Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Combo! Sealed Sub below Mains
Discuss Combo! Sealed Sub below Mains in the DIY Speakers and Subwoofers forum; Combo! Sealed Sub below Mains I'm going to try double checking the modeling of the tritrix sealed for power handling as I didn't get the ...
Views: 759 - Replies: 43
Old 10-12-09, 05:23 PM   #26
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
  ironglen is online now
Re: Combo! Sealed Sub below Mains
I'm going to try double checking the modeling of the tritrix sealed for power handling as I didn't get the value you did-it surpassed the 2.5mm xmax around 80-110hz, at a much lower input than advertised. When I modeled ported, performance was really only affected below 80hz and even then power handling wasn't as advertised, so I'll have to check again.
Based on what I've got so far, my plan would likely be to use a peerless mid/dayton tweeter small sealed setup, and if it failed, go to the tritrix kit. My design will use a simple flat baffle that I can easily change if needed, volume sealed is very forgiving for 5.25 drivers, so I'd be out $120 or so if I have to go to the tritrix configuration. A better plan than $600+, eh?
Or maybe I should pick up the tritrix kit now- then add the 4 peerless drivers for $50 (to my door) for a total of $170 plus any xover mods I add. I'd be able to do A-B comparisons as well
Old 10-12-09, 07:14 PM   #27
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
A setback to option B is the tritrix now uses dual 4ohm mids, whereas it previously used dual 8 ohm mids in the triune format. My amps can handle the triune format's net 4 ohms no problem, however, the peerless mids are dual 8 ohm drivers, so I might ask if they can package the tritrix as the old triune for me, I hope
Old 10-12-09, 08:33 PM   #28
Alias: Matt
evilskillit's Avatar
Loc: USA, Kansas City, MO
User: #26820
Since: Oct 2008
  evilskillit is online now
Let me know how it worked out. I had a set of 3way galaxy speakers that had a tweet, a mid and a 12" woofer. The woofer surround rotted out. Well I figure any 12 should work right? And any new 12 should sound better than a 20 year old woofer did so I bought some random 12" goldwood woofer.
The first one was the wrong impedence, it sounded horrible. Then I got a 4 ohm, at least it was loud enough now, but it still sounded like poopoo. I ended up shoving the speakers into the attic and trying to forget about them. Then one day I was cleaning the attic and saw them. Took out the perfeclty good but bad sounding 12s, modeled them in Winisd and forced them to be the subs in my 2 channel stereo set up. They sound great now. But in those galaxys, they were awful. All shrill, no bass at all
Old 10-12-09, 09:38 PM   #29
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
I'm following you-I've modeled both sets of 5.25's in identical sealed volume, with the lower freq response curve almost identical given the same hpf from my preamp, only output being different. Both speakers will be well within their higher freq limit. The baffles on the tritrix is almost identical to the baffle from an nht speaker the peerless 5.25's were used, so the only real difference between the two should be the crossover, we'll see
The fine print on the PE tritrix kit page allows comparable part substitutions, and 4 and 8 ohm drivers are priced the same!
Old 10-12-09, 11:51 PM   #30
Alias: Matt
User: #26820
Since: Oct 2008
Awesome, that works out well for you, good luck with your project and let us all know how it works out for you. I can't wait to see the results
Old 10-15-09, 01:36 AM   #31
Alias: Ed Alexander
Loc: Tempe AZ
User: #20949
Since: May 2008
  EdmundGTP is offline
I have a pair of Klipsch KSP-400's which look to be essentially what you're trying to accomplish.
Word of caution about combining subs with your two main speakers. Everyone knows that positioning of your main (stereo) speakers relative to your listening position (sweet spot) is critical for imaging and soundstage etc. And once you figure out those relative positions they're pretty much set in stone (or carpet). There is a major draw back to having your sub system co-exist in position with your main speakers, and that is the fact that you won't be able move the subs to a point in the room where THEY sound the best. They're "stuck" where the mains are and wherever that ends up being could be a spot which negatively impacts your bass response. I have a very odd shaped room and in order to get the powered subs in my KSP towers to sound decent at my listening position, it required significant equalizing. Conversely, if I had the ability to move the sub(s) independently of the mains, shifting them just a few feet along one of the walls would have cut my EQ needs to a bare minimum or perhaps even made them nonexistent.
Just something to consider.
Old 10-15-09, 02:07 AM   #32
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
That's an excellent point. I'm hoping a couple features will help with those issues: I'm using 12" subs that can produce plenty of spl since they likely won't benefit from good corner loading and I'm also (shh, top secret) porting the sub chamber with 2 ports, with a 25hz tune, 18hz tune, and a usable sealed mode so I have some control on response and output- hopefully it will be enough! I'm hoping for the best as I'll have ~$400 tied up in the complete passive speaker, plus the 285w/ch sub amp for $120 for just over $500 for the pair.
Old 10-15-09, 02:40 AM   #33
Alias: Ed Alexander
Loc: Tempe AZ
User: #20949
Since: May 2008
You might get lucky. Though each of the subs will probably produce suitable SPL across the sub frequency range, I suspect you might run into trouble with certain frequencies canceling each other out or reinforcing each other excessively. Again this is highly dependent on location and room geometry. In my particular case I had a nasty dip at about 42hz and at 75hz, but a significant spike around 60hz as measured at the listening position. This was very noticeable by ear alone, and at the same time I could walk to other places in the room where those peaks/dips weren't audibly obvious at all. Either way, I wish ya good luck. It's a legit project, and I hope it turns out well!
Old 10-15-09, 10:01 AM   #34
Alias: Matt
User: #26820
Since: Oct 2008
Yeah, with stereo subs, especially as speaker stands you sort of have a place picked out and hopefully they work there. I did a bit of reading and moved mine around my music room till I ended up with one against the back wall directly behind me, and one against the wall directly in front of me, myself being centered between the two. It sounds pretty flat, tho I have not measured them.
Old 10-15-09, 04:50 PM   #35
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
Those are very nice towers, and a nice layout in whole. My design will use a down-firing driver-hope that helps with the evenness.
Well, after looking extensively-the tritrix kit is a real recession buster, just as advertised; I've got a kit on the way I hope to get to this sooner than later. With a footprint of only 14.5" diameter (which will be tight with the 12"), I'll FIND a place to put these if they turn out nice
Old 10-15-09, 07:51 PM   #36
Alias: Matt
User: #26820
Since: Oct 2008
Yeah the Tritrix kit is currently the deal of the century. I would like something a bit more reference level myself but you can't beat what you get for the price. As for doing a down firing sub that has its own set of issues, you lose excursion to gravity so its not ideal, plus I think it causes the suspension to wear out faster, after all its never recommended to store speakers flat. But some drivers handle it better than others, everyone here can help with that too. Either way I can't wait to see some pics of how it turns out.
Old 11-01-09, 05:19 PM   #37
Alias: Tad Slomski
Loc: Brillion, WI
User: #3391
Since: Oct 2006
  Tsloms is offline
If you currently have a sub you should probably set it in each of the prospective locations just to make sure that you do not have any bad room modes in those locations. It is possible that those locations could be bad for subs. Manufacturers integrate the subs into mains simply for convenience and not necessarily sound quality.
Old 11-01-09, 05:35 PM   #38
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
I'm re-thinking the whole project: Thanks to all of you guys with the VERY helpful suggestions and feedback. Hmm, what am I gonna do NOW???
Old 11-01-09, 07:41 PM   #39
Alias: Matt
User: #26820
Since: Oct 2008
I don't know, what ARE you going to do now? What parameters have changed and what new thing are you considering?
Old 11-03-09, 01:11 AM   #40
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
Looking at my system, and reading a point by another member, I realize my mains are by far my weakest link. I have power to spare, and I would want a pair that could handle house-filling spl levels, but I'm not really sure what I need vs want, but I could: buy a pair of towers like these or these, or maybe sell my sole for these or my soul (all $2000 worth)for these. Or I could buy up several anarchy mids and plan to build a TMM or TMMM set once some plans are devised (maybe IF someone devised-no guarantee).
Old 11-03-09, 01:47 AM   #41
Alias: Matt
User: #26820
Since: Oct 2008
If you could swing 500-700 you could build a pair of these. I bet they rock the house pretty good.
Total woofage four 8" woofers and two 6" mids. Should offer plenty of output. High quality design too.
http://www.htguide.com/forum/showthread.php4?t=15323
Old 11-03-09, 01:56 AM   #42
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
That looks NICE-I'll take a further look. Not sure my craftmanship will even come close-I'll have to go gloss black or veneer if I build.
Old 11-03-09, 01:03 PM   #43
Alias: Matt
User: #26820
Since: Oct 2008
Actually the pictured speaker IS veneered I belive, with a gloss black back and top. If you check out the build thread you'll see more pictures.
Old 11-03-09, 02:29 PM   #44
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
I don't know which thread it is- it looked like the thread had dozens of pages
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
combo!, mains, sealed
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
