| DIY Subwoofers - Sealed and Ported Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18Discuss Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 in the DIY Speakers and Subwoofers forum; Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 Having read a ton for several weeks and learned a lot, I am desiring more directed knowledge.
I am building ... |
Views: 724 - Replies: 29
| Having read a ton for several weeks and learned a lot, I am desiring more directed knowledge. I am building a 3300 cu foot (22' x 15' x 10') dedicated theater room, starting with the audio. I am planning my subs and wanted it loud and deep (who doesn't???). I have also finished reading the excellent book by Floyd Toole ( ) and in the interest of good bass for as many as possible, have elected to position two subwoofer enclosures in the middle of the front and the middle of the back wall. This places some constraints on my box size, notably the depth, which I want to keep at 18-20". I am planning to place 2 drivers in each vented enclosure and using Box Notes have arrived at a box that is 42" tall, 66" wide, and 20" deep with a working volume of 21.7 cu feet (615 liters). Here are the gory details (by the way the port is 8" diameter; the cursor makes it look like 18"): ![]() So, I am getting to the heart of my question here. I have modeled this box tuned to 15 Hz with two ED 19Ov.2 and two SoundSplinter RL-p18 drivers using WinISD alpha. Here are the SPL graphs without EQ assuming 125 W of system input power. The 19Ov.2 is in blue and the RL-p18 is in red: ![]() Not exactly the flat response from 15-80 Hz that I am looking for. If I apply parametric Eq (fc=15, Q=1, gain=4.5dB) to each system, then the curves look like this: ![]() I am struck by the flatter curve of the RL-p18, but slightly deeper extension of the 19Ov.2, but let's face it, at this point I am over my head and really don't know too much about what I am doing. Can I flatten the 19Ov.2 curve with a lowpass filter or ??? I am hoping that some of you smart folks can help me optimize the situation and solidify my build plans. Do note that the 190v.2 costs $245 shipped, while the RL-p18 is $440 shipped. I am cost conscious, so if I can get the 190v.2 to model flatter, then I will be convinced to go that direction, recognizing that this modeling gets you only so far what with the marked room influences that I see in some of the in room FR analyses that some of you all are posting... Thanks in advance for your advice and engagement in my project and apologies for the loooooong post, Geoff | ||||
| | #2 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 Be aware that the RL-p18 is currently unavailable and is estimated to be in stock 1st quarter 2010. Your SPL graph of the 19Ov.2 shows a 4 ohm load for both subs. What amp are you using? | ||||
| | #3 | ||||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 Quote:
Actually, I see that I left the "series resistance" field at 0.01 ohms, which is probably not correct. When considering two drivers with dual voice coils, what would be the recommended wiring for the two driver configuration with an EP2500 and what should I enter into this field into the "series resistance" field in WinISD? | ||||||
| | #4 | |||||
As for the "series resistance" in the Signal tab , that is not for the final ohm load of the subs. see "Designing your box" in the help files. | |||||
| | #5 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 Thanks for your help. Mike. I do not own drivers yet. I suspect that I would get the D4 version, which as I understand allows me to create either a 1 ohm or a 4 ohm load depending upon parallel or series wiring of the voice coils, respectively. Wiring the voice coils of each speaker in series and then the two speakers in parallel gets me 4 ohms, correct? I think that will give me the best flexibility for amplification. In WinISD, Re is set at 3.5. I used the values from the (ED Website) to derive this value. I do note that the Miscellaneous Parameter section of WinISP shows 2 voice coils in parallel with Re=3.5, when I select series for the two voice coils, then Re is increased to 14 ohm automatically. Also Bl reduces to 11.05. Are these values correct for series wiring of the voice coils or should I re-adjust B1 to 22.1? How do I then adjust the parameters to accommodate for the two drivers wired in series or does the program assume this with the num of driver field indicating two drivers? I so not see where to tell the program that two drivers are wired in series or parallel. Finally, I am better off un-checking the auto calculate feature and entering all of the discrete values from the ED specs or should I let WinISD adjust the values? Apologies in advance fir extreme newbie questions. | ||||
| | #6 | |||||||
Regarding your sub design, will you be using one EP2500 for both cabinets or a EP2500 for each cabinet? | |||||||
| | #7 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 I am looking forward to that!!! So, here is where I am at: Baseline data from Elemental Designs web site on the 19Ov.2 driver: ![]() Entering Re and BL into WinISD provides the following: ![]() Changing parallel selection for the dual voice coils to series gives the following Re and BL values, automatically: ![]() If I attempt to halve the Re value to accommodate for two drivers (each with 4 Ohm voice coils wired in series), the BL does not automatically update. So, I uncheck the calculate automatically selection, delete the entered value of BL and allow the automatic calculation of BL: ![]() As one can see the BL is now slightly different. Now I divide Re by 2 to accommodate for the parallel wiring of the two drivers (each with 4 Ohm voice coils wired in series). The resulting calculation gives: ![]() With these driver parameters entered please note the box, port, and filter parameters indicated on the following three plots of SPL, port air velocity, and group delay: ![]() ![]() ![]() Do I have all of this correct? Do my ports seem reasonably sized? I was planning to run them out of the right and left sides of the 66" wide box. I am a bit over the 17 m/s threshold at 13 Hz (calculated velocity = 19 m/s) that may cause chuffing, but any increases in port diameter or number, while reducing air velocity, are associated with an unacceptable increase in port length. I am rationalizing this velocity on the assumption that little source material will have much information at 13 Hz and with two of these bad boys in the room, I am unlikely to get near Xmax. Are the filter parameters reasonably achievable? Will this sub kick butt, ie can I expect the observed flat response from sub 15 to 80 Hz??? | ||||
| | #8 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 I almost forgot about this. I am thinking that I will have one EP2500 for each cab. Does this seem to be the most logical plan rather than use one amp for both cabinets? | ||||
| | #9 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 you'll need two ep2500s, one for each cab. if you're going ported you want the d2 so the behringer will give them ~650w each. if you go with the d4 they'll get like 1,000w each which i think is too much for them ported. | ||||
| | #10 | |||||
| Quote:
Posted via Mobile Device | |||||
| | #11 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 A couple of thoughts, just my opinion. You want loud and deep but your modeling does not reflect the subs and amps capabilities. With a pair of the subs in 21.7 cu.ft tuned to 15 hz and with 4.5 db of boost applied, the subs will handle 650 watts each. This assumes the D2 sub wired for 4 ohms and one sub to each channel of the amp. With a Hi-Pass filter applied at 16 hz the subs never exceed Xmax. Which brings us to porting. There is no issue with an air speed of 26 m/s, many a sub has been designed and built with this speed with no problems. Two six inch ports would have an air speed of 36 m/s, too high. A 10 inch diameter port 35.75 inches long would be just under 26 m/s. You could expect 124 db down to 15 hz with one cabinet. Now that's loud and deep! Should you go this route, I suggest you build one cabinet first, it may well be enough for your needs. ![]() | ||||
| | #12 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 Wow Mike. I am clearly missing something in my WinISD file of this build. As you can see from my prior posting, my specs are completely different from what you have determined. I could learn a lot by examining the file that you have made for this driver and this proposed cabinet. Is it possible for you to send them to me so that I can open them and examine them on my computer? Thanks, Geoff | ||||
| | #13 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 After thinking a bit about it, I understand the principle of keeping the two drivers independent in the cabinet and driving them from each of the channels in the EP2500. So with the D2 wired in series, I am at 4 Ohm and then driving each driver with 650 W. This is exactly what dradius had in mind. I would still like to examine the driver and project files for this build on WinISD, as I cannot generate the same graph that Mike sent in his last post, but at least a bit of the mystery is receding. Again, many thanks. Last edited by nibix kfrundi; 09-26-09 at 02:24 PM.. | ||||
| | #14 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 The file is a non auto calculate version with the parameters you listed from the E.D. website. Note that the Re stays at 3.5 ohms since each sub has its own channel at 4 ohms and the input power for both is 1300 watts. here is the file: Elemental Designs 19Ov.2 Non AC.wdr Here is the project file: E.D.19O.2 - 21.7 Cu.Ft..wpr | ||||
| | #15 | |||||
Also, while some manufacturers may do it, the last thing I would ever want to do is apply EQ boosting around the tuning region of a ported sub. Excursion is already at its greatest just above tuning, impedance is at its lowest at tuning (and cone movement is next to nothing, so the voice coil is getting pretty hot), and then the driver becomes susceptible to unloading below tuning. Not really the greatest place to apply some boosting. Mike is leading you on the right path - get increased low end output through an increase in sensitivity. You do this by using a larger enclosure. The larger enclosure also allows you to use more adequate porting. | |||||
| | #16 | |||||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 Mike, Those are very helpful. I have a few questions scattered through my ramblings below: Why do you only specify one voice coil in the driver file? I am glad that you have confirmed that the system input power on the signal tab is the power into the speaker from the amp. I found the following statement from the help file on this subject to be very confusing: Quote:
Not specifically in the help file, but accessed from here after a google search states: Quote:
With the parameters that you have worked out for the cabinet and driver, it is interesting to see how little difference appears between a sealed design and a ported design. For a sealed design, a slightly smaller box (19.6 cu ft) reduces the cone excursion to be similar to the vented design. Everything else equal the group delay falls to 40 ms at 12 Hz and the difference in SPL is a maximum of 6 dB at 16 Hz and only 2 dB at 30 Hz. I applied a 4th order low pass filter at 60 Hz to both designs as well. They look like this: ![]() What do you think is the audible nature of this difference? Again, many thanks for all of the insights. | |||||||
| | #17 | ||||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 Steve, I have read many of your posts and learned a lot from them. Thanks for weighing in. Quote:
Let's see, 40 cu ft would be 72" x 60" x 20". That might stretch the limits of practicality. Is there a blend of cabinet volume and amplifier boost that makes you more comfortable near the tuning frequency? Incidentally, the impedance and the cone excursion are the same when comparing the larger cab with no eq to the smaller cab with eq boost. Am I still risking an unloading event with the larger cab? | ||||||
| | #18 | |||||
How large an enclosure can you live with? How about 400 liters? | |||||
| | #19 | |||||
Group delay in speaker design is one thing, in subwoofers it's another story. It's not something that you would notice. I'm not able to see the graph you posted above due to a bad internet connection. As for boosting the low end, with a Hi-Pass filter you're within Xmax, cone excursion and impedance doesn't drop below 4 ohms. I don't see this being a issue with program material. Just don't play a 15 hz sine wave with 1300 watts and your sub will be fine. | |||||
| | #20 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 I should be well over that. The 21.7 cu ft design that we have been kicking around is 615 liters and the monster 40 cu ft design that I mentioned in my last post would be 1133 liters. | ||||
| | #21 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 sorry for the delayed response, it sounds like you figured it out on your own though yeah i'd give each sub its own channel from the behringer. and just to reassure you, i have the same drivers and give them 650w each ported and they are ridiculous. 4 separate boxes would allow you to put one in each corner etc. but of course it'd be more wood and work. either way i think you'll be happy. 4 of these will be awesome either way. | ||||
| | #22 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 Hey Dradius, I see that you built sonotubes. I was thinking of doing that, but rejected it so I could have a lower profile design from a depth perspective. The downside of sonotubes is that their circular cross-section means that they are equally deep and wide. I am curious about your consideration to cut your tubes down and go sealed. I recently noted that mktheater did the same thing. I do not want to go through the exercise of building vented cabinets only to decide that I want sealed. While Mike's help, I have modeled the vented and sealed cabs (see post #16 above), I have no intuition as to how they would perform/sound. Please discuss your thoughts and experience on this subject. | ||||
| | #23 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 i'm far from an expert on this stuff, so take everything i say with a grain of salt ![]() my sonos aren't equally deep and wide, they are 24" wide and 6' long. if i cut them down and sealed them, then yeah they'd be 24x24. i talked to eD and determined the d2 version is the way to go if you want ported, since 650w is about right for them to shine. however, they need much more power if you're going sealed (~1000w.) so you'd need the d4 version, which is what mktheater has done. so i'm definitely not going to seal them. the only downside to mine that i was worried about was bottoming them out, but they are tuned pretty low and i also learned my receiver (and most mid-level ones i think) won't even send a super low signal. i've had them running pretty hard and never had any issues though. i'm really not the guy to talk to as far as sealed vs. ported, i just don't know enough about it. i thought about sealing them because i was considering putting one in each corner and didn't want four 6' monsters in the room not because i prefer sealed to ported.i'd definitely determine which way you want to go so you can buy the d2 or d4 version accordingly. i'd also consider just 2 drivers and one amp to start. it might be plenty for you. and last but not least, when i bought my drivers they were $50 cheaper than they are now. i really like them, but am annoyed they keep raising prices on all their stuff. | ||||
| | #24 | |||||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 If they are standing upright, then these are 24" deep and 24" wide - that is what I meant in my comments. I am looking for 18" deep with a big cab and the possibility of mounting an 18" driver, this eliminates the sonotube concept and leads to a traditional box. Quote:
![]() Quote:
Look at Soundsplinter and the RL-p18. How screwed up is that company that they cannot deliver a core product for at least 4 months??? ![]() | |||||||
| | #25 | ||||
| Re: Designing Dual 18" vented boxes: ED19O.2 vs. SS RL-p18 My 2 cents here. The RLP-18 is a better driver but it's also a lot more expensive and unavailable. Scratch it from the list. Each enclosure at 2 ED 190v2's per cab should get an EP2500. I'd get the D4 drivers and wire each cab to 4ohm mono to get the most power from the amp. Those drivers have quite a bit left after 22mm xmax is met and won't bottom out until after 30mm one way. Also with thermal losses and suspension tightening it'll take more power than the sims indicate to bottom the out. The other idea I have is the Mal-X 21" driver that just came out. Have you thought about using one of these per cab instead of 2 18's? It'd be a bit more expensive than 2 190v2's, but it should be impressive in a big ported cab. | ||||
