| DIY Subwoofers - Sealed and Ported New diy subDiscuss New diy sub in the DIY Speakers and Subwoofers forum; New diy sub Hi there,
Ive gone for 2 FI Q18 D1's so I can run them bridged in 4 ohms. Had a ... |
Views: 4233 - Replies: 304
| | #52 | ||||
| Re: New diy sub Yes, now you're on the right track. A final 4 ohm load is what you need.Here is how to wire 2 - D1 subs for a 4 ohm load. ![]() | ||||
| | #53 | ||||
| Re: New diy sub Cheers Mike. I ordered them today and will get them by the end of next week. Hopefully be able to start it next weekend. I will keep you posted and upload pics as I go on. Cheers for all your help mate. Your a star. Graham | ||||
| | #54 | ||||
| Re: New diy sub Looking forward to your build pics! | ||||
| | #55 | ||||
| Re: New diy sub Mike What sort of wadding is best to use. Sheets or stuff you chuck in. What does it do to the sound and characteristics of the sub. Also what glue should I use. One thought I just had was with regards to the qtc. The qtc on my set up is on 0.95. What does this mean and is this ok. When I change the box size to 50 cu ft it goes down to 0.7. cheers Graham Last edited by gperkins_1973; 09-16-09 at 03:58 PM.. | ||||
| | #56 | ||||
| Re: New diy sub Onkyo 875 | SVS PB13U (sold, DIY in the works) | Bose 203 Fronts | MA R250 Center | MA R270 Rears Is there a cure for this addiction | ||||
| | #58 | ||||
| Re: New diy sub Hi guys, I took a few pictures yesterday so I thought I would start posting up as I go. One is of the amp and a few of the box roughly made up so you can see how big it will be. What is the best adhesive to use to glue the wood together. There seems to be mixed opinions over here in the UK but as there are alot more diyers in America it would be good to get your opinions. cheers Graham | ||||
| | #59 | ||||
| Re: New diy sub Any yellow carpenters glue works well, I use Elmer's brand. Is that going to be the location of the sub when you're finished building? | ||||
| | #60 | ||||
| Re: New diy sub Mike, Yep! I had my PB13 firing into the wall and that was the best sound I found in the room and I was surprised it wasn't boomy either. I will be removing one of the TV cabinets and moving the speakers in slightly so I can pull the sub away from the wall a bit. God it weighs a tonne. I am going to put it on castors as it would need two strong men to move it. To give you an idea how it compares to my PB13 size wise for a laugh. ![]() Do you know what gripfill is like? cheers Graham | ||||
| | #61 | ||||
| Re: New diy sub Gripfill will work fine. Will you be using clamps or screws? | ||||
| | #62 | ||||
| Re: New diy sub Mike, Screws, screws and more screws. I am going to put sealant in all the internal edges and corners to seal properly. I should get the drivers by the end of the week so I can then draw up my outer holes properly. Just one thought, on the internal bracing would it be ok for me to cut the main large circle and then just cut smaller circles above and below rather than cutting perfect shapes. See below. cheers Graham | ||||
| | #63 | ||||
| Re: New diy sub If you're using screws you have to predrill a pilot hole and countersink first or the MDF will split. Practice on a couple of pieces of scrap first until you get the pilot hole size and depth figured out for the screws you'll be using. 1.5" drywall screws work well as they have a smaller head then a regular screw. As for bracing, which ever way it easier for you, both would work. | ||||
| | #64 | ||||
| Re: New diy sub Hi guys, What is the best way to connect the Onkyo 876 to the behringer. I've seen a XLR to rca lead http://www.dolphinmusic.co.uk/catego..._-rca-(phono)/ Would this be ok. cheers Graham | ||||
| | #65 | ||||||
| Re: New diy sub Quote:
![]() Onkyo 875 | SVS PB13U (sold, DIY in the works) | Bose 203 Fronts | MA R250 Center | MA R270 Rears Is there a cure for this addiction | ||||||
| | #66 | ||||
| Re: New diy sub Dan, The behringer 4000 don't have rca input so would it be a case of getting a XLR adapter to put the rca end into the amp. There seems to be alot of people getting hum noises when they connect their BFD's into the configuration. Does this happen to everyone. cheers Graham | ||||
| | #67 | ||||
| Re: New diy sub Its quite common for the BFD to cause a hum in a lot of systems. There is a solution to this if you look around the forum on here. What you need is one or two of these, depending on how many of the inputs your going to use: ![]() Onkyo 875 | SVS PB13U (sold, DIY in the works) | Bose 203 Fronts | MA R250 Center | MA R270 Rears Is there a cure for this addiction | ||||
| | #68 | ||||
| Re: New diy sub I'm having a hum problem with my Behringer MIC2200. Is it the same solution as with the BFD? | ||||
| | #69 | ||||
| Re: New diy sub How is the sub coming a long Graham, has the build started yet? | ||||
| | #70 | ||||
| Re: New diy sub Recruit, I've got the Gperkins thread on the avforums website as well. The box will be started this weekend so I will be getting some pictures up on Monday to show. Just a few bits to get now. Speaker wall plate, white oak wood veneer (finally chosen on 1 coat of antique pine and one coat of clear gloss) and then to do the speaker grills which I know what I am going to do on that. Oh and the feet too. The fiberfill is perfect. cheers Graham | ||||
| | #71 | |||||
| Re: New diy sub That's brilliant graham, look forward to the end results, when you post it here ![]() Quote:
| | #72 | ||||
| Re: New diy sub Right chaps I have got some pictures now for you. Its been a while as I am now doing it all myself. I will upload some more as there are a few for you. I bought myself a router and made a dummy jig for the wholes which need to quite large. Let me know what you think. cheers Graham | ||||
| | #73 | ||||
| Re: New diy sub Looking good Graham how long do you think before it's completed? | ||||
