| DIY Subwoofers - Sealed and Ported Just Purchased eD 19Ov.2 Now What?Discuss Just Purchased eD 19Ov.2 Now What? in the DIY Speakers and Subwoofers forum; Just Purchased eD 19Ov.2 Now What? The sub will loosen up with use and you'll get more low end output. The subs tuning is 21 hz, ... |
Views: 343 - Replies: 30
| | #26 | ||||
| Re: Just Purchased eD 19Ov.2 Now What? The sub will loosen up with use and you'll get more low end output. The subs tuning is 21 hz, a HPF at 17 -18 hz would be best. | ||||
| | #27 | ||||
| Re: Just Purchased eD 19Ov.2 Now What? So just set the subsonic filter to 17-18 and leave everything else at default? I have been playing around with it and have noticed a difference. Last edited by vilacr; 11-06-09 at 10:36 PM.. | ||||
| | #28 | ||||
| Re: Just Purchased eD 19Ov.2 Now What? I'm not familair with the eQ.2 Set it where it sounds best to you. | ||||
| | #29 | ||||
| Re: Just Purchased eD 19Ov.2 Now What? I am getting the hang of the eQ.2 now,but I have another dilemma. I tried to paint birch plywood piano black (used primer as well) and screwed it up bigtime. Then ,my brilliant self , decided to sand it down a bit and use truck bedliner another big mistake. My question now is what can I use to cover my disastrous paint job but floor shaking sub? I need something like maybe veneer or something else. Let me know. | ||||
| | #30 | ||||
| Re: Just Purchased eD 19Ov.2 Now What? What went wrong with the truck bedliner? | ||||
