Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
My first attempt at DIY (sort of)
Discuss My first attempt at DIY (sort of) in the DIY Speakers and Subwoofers forum; My first attempt at DIY (sort of) Hello all. I am attempting my first build, and by that i mean assembly. I received all my parts from ...
Views: 451 - Replies: 17
Old 08-25-09, 02:59 PM   #1
Alias: chris
Loc: winnipeg, mb, canada
User: #40378
Since: Aug 2009
  chrischaos is offline
Hello all. I am attempting my first build, and by that i mean assembly. I received all my parts from ED. They cut the endcaps for me, and are providing the drivers and amps ( 4-19 0v2 and 2 lt1300). All to be enclosed in 2 sealed sonotubes. My first step will be cutting the sonotubes- any suggestions on which type of saw to use? Any recommendations on painting the endcaps? I saw a "marble look" spray can and thought that may look nice. I am going to wrap the tubes with a custom graphic dye sublimated cloth that i will get a friend to design (not sure on design yet though). I appreciate any feedback and will start submitting pics when i get the cuts made.
Old 08-25-09, 05:03 PM   #2
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Re: My first attempt at DIY (sort of)
I used a hacksaw and slowly followed the cut line around the tube. Make sure your cut line is perfectly square. Prime the end caps before you spray them. The inside of the tube has a transparent release film that needs to be peeled off so the glue will stick to the tube and endcap.
Is the 190v2 dual 4 ohm coils?
We're all in this together!
Members DIY Subwoofer Database
Old 08-25-09, 08:59 PM   #3
Alias: chris
User: #40378
Since: Aug 2009
dual 4 ohm coils-yes. Thanks for the other tips ( i would not have peeled the film). I will definitely prime everything. The tube will be blasted with black as well to make sure no other colour comes through the fabric.
Old 08-25-09, 10:05 PM   #4
Alias: Mike
User: #8033
Since: Apr 2007
What net volume will the tubes be?
Old 08-26-09, 08:20 AM   #5
Alias: chris
User: #40378
Since: Aug 2009
About 11 cu. '. or 311 L. The tube will be 41" long with a diameter of 24.75" (11.42 cu.') i guessing about .5 cu' for drivers.
Old 08-26-09, 09:02 AM   #6
Alias: Mike
User: #8033
Since: Apr 2007
Modeling shows 122+ db at 20 hz with room gain, you have some serious bass coming your way!
Old 08-26-09, 12:04 PM   #7
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
  ironglen is offline
Mike P. wrote: View Post
That's the way we like it here at HTS
You can check out several sonosub builds here to see some helpful ideas and prevent some pitfalls
Old 11-04-09, 11:20 AM   #8
Alias: chris
User: #40378
Since: Aug 2009
This is the graphic i was thinking of for my sonotube build. Any thoughts?
Old 11-04-09, 11:23 AM   #9
Alias: Mike
User: #8033
Since: Apr 2007
It's definitely an eye catcher!
Old 11-04-09, 12:00 PM   #10
Alias: Todd
User: #36453
Since: Apr 2009
  byrne is offline
That is pretty cool looking. How are you going to apply it to the sono tube?
Todd
Old 11-04-09, 12:06 PM   #11
Alias: lsiberian
Loc: Fort Worth, TX
User: #35637
Since: Mar 2009
  lsiberian is offline
Do you have a plunge router? Those are great for cutting circles and templates.
You can also use a jigsaw or even a hack saw if you want a good workout.
Old 11-04-09, 01:14 PM   #12
Alias: chris
User: #40378
Since: Aug 2009
The graphic will be printed on a piece of cloth. The process is dye sublimation. Same thing as graphics on poker/pool tables. I will apply it to the tube with velcro (i think) at the top and bottom.
Old 11-04-09, 03:27 PM   #13
Alias: chris
User: #40378
Since: Aug 2009
Here are more pics. They did not turn out great after i tried to resize. The build went great. It gives me a great amount of respect for those of you out there that do your own woodworking as well as some of the beautiful finishes i've seen on DIY builds.
Old 11-05-09, 02:47 AM   #14
Alias: Ryan
Ryan Anderson's Avatar
Loc: sfsd
User: #39709
Since: Jul 2009
  Ryan Anderson is online now
chrischaos wrote: View Post
are you putting this on your sonos??
what didnt turn out, build pics or graphix?
My LLT in-car build log
Fi IB3 18 21 cubes @ 15Hz 7.75" x 19.5" sonotube
http://www.hometheatershack.com/foru...tml#post198320
Old 11-05-09, 08:54 AM   #15
Alias: chris
User: #40378
Since: Aug 2009
The pics did not turn out great. After i tried to resize them it really cut out a lot. I like the colors on this a little better. This will be the graphic i'm using,
http://i737.photobucket.com/albums/x..._Tubes3.jpg
This will be applied to the tubes
Old 11-05-09, 07:30 PM   #16
Alias: Ryan
Loc: sfsd
User: #39709
Since: Jul 2009
its a sweet pic!
Old 11-10-09, 09:30 AM   #17
Alias: chris
User: #40378
Since: Aug 2009
Hey all. Just a quick update. The subs are in place and running. The graphic is at the printers. It will be applied to a stretch fabric that will be sewn into a "sock". It should be ready in a week or so. With the ratshack meter, I'm hitting 117 DB at listening pos (14') with my avr at -10 watching Iron Man. I know i've got reflections and things i'm going to have to address, but i am extremely happy so far.
Old 11-10-09, 02:38 PM   #18
Alias: Fred
User: #20762
Since: May 2008
  fredk is offline
I'm looking forward to pics with the cloth on the sub. Thats a really good idea!
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
(sort, attempt
