Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
New diy sub
Discuss New diy sub in the DIY Speakers and Subwoofers forum; New diy sub Matt, have you tried this in MDF or solid wood as shown in the link?...
Views: 4256 - Replies: 304
Old 10-29-09, 08:37 PM   #151
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Re: New diy sub
We're all in this together!
Members DIY Subwoofer Database
Old 10-29-09, 08:56 PM   #152
Alias: Matt
evilskillit's Avatar
Loc: USA, Kansas City, MO
User: #26820
Since: Oct 2008
  evilskillit is offline
Re: New diy sub
MDF, so far all my designs have been MDF. I tried to build something out of baltic birch but when I went Home Depot was out . The Geurilla Glue worked great too, in my smaller bookshelf speakers I had a hard time getting the t-nuts to bite and they would tend to want to wiggle and spin. I never did take those back apart and put on Geurilla Glue tho if I ever have them apart I'll put some on any t-nut that falls out. But I built my 12s that way and it worked great, also put in the t-nuts for my friends sub and floor spikes that way and it worked great as well. Now the hole can't be too much smaller than the t-nut obviously, but as long as its close it works great.
Here is a great link discussing the installation of t-nuts with and without glues
Link to discussion
Old 10-30-09, 02:20 AM   #153
Alias: gperkins
User: #37001
Since: Aug 2008
  gperkins_1973 is offline
Re: New diy sub
Thanks for this guys. I have M5 hex bolts and t nuts. I could try to countersink the inside so the t nut has a slight recess and then glue them in.
cheers
graham
Old 10-30-09, 09:55 AM   #154
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Been thinking about EQing tonight and looking at various options.
FEEDBACK DESTROYER PRO DSP1124P - £70 approx
FEEDBACK DESTROYER PRO FBQ2496 - £120 approx
ULTRADRIVE PRO DCX2496 £220
ANTI MODE 8033 - £240
The first one seems to quite popular but am worried about the frequency response only starting at 20hz. What about frequencies below this as I am sure mine will hit a bit below that. How does that get measured. The second one has an auto facility on it from what I have read which would be handle with the option of manually tuning it. The third has a frequency response starting at 10hz and the Anti mode is 16hz. Does all this really make much difference.
Opinions would be appreciated please.
cheers
Graham
Old 10-30-09, 10:28 AM   #155
Alias: Mike
User: #8033
Since: Apr 2007
Re: New diy sub
The BFD's require measurement software like REW to see where the filters need to be applied. The Antimode 8033 is fully automatic and does an excellent job according to the review I read on it.
http://www.hometheatershack.com/foru...de-8033-a.html
As stated in the review, the 8033 does in minutes what it took hours to do with a BFD.
Old 10-30-09, 10:50 AM   #156
Shack Moderator
Alias: John
recruit's Avatar
Loc: UK - Near London
User: #37302
Since: May 2009
  recruit is online now
Re: New diy sub
For the money the Antimode seems to be the little box of magic for sub EQ...
Old 10-30-09, 11:02 AM   #157
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Thanks guys for that. I have used REW before. I had the PB13 before and REW produced quite a flat graph with no EQ the position of that sub will be the same as the one I am building so I am hoping for a similar result. What about the frequency response of the BFDs as they start from 20hz so what happens with the frequencies below that.
cheers
Graham
Old 10-31-09, 05:03 AM   #158
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
Re: New diy sub
Graham - I know that the Velodyne SMS-1 goes down to 5hz on one of the software versions for the unit, it is a long time since I played with one as I always found Audyssey more useful for EQ, to note though the filters only allow EQ'ing down to 15hz although the roll off can be set lower which is 5hz...but it does give a warning when doing this.
Old 10-31-09, 08:25 AM   #159
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Hi guys,
Just had a total nightmare with the t nuts. Didn't work at all. I pushed the bolts through with the washer and then tightened up the t nut a little and then screwed in the bolt. The first couple worked fine and then all the others, the t nuts wouldnt go into the wood. They just kept turning without gripping into the mdf.
Any suggestions? I am in fear of having to install my drivers at an angle if I cannot fix this.
cheers
graham
Old 10-31-09, 09:40 AM   #160
Alias: Mike
User: #8033
Since: Apr 2007
Re: New diy sub
I have always installed mine with a hammer and then applied glue to the perimeter of the T-Nut.
Old 10-31-09, 09:47 AM   #161
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Panic over, sorted it out now. Phew! I got an old drill bit to open the holes on the inside and then fixed them in. Thank god for that. I will be testing it at 6pm today when my brother comes over. Will take some pics then and do a video.
cheers
Graham
Old 10-31-09, 09:51 AM   #162
Alias: prize
Loc: Midlands, UK
User: #40735
Since: Aug 2009
  Prize78 is offline
Re: New diy sub
Driver's fitted now then Graham?? Is it worth me calling the national grid to brace them first?!!
Old 10-31-09, 09:55 AM   #163
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Prize,
Be patient my boy. I am letting the glue dry and at 6pm it will be fired up and rest assured you WILL hear it from all the way up there.
Bloody Gorilla glue, I got it every where. What a nightmare that stuff is.
cheers
Graham
Old 10-31-09, 10:44 AM   #164
Alias: Mike
User: #8033
Since: Apr 2007
Re: New diy sub
After the glue dries run the bolts through the T-Nuts before you mount the sub to make sure there are no problems.
Old 10-31-09, 11:52 AM   #165
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Hi guys,
Here is a picture of my veneer that I got from Richard Russell. I got two 8 x 4 sheets at £113 all in and that will veneer the whole of my box which I think is a great price. Just need to sort out the adhesive which I am not sure which to get yet. It is in oak and has a better colour to it than the peel and stick white oak I got from Vale Veneers.
Some teaser pics to follow.
cheers
Graham
Old 10-31-09, 11:56 AM   #166
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
As promised some more pics. Forgive the quality, rubbish digital camera.
Here is bad attempt at installing t nuts. The first one was a complete nightmare but the second one was a complete success.
cheers
graham
Old 10-31-09, 12:00 PM   #167
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Wait for it..... and at last a driver in.
Now it weighs a ton. I am really suprised how much difference just one driver has mad to the weight. Shocking!
Submersive?
cheers
Graham
Old 10-31-09, 12:03 PM   #168
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
And how this baby looks inside the enclosure. I think all in all its been a reall success and I am really pleased with how it all has turned out. Its not the cleanist of jobs but Im sure the sound will more than make up for it.
cheers
Graham
Old 10-31-09, 12:22 PM   #169
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
  yourgrandma is offline
Re: New diy sub
What a monster. Make sure no small children or household pets are in there when you close it up.
Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3
Old 10-31-09, 01:38 PM   #170
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Good point I have two cats and two children.
cheers
Graham
Old 10-31-09, 01:43 PM   #171
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
Re: New diy sub
Ummm, that does look rather tasty Graham...once fired up check adjacent walls to see if there is any cracks/movement
Old 10-31-09, 01:47 PM   #172
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Recruit,
I tell you one thing this is definitely not going to move anywhere. It really does weigh a ton.
cheers
Graham
Old 10-31-09, 01:50 PM   #173
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
Re: New diy sub
gperkins_1973 wrote: View Post
Recruit,
cheers
Graham
Lol...the sub won't but the house will
Seriously though it does look very good indeed
Old 10-31-09, 02:13 PM   #174
Alias: Mike
User: #8033
Since: Apr 2007
Re: New diy sub
You'll need to keep the poly fill away from the pole vent of the subs.
Old 10-31-09, 03:46 PM   #175
Alias: Mike
Loc: San Dimas, CA
User: #13466
Since: Nov 2007
  sub_crazy is offline
Re: New diy sub
Wow, your sub look very menacing..........nice
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
