| DIY Subwoofers - Sealed and Ported LLT ExplainedDiscuss LLT Explained in the DIY Speakers and Subwoofers forum; LLT Explained With your recommendation I don't have to worry about two. Great!
Well if you try making a LLT from a ... |
| | #101 (Link) | |||||
| Re: LLT Explained Quote:
| | #102 (Link) | |||
| Re: LLT Explained Steve ... That helps a lot. I think I'm on at least one rail of the track. Price does come into the mix as I need to do a complete HT system from scratch. Would you be kind enough to list acceptable 15" drivers for LLT so I can choose the optimum for my budget. Is the Dayton 15 Ref in the group or any of the Daytons? I can do multiples if that helps, boxes are cheap for me. Reason for Daytons is I can trade for them and pay no shipping. Is there an easy way to evaluate whether any two or more woofers would be better than one of better known quality, i.e. two Dayton model X's vs. one RPL-15? Zene | |||
| | #103 (Link) | |||
| Re: LLT Explained The Dayton Ref HiFi 15 would work, but you'd probably want to use two of them to ensure plenty of headroom. The only other real options at the moment are the already mentioned TC 2000 15 svc, the SS RLp15 D2, the LMS 4000 15 (need two), the LMS 5400 18, and maybe the new Adire Tumult 15 D2. Cost/performance wise, the SS RLp15 comes in first, with the TC 2000 15 offering slightly more performance for slightly more cost and being a little larger, and then dual Dayton HiFi 15s for a little more and double the size of the TC 2000 enclosure, though it needs the least power. If you list your budget and size limitations, I can help you reach a solution pretty easily. | |||
| | #105 (Link) | ||||
| | #106 (Link) | |||
| Re: LLT Explained Yeah dude, it definitely made production....there was even a build thread on the TC Sounds forums. But no doubt it wasn't very popular. I am hoping the 4100 Neo will be much more successful. | |||
| | #107 (Link) | |||
| Re: LLT Explained Steve ... Will figure budget. I have a few more people to talk to about equipment. In the mean time can you tell me what excursion limits limits as a % of Xmax you feel is good headroom. I can work backwards with SPL wanted to find power limits without exceeding mfg power limits. So for Xmax = 20mm, 10mm would be 50%. Then inputting power into UniBox to match that limit. As long as that does not exceed Pe I should be good to go, but I am not positive which mfg power limits to use Pe or max. Hope that makes sense? Zene | |||
| | #108 (Link) | |||
| Re: LLT Explained Well I try to amp limit so that max excursion limits can't be reached, and typically this ends up being below or near the power handling limits. Depending on the output levels max power would correlate to, it can be ok to use an amp with more power than the driver can handle. As for the amount of headroom, based on many LLT owner experiences, I would advise that modeling show the sub to be capable of 112db+ levels above tuning for spirited playback. Depending on how loud you listen to, you may need more than that. Overall though, most are very satisfied with that capability. | |||
| | #109 (Link) | |||
| Re: LLT Explained Steve .. 112dB sounds reasonable. Music ; I understand levels, but HT is another animal. I do not get a clue in demo rooms. Walking around with a RS meter is pointless. Just to suck-up a little more, your work explaining LLT is going to help a lot of old Star War fans (me, me). Much appreciated. Zene | |||
| | #110 (Link) | |||
| Re: LLT Explained Thanks. To be honest, I find output levels for home theater much easier to understand than for music. Assuming calibrated systems and capable gear, if I watch a movie at -15 on my system, then watch it at -15 on a friend's system, I should be exeriencing virtually the same output levels. Assuming the movie wasn't recorded hot, I would also expect the potential for each speaker to hit 90db levels and the LFE channel to hit 100db levels....factor in the redirected bass that goes to the sub as well, and the sub may be asked to reproduce ~105db levels on its own. This is because a calibrated master volume level of 0 equates to the potential for each speaker channel to hit 105db peaks and the LFE channel to hit 115db peaks. You simply adjust from there. When it comes to music, I really don't know if there is a standard or reference level. I don't know what the dynamic range is for PCM, DVD-A, SACD, or other music formats. Differences in compression/dynamic range vary WILDLY from cd to cd. But anyway, getting back to the sub, if it's capable of 112db+ levels above tuning, that means you should be able to listen to movies on a calibrated system up to a master volume level of about -8 (that's pretty loud ). Of course there are hot movie tracks every now and then (War of the Worlds DTS), but by and large, I've found I typically listen at the same master volume for every movie. | |||
| | #111 (Link) | |||
| Re: LLT Explained Steve ... Stereo does have it ups and downs (punny); cd vs records,type of music, mood, purpose, wine intake and a hundred other variables as you mentioned. My saving grace is a remote volume control on my preamp. I could not get along without one. I have a small red dot on the knob so I can see it and simply make a mark on a sticker on the cd case or record cover that shows clock position of desired level. Match it with the preamp knob and I'm close. Sorry for stereo interrupting HT, but may be useful to others. Zene | |||
| | #112 (Link) | |||
| Re: LLT Explained P.S. Sub amp is at arms length for quick change, noting the approx positions for any cd or record I particularly want different settings than normal. It's easier than one might think. Practice makes quick. Marks on knobs this time is for flattest response return. Zene | |||
| | #113 (Link) | |||
| Re: LLT Explained Steve, In case the TC2000 15" is on backorder, is the Ficaraudio Q15 suitable for LLT? Q15 specs https://ssl.perfora.net/www.ficaraud...iew.shopscript DUAL 1 | DUAL 2 Fs: 25.9 Hz | 24.9 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 5.64 | 5.72 Qes: .54 | .54 Qts: .49 | .49 Mms: 257g | 279g Cms: 0.15mm/N | 0.15mm/N Sd: 810cm^2 | 810cm^2 Vas: 135 l | 135 l Spl: 88.2dB 1W/1m | 87.7dB 1W/1m Bl: 10.4 N/A | 15.1 N/A Xmax: 27mm Rms: 1000W Sealed box: 2-2.6 cuft Ported box: 2.8-4 cuft @ 28-33Hz Sub OD: 15.625” Cut ID: 14.125” Mounting depth: 8.500” Displacement: 0.19cuft Regarding the questions for 12" drivers, the Adire Brahma 12" works well in the Sadhara sonotube. I'm looking for tighter, chest pounding with extension below 20Hz. thanks for your efforts. Al | |||
| | #115 (Link) | |||
| Re: LLT Explained On another forum someone built a Q15 LLT , but the Q15 he used was custom. By his accounts, it turned out great. It was a Dual4 ohm version, I remember. http://www.avsforum.com/avs-vb/showthread.php?t=728542 | |||
| | #116 (Link) | ||||
| Re: LLT Explained Wow, never even caught that thread Quote:
Al, if you can afford $30 more and a bit more space than what you were planning, I'd highly suggest going with the 18". | ||||
| | #118 (Link) | |||
| Re: LLT Explained what a great job with so much info, tks steve! ![]() proud to be first SVS user in TW! and so proud to be first TW user with 2 SVSes! now TW first Onkyo 905 user! ![]() threads http://www.hometheatershack.com/foru...s-user-tw.html http://www.hometheatershack.com/foru...html#post32842 http://www.hometheatershack.com/foru...html#post47160 http://photo.pchome.com.tw/lienly | |||
| | #119 (Link) | |||
| Re: LLT Explained I don't understand this issue with "resurgance of the port output"...especially in light of all the non-linear behavior: http://www.klippel.de/pubs/default.asp http://forums.klipsch.com/forums/sto...6640/PORTS.pdf With port compression, voice coil temp rise, Bl and suspension drops, inductance modulation, etc etc..., I think there is a pretty good argument for implementing resurgance over the port's passband. It just requires the cabinet to be much larger... Btw, your response times for the port build up or whatever seem a bit skewed considering that an 18Hz filter is going to affect the output at 20Hz...I think it would be more fair to show the response where the peaks are both .4, not .3 and .4. I'm not sure if it matters, but I would expect output to increase faster when the air velocity is faster... -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | |||
| | #120 (Link) | |||||||
| | #121 (Link) | ||||||
Klippel isn't doing all this research for nothing. ![]() Quote:
The tuning alignment is a degree of freedom within the design that can be used to address the non-linearities of the total system. Minimizing the non-linear behavior of one single variable may not be in the best interests of the whole system. Quote:
I was just commenting that it would be more meaningful if you had used a peaking filter, or merely turned up the volume on the highpassed sub so that the amplitudes were the same between trials. Only then will the time-domain differences be meaningful. I hope I don't come across negative - I totally dig the writeup and just wanted to throw some other ideas out there. It's hard to present an idea without coming across negatively. Heck, I don't even propose these ideas as fact... -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | ||||||
| | #122 (Link) | |||||||
| | #123 (Link) | ||||
