2 cu.ft.
We're all in this together!
Members DIY Subwoofer Database
Old 12-30-08, 02:09 AM   #4
Alias: Binger
Loc: Omaha
User: #18424
Since: Mar 2008
Re: scrap sonotube
so I was driving home from dopping my wife and son off at the airport...I came across a piece of sonotube laying on the side of the road...so I went home grabbed my hatch back and went back to pick it up...put it in the car...went to work...then when I came home I noticed that in my excitement i didn't realize that this thing is 50" across...so I might cut it down a bit and use it as a big coffe table sono sub...or I may just throw it out...because its huge.
Old 12-30-08, 03:27 AM   #5
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Re: scrap sonotube
Making end caps for it would be a challenge.
Old 12-30-08, 07:17 AM   #6
Alias: fackamato
Loc: Sweden / Ireland
User: #11666
Since: Sep 2007
  fackamato is offline
Re: scrap sonotube
50 inches across! That's nothing!
It would be a huge sub that's for sure
Old 12-30-08, 02:39 PM   #7
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Re: scrap sonotube
fackamato wrote: View Post
A "table" 18 inches high works out to be 20 cu.ft. That would make a "low profile" LLT!
Old 12-30-08, 06:21 PM   #8
Alias: Binger
Loc: Omaha
User: #18424
Since: Mar 2008
Re: scrap sonotube
I was thinking about the massive size of this thing...then I thought...what about cuting it then rolling it up in a spiral like a snail shell...then securing wood to the sides like normal...then have the bends be 3-4" apart and use that like a long curved slot port.
How would I go about calculating this to see if its even doable?
Old 12-30-08, 06:25 PM   #9
Alias: Binger
Loc: Omaha
User: #18424
Since: Mar 2008
Re: scrap sonotube
never mind...I went down stairs to measure its depth...and I noticed that it was wet on one side and the moisture made the layers split apart about half way through the depth of the tube all the way around.
Guess its off to white cap in the spring.
Old 12-31-08, 06:28 AM   #10
Alias: Sam
Loc: Adelaide
User: #11091
Since: Aug 2007
  a1161979 is offline
Re: scrap sonotube
Mike P. wrote: View Post
Porting it woulkd be interesting tough
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
scrap, sonotube
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
