Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
New diy sub
Discuss New diy sub in the DIY Speakers and Subwoofers forum; New diy sub Hi there, I live here in the UK and am looking to do a diy sub. I have just sold ...
Views: 4160 - Replies: 303
Old 09-09-09, 04:36 AM   #1
Alias: gperkins
User: #37001
Since: Aug 2008
  gperkins_1973 is offline
New diy sub
Hi there,
I live here in the UK and am looking to do a diy sub. I have just sold my PB13 ultra and was looking at a dual 18" opposite sealed sub similar design to the submersive but bigger and more powerful.
What 18" subs and amp would be good to use so that I can achieve a better response in the lower hz and upper hz that will beat the PB13. Dimensions that I can go up to are 36" long by 24" wide by about 30" high.
Is this possible and what options do I have. I am new to this so your advice would be great. I have been looking at FI subs but am open to all options.
cheers
Graham
Old 09-09-09, 11:02 AM   #2
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
bump
Old 09-09-09, 11:50 AM   #3
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
  ironglen is offline
Re: New diy sub
You've got plenty of options for 18"- Exodus Mal-X, Soundsplinter, the Fi- add a pro-amp of your choice with a equalizer, maybe Behringer dsp1124 and you're ready to build. Two of any of these with power should exceed your need At least that's what I've seen here... One of the excellent moderators may help out here. You can use winisd here to play around with modelling-it's fun to tinker with it if you've got the time.
Old 09-09-09, 02:56 PM   #4
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Re: New diy sub
Do you have a budget for the subs and the amp?
We're all in this together!
Members DIY Subwoofer Database
Old 09-09-09, 04:24 PM   #5
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Right here goes this is what Im looking at.
2 x Maelstorm gen 2's in a sealed enclosure measuring 36" long by 24" wide by 30" high in a dual opposite configuration like the submersive run by a behringer europower 4000 amp.
Your thoughts please.
cheers graham
Old 09-09-09, 05:20 PM   #6
Alias: Mike
User: #8033
Since: Apr 2007
Re: New diy sub
Actually that's exactly what I was going to suggest if your budget would allow it. The net volume of the box would be about 12 cu.ft., with each sub wired for 4 ohms and each fed from a channel of the amp they would handle the full power of the amp. Cone excursion is not an issue, there would be no requirement for a subsonic filter. Depending on how much room gain you'd get you can expect 120 -122 db at 20 hz.
Name:  uk maelstrom.JPG
Old 09-09-09, 05:40 PM   #7
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
how would that fair against the PB13 ultra I just sold. How much bracing would I need.
cheers graham
Old 09-09-09, 06:35 PM   #8
Alias: Mike
User: #8033
Since: Apr 2007
Re: New diy sub
The PB13 Ultra was tested at 105 db at 20 hz with a 20 hz tuning. I would suggest "window pane" bracing side to side and front to back.
Top view:
Old 09-09-09, 06:52 PM   #9
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
mike
I was thinking the same after looking at the diy kit for the A7s-650 from ED.
122db to 105db at 20 hz isnt that a massive difference?
cheers graham
Old 09-09-09, 07:06 PM   #10
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
  ironglen is offline
Re: New diy sub
Your house:
Your guests:
If you so wish
You're not messing around- I hope you have a strong back!
Old 09-09-09, 07:11 PM   #11
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
On a scale of 1 to 10 how powerful is that baby going to be.
cheers graham
Old 09-09-09, 07:12 PM   #12
Alias: Mike
User: #8033
Since: Apr 2007
Re: New diy sub
Come to think of it, the test I read was done outside so no room gain was added. 105 + 6 db room gain would put it inthe 111 db range. The dual 18's still have a big advantage though.
Old 09-09-09, 07:19 PM   #13
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
mike
so what do I need to do to make the PB13 look tiny.
I thought an extra 6db was twice the output. Surely a dual opposite configuration 18" sealed enclosure would walk all over the PB13.
cheers graham
Old 09-09-09, 08:51 PM   #14
Alias: Mike
User: #8033
Since: Apr 2007
Re: New diy sub
There's no question dual 18"s will outperform a 12" sub. By a wide margin.
Old 09-10-09, 02:47 PM   #15
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is offline
Re: New diy sub
gperkins1973 wrote: View Post
cheers graham
For real fun get 2 amps, one for each driver. Your destruction of the PB13-Ultra shall be the stuff legends are made of . . . Your grandchildren will tell tales of the "big speaker" that their ancester had built...You will pass go...You will collect $200...
Old 09-10-09, 06:26 PM   #16
Alias: Flamin 'D
User: #41683
Since: Sep 2009
  Flamin_D_Audio is offline
Re: New diy sub
soundsplinter? i didnt think that was around in the uk, if anyone finds a dealer let me know!
Old 09-11-09, 09:02 AM   #17
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Hi guys,
Quick question, How about the following:
Four of these drivers in a sealed box with 2 firing forwards and one each side running off one Behringer 4000 amp. It's a thought as someone over here on the UK thread is building a push/pull version with 2. I can get four of these for £200 less than the two Maelstrom Gen 11 drivers.
http://aespeakers.com/shop/catalog/p...products_id=68
Would I still be better with the dual 18" Maelstrom's in a sealed opposite sub or would the above sealed work with the four 15"s.
The sealed box for the four would have to be the same and that's 36" long by 24" wide by 30" high.
cheers
Graham
Old 09-11-09, 11:45 AM   #18
Alias: Mike
User: #8033
Since: Apr 2007
Re: New diy sub
Are they single 4 ohm coils?
Old 09-11-09, 11:50 AM   #19
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Mike,
Here is the link for option 1.
The other option is the FI Q15's.
Attached is a rough drawing to show what I was thinking of.
cheers
Graham
Old 09-11-09, 01:38 PM   #20
Alias: gary
Loc: UK
User: #4578
Since: Dec 2006
  needmorstuff is offline
Re: New diy sub
have you considered the IB route.. could have 4 18's then.
Old 09-11-09, 02:19 PM   #21
Alias: Mike
User: #8033
Since: Apr 2007
Re: New diy sub
The Fi or AE would have the advantage from 30 hz up.
Old 09-11-09, 02:39 PM   #22
Alias: gary
Loc: UK
User: #4578
Since: Dec 2006
Re: New diy sub
Mike P. wrote: View Post
Attachment 15807
not sure if yuo are aware but fi and ascent from here.. http://www.bladeice.com/products.php
Old 09-11-09, 04:02 PM   #23
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
mike
Sorry to be thick but I take it that graph is based on 4 FI's or AE 15's against 2 18" maelstroms. If theres doesn't seem alot in it. What would your advice be to go for. How would the FI Q18's dual opposite configuration compare to the dual 18" maelstrom's. Would you be able to show me them together please.
cheers graham
Old 09-11-09, 04:25 PM   #24
Alias: lsiberian
Loc: Fort Worth, TX
User: #35637
Since: Mar 2009
  lsiberian is offline
Re: New diy sub
have you considered a folded slot port design. They have low distortion and great extension. A lot of speaker builders I know prefer them.
Old 09-11-09, 04:32 PM   #25
Alias: gperkins
User: #37001
Since: Aug 2008
Re: New diy sub
Depends on what they are like for music as the PB13 ultra disappointed me in that department. Hence going sealed
Oh and I live in an end terrace house!
cheers graham
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
