| DIY Subwoofers - Sealed and Ported LLT Explained - Discussion ThreadDiscuss LLT Explained - Discussion Thread in the DIY Speakers and Subwoofers forum; LLT Explained - Discussion Thread Well, I built an LLT using the 15" TC-2000 and have been very pleased with it so far.
Yeah, a ... |
Views: 2000 - Replies: 156
| | #51 | ||||
| Re: LLT Explained Well, I built an LLT using the 15" TC-2000 and have been very pleased with it so far. Yeah, a 12-13ft^3 MDF enclosure would be pretty **** heavy, which is one of the main reasons I chose to go the sonotube route. Most folks make their own jig to cut the big diameters, but there is a jasper jig available that is capapble of much larger diameters. http://www.rockler.com/product.cfm?page=5960 | ||||
| | #52 | ||||||||
| Re: LLT Explained Quote:
Will, thats huge :raped: If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | ||||||||
| | #53 | |||||
The problem is as I mentioned, to resolve the issue of a resurgence in port output one must use a smaller enclosure with a lower tune, and this gets away from a successful LLT design. Try making a LLT with a RLp12 D2 - just ain't gonna happen. The RLp15 just makes it. The reason I keep saying that is to make the point that high Bl and low Qts work against a LLT design. | |||||
| | #54 | |||||
| Re: LLT Explained Couldn't answer that as I'm nowhere near qualified to answer that. I haven't kept track of every LLT design built Plus, Its totally irrelevant to my entire post, even the section you're quoting. ![]() Quote:
So I hope that at this point everyone understands why low Qts/high Bl aren't something to look for to use in an Xl-sized Ebs alignment...its been repeated enough times in this thread ![]() Now, Someone build me a large and low tuned Sono for my 1030ft^3 bedroom! ![]() If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||||
| | #55 | |||||
BTW, what are the particulars on your TC-2000 LLT? I was looking at using the TC2K 15" SVC, going about 13 cu ft with a 13hz tune and three 4" ports. | |||||
| | #56 | ||||
| Re: LLT Explained NP. I used the SVC model as well, and the enclosure is roughly 335liters net, tuned to around 14Hz. I used a single 6" double-flared port from PSP, and I am happy with it. http://s27.photobucket.com/albums/c199/wadeere/Sonosub/ Here is the thread that chronicles the entire build. http://www.avsforum.com/avs-vb/showthread.php?t=725955 Last edited by WillyD; 12-10-06 at 11:39 PM.. Reason: ... | ||||
| | #58 | |||||||
). If some wanted a good LMS driver to use for a LLT, the 4000 would be it aside from its poor sensitivity, so it would be nice if the 4100 was similar with just a more efficient or sensitive motor. | |||||||
| | #59 | ||||
| Re: LLT Explained Ahh, yeah I understand that completely. That was the time when I first started getting into DIY subs...unfortunately. Anyway, I hope the 4100neo proves to be a good LLT contender. It'll be good to have yet another option out there...especially after that dry spell you mention. Its slowly beginning to look better for DIY again. From what I've heard it'll model very similarly to the LMS-5400 which will be a good thing. Can't wait for that rl-p18 either. Its going to be ridiculous. If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | ||||
| | #61 | |||||
| | #62 | ||||
| Re: LLT Explained Just a heads up, an Avalanche 18 driver has become available. PM me for details if you are interested - it is essentially the ideal driver for a LLT. | ||||
| | #63 | ||||
| Re: LLT Explained Steve, Recently, a friend asked me to help assist him in putting together a “budget” home theater setup. Together we decided to start with a subwoofer as our first project. Our budget for the sub is about $400. I have this plate amp on order http://www.apexjr.com/Apexsenior.htm . Side note… this plate is on special until the end of the month for $125. I stumbled upon this thread today (not really had a ton of time to read all the info at AVS) and like what I have read so far. While the RL-P15 and TC2000 15” drivers are a great value and work in an LLT subwoofer, I think the needed power and cost of these drivers blows our budget. Which leads me to my question… is there a 12” option out there suitable for an LLT? Using the T/S recommendations outlined in this thread, would the new CSS SD12 fit the bill http://www.creativesound.ca/details.php?model=SD12 ? How about the new TC DB-500 12”, or even the TC1000 12”? One thing in our favor is the WAF isn’t opposed to a large enclosure aside from the finished product needs to match the existing color/finish of the entertainment wall unit. Which sparks another question… is there any benefit in using a sona tube over an MDF/BB plywood cabinet? I am afraid the cabinet guy is going to have a hard time making a cardboard tube look like painted knotty alder. Thanks, Chris | ||||
| | #64 | ||||
| Re: LLT Explained Well I have had a little more time to play around with Unibox and also read more on the web about LLT designs. From what I have been able to gather, the 15” drivers previously mentioned are still the best options. However, I am determined to make a 12” driver work. Of the drivers in the 12” range the CSS SD12 seems to be the best. Here is what I have come up with so far... Will someone please comment on this proposed design? | ||||
| | #65 | ||||
| Re: LLT Explained Well you'd want to avoid the resurgence in output, you want a smooth, shallow rolloff prior to the 4th order rolloff below tuning. Without modeling this driver, I just don't think a 12" will really be suitable without giving up too much in the more usable bass ranges. Larger drivers "get away with it" because the headroom is already typically more than enough in higher bass frequencies, so some efficiency is shifted down low. I'd go a little smaller, raise the tuning to ~19-20hz, use the 18hz highpass in the plate amp, and end up with a nice subwoofer ![]() | ||||
| | #66 | ||||
| Re: LLT Explained Steve, Thanks for your reply… Your right! I have had a very difficult time getting a 12” driver to work. In the end I really want to avoid doing another boring sealed sub. I was also hoping an LLT sub could cure me of my "ported is bad" stigma. It’s beginning to look like maybe this isn’t the project to go LLT on. Well either way my interest is perked and hopefully sometime in the future I will be able to experience the LLT subwoofer. Before I completely abandon the idea, do you mind taking a look at the CSS SD12? I did as you suggested and changed the volume and tuning frequency (120 liters, 19 Hz, 5” port 31” long) I know this configuration doesn’t provide the desired roll off, but it is next to impossiable to get the desired roll off without generating very low port resonance. Please take a look at the attached graph and let me know if the CSS SD12 is really worth porting. Here are the driver specs from Creative Sound’s website. Re: 3.6, Le:1.45, Fs: 23.3, Qms: 2.87, Qes: 0.447, Qts: 0.387, Vas: 83.3, Cms: 0.25, SD: 490, Xmax 19.5, Xmech: 32, BL: 14.6, Mms: 186.4, SPL: 85.6. Thanks again for your imput. | ||||
| | #67 | ||||
| Re: LLT Explained To give you an idea of what something close to a LLT would be like with this driver, I'd go 140 effective liters with a 4" diameter port that is 25" long being fed with ~400 watts. Unfortunately, this still wouldn't meet the criteria, and such a design has port chuffing issues and might not achieve "enough" headroom. What I would aim for is something like 150 effective liters with a 5" diameter port (if possible) that is 24" long being fed with ~600 watts and using a 17hz 2nd order highpass. Is it guilty of the majority of traditional ported subwoofer issues? Yeah, but hey, considering it's a 12" driver, overall performance looks pretty good. | ||||
| | #68 | ||||
| Re: LLT Explained Your suggestions/info confirmed the same issues I was running into too. The 140 liter option will suffer port noise at about 100 watts and even the 150 liter, 5” X 24” port suggestion runs into port chuffing around 200 watts (provided my sims are accurate). Again, thanks so much for your help. Even though I will most likely end up building a sealed sub, unless I can convince my friend to spend more money on a larger driver, this has been a good learning experience. I am beginning to questions my own current stereo subs and think maybe an LLT TC2000 is in order. I have a pro amp that is about 1100 watts bridged into 4 ohms... ![]() | ||||
| | #69 | |||||
| | #70 | ||||
| Re: LLT Explained I sent you a PM. I was goint to use a Mach5Audio MJ-18 (due to budget reasons) but I may be interested in the Avalanche. | ||||
| | #71 | ||||
| Re: LLT Explained An Avalanche 18 on the open market won't last very long, it got taken a while back ![]() | ||||
| | #72 | ||||
| Re: LLT Explained Steve I'll take up your offer to design a better-performing LLT around my present IB system. ![]() 4 x AE IB15s in a leaky 600 cu feet enclosure of triangular elevation. EP2500 + CX2310 + BFD. 95dB @ 10Hz REW sinewave (uncorrected RS SPL latest analogue model) at the listening position 9 feet from the IB array is hardly getting the cones moving. Perhaps 10mm total movement? No matter how many times I try I always chicken out before going any louder. Well over 120dB uncorrected at higher frequencies. Off the 120dB scale at 9 feet around 40Hz. What I can't get with the IB is a house curve despite a +16dB boost at 20Hz on the BFD. ![]() My present response curve before and after BFD is shown in my sig below. I have loads of room to build large airtight enclosures within the triangular section behind my IB baffle if it's really worthwhile. ![]() This should be good fun! ![]() | ||||
| | #73 | ||||
| Re: LLT Explained Ok, so before EQ, looks like -6db at ~25hz. With EQ, let's say ~10hz. Piece of cake. In regards to output levels, no need to even mention them, it would be impossible for a ported design using the same drivers and amp to have less output if I look to tune where your sealed response dies off. It's really that simple, all a port is is like a EQ boost that doesn't use more excursion and reduces distortion. Can you hook me up with the parameters for that driver? | ||||
| | #74 | ||||
| Re: LLT Explained Hi Steve AE IB15 (discontinued) Fs________16Hz Qms______4.9 Qes_______.48 Qts_______.44 VAS______467 Zn_________8 Re________5.6 Le________1.25 Mms._____218 Cms______.45 Bl________16 Sd_______855 SPL______89.5 Pe Cont___500 Xmax_____15.5 VC dia____54 VC l______38 Gap Ht____.385 | ||||
| | #75 | ||||
| Re: LLT Explained Wow Chris, I'm not just saying this, but you almost couldn't have asked for a driver more suited to this type of application (ported IB design) except for something like the LMS 4000. That Vas is very high for a 15" driver, making proper porting and low end sensitivity a sinch. More excursion woulda been nice, but can't complain. Let me first collect a little more information though. With that 16db boost at 20hz, in all honesty, have you ever experienced any bottoming? You can get 120db+ levels at mid to high bass frequencies, but there is heavy compression going on below that, and your natural response shows this. Without exceeding excursion limits, and taking into account electronics rolloff, that IB is limited at ~9.5hz to 170 watts. So assuming you watch the typical WOTW, Incredibles, and other such low bass intensive movies at spirited levels (-10 or higher), if there has never been any bottoming, I can factor in more electronics rolloff than I am now. Or do you not really listen that loud (-10 or higher)? And are these sweeps corrected or not? Using Sonnie's correction files if so? As far as room gain, doesn't really look like you are getting any. In fact, at the listening position, seems like you are losing a touch of low end. See the attached picture, it is what the rolloff should look like without any room influence, 12db/octave. This may also be incluenced partly by electronics rolloff.....my fingers would point in the direction of that standalone crossover and the BFD It would also seem that the response looks more like the enclosure volume was 14 cubic feet as opposed to 600 based on where the rolloff begins (40hz) - that probably means the driver suspension isn't nearly as loose as AE claims.Anyway you could take a 75db sweep from 10-100hz without that crossover or BFD in the chain? As in unplug them and go dvd player - processor - amp - sub? If not, no big deal, but the better idea I have of your electronics rolloff, the more performance I can extract. Make sure you are using Sonnie's RS spl meter correction file. I'll wait to finalize the ported design until you can respond to some of those, but from an intial look, you won't need to partition off more than ~150 cubic feet, and you'll have up to 10db more headroom down low. Last edited by SteveCallas; 01-10-07 at 11:30 AM.. | ||||
