Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
My RSS390HF Build - 4 Boxes in Satin Black
Discuss My RSS390HF Build - 4 Boxes in Satin Black in the DIY Speakers and Subwoofers forum; My RSS390HF Build - 4 Boxes in Satin Black OK - First off thanks to anybody here who has provided me advice and to all of you who have ...
Views: 247 - Replies: 10
Old 11-02-09, 05:17 PM   #1
Alias: Josh
GSX-R_Rider's Avatar
Loc: Maine
User: #44244
Since: Nov 2009
  GSX-R_Rider is offline
OK - First off thanks to anybody here who has provided me advice and to all of you who have posted your own DIY sub pics in the past. It seems that for the past 6 months or so I have spent an inordinate amount of time on this forum as well as other AV Forums and have gained an amazing amount of great information which inspired me to finally move forward and build my own DIY Sub Boxes. Although I am not entirely new to working with wood I was initially uncertain if I could build something with satisfactory fit & finish to "pass the grade" and look like it belonged in my home.
My goals were pretty simple.....this system will occupy my own personal music room in my house where I keep my acoustic drum kit. I wanted to build an 80% music oriented system that would sound BOTH good and very loud. I would like to have the option to play my drumkit without headphones and instead use the speakers to "play along" with the drums and I knew it would take a lot of both watts and speaker to accomplish this goal without straining the system. I decided on the Dayton RSS390HF based on sound quality, value, positive feedback and lastly for my own personal preference of building a large sealed sub.
The boxes are 21.75"x21"x21.75" constructed out of 3/4" MDF. The front baffle is 1.5" and the top of the boxes are also 1.5" thick. I used 2x4's for bracing and a full roll of R13 (I think) fiberglass insulation which was 3.5" thick to dampen the box and attached it to all of the interior walls. I get an internal volume of approximately 4.5 cubic feet when I account for bracing and stuffing.
The primer is Zinsser BIN (2 Coats rolled with 1/4" nap roller). The satin black coat is Sherwin Williams Duration Acrylic Latex (4 coats rolled with 6" foam roller) and finally I sealed the S&W satin black with Minwax Polycrylic Satin using a Purdy 3" brush and light coats. All coats of primer, acrylic and polycrylic were sanded lightly in between coats using 220 grit sandpaper.
The only part of the finish I would do differently if I could go back is that I used MH Ready Patch Professional Spackling (black and orange can) on the outside exposed edges of the front baffle and to fill in some of the seams where the MDF met up on the edges on the outside of the box. The spackling dried extremely hard and quickly but my mistake was not sanding it down far enough. Although it looked to my eye and felt to my hand to be smooth prior to painting you can see some of the edges on the painted boxes. It isn't disastrous by any means but I should have spent a little more time feathering the edges of the spackling to get the perfect finish I was hoping for.
Other than that I am pretty happy with the results although I have yet to hook the boxes up yet and listen to them. Currently they are awaiting the amps and misc gear I have to order in the next few weeks to finish out what I need to start listening to music. I plan on buying a couple of EP4000s to power everything and I already have purchased a pair of Behringer B2031P studio monitors (pictured) to handle the mid and high range. I am most likely going to use a Yamaha RX-V665 as a pre-amp and 5.1 processor as well and a DCX2496 for active xover and eq duties. A 42" Panasonic Viera Plasma will round out the system which will be used mainly for PS3 duty and watching BluRay movies. Lastly over the weekend I pulled the trigger on a center channel and surrounds from The Speaker Company (P5-PR 5.25"surrounds and TC2 center channel). Since this system is not my "main" system at home I tried to make purchasing decisions around high value yet high quality and performing equipment. Hopefully by the time Xmas rolls around I will have some pics of the completed system I can post here as well as listening impressions. Thanks again for this forum - the info is invaluable!
The pics below show the speakers in the room they will be placed in but they are not permanently situated yet in the photos....I have some reorganization to do first before they are permanently placed.
Old 11-02-09, 06:46 PM   #2
Alias: Matt
evilskillit's Avatar
Loc: USA, Kansas City, MO
User: #26820
Since: Oct 2008
  evilskillit is online now
Re: My RSS390HF Build - 4 Boxes in Satin Black
Wow, congradulations. I bet those sound awesome. I built a ported RSS315HF for a friend and just one of those little things really plays loud and low. I can't imagine how cool for of the 15" version must sound.
The Dayton Reference 15" drivers in a sealed configuration should sound very musical and should make you very happy. What sort of music are you going to be listening to on these? Make sure and let us know how they sound when you hook em up? I can't wait to find out.
Old 11-02-09, 06:49 PM   #3
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Thread moved to DIY Subwoofers - Sealed and Ported.
Nice work on the cabinets! With the EP4000's you'll have lots of power. Let us know how they sound when you get them fired up.
We're all in this together!
Members DIY Subwoofer Database
Old 11-02-09, 06:54 PM   #4
Alias: Josh
Loc: Maine
User: #44244
Since: Nov 2009
Yes I did choose these subs mainly on the strength of their SQ and ability to reproduce music. I will also use them for some home theater and PS3 duty but music was the main priority. I have yet to listen to them yet as I need to now order the ep4000s and a couple of other odds and ends - I decided to build the subs first because I wanted to get the hard part out of the way first...ordering new gear is the fun part!
evilskillit wrote: View Post
I would guess due to the fact that you are going with sealed enclosures and the Dayton Reference subs that you're going mainly for music and sound quality? What music will you be listening to on these and what are your impressions?
Posted via Mobile Device
Old 11-02-09, 07:01 PM   #5
Alias: Josh
Loc: Maine
User: #44244
Since: Nov 2009
Oh and sorry but forgot to mention in my last post....regarding the music I will listen to with this system. I have a collection that spans from Big Band and 60s R&B all the way up to a current and extensive collection of Swedish extreme metal so basically I wanted a system that can cover ALL musical bases. Since I am a musician I constantly seek out new music and genres to try to learn from so I didn't design this system for any one genre of music but I did definitely want it to be able to play very loud and clear with great SQ......
Old 11-02-09, 07:41 PM   #6
Alias: Josh
Loc: Maine
User: #44244
Since: Nov 2009
Also FWIW: I used a Jasper Jig for all circle cutting duty mounted to a Craftsman Plunge Router (on sale for around $80 and worked great). I used a Craftsman carbide 1/4" bit to cut the circles out and an Amana carbide tipped 5/8" rabbeting bit I found on sale for $7 to cut the recesses. As a router newbie I have to say I found the Craftsman and Jasper combo almost idiot proof.
To make life easier I had Lowe's cut the 3/4" mdf into pre-measured "slabs" which made them more manageable to handle and cut to size at home. I used a Milwaukee circular saw and a steady hand/eye to make my cuts at home. I also found a large 24" framing square to be a life-saver on this project. Lastly I used Titebond 3 glue (and a lot of it) as well as 1.5" sheetrock screws which I countersunk and filled with Elmer's wood filler.
My next project will most likely be on a smaller scale! Doing 4 big boxes like this was exhausting but fun. I want my next project to be a little more manageable in size but I want to learn more about finishing techniques and create something that really looks high end and unique. I thought about maybe trying the Dayton D3 loudspeakers next but am still undecided.
Old 11-02-09, 07:59 PM   #7
Alias: Matt
User: #26820
Since: Oct 2008
Nice you'll have to rock some of In Flames - Reroute to Remain for metal its got some pretty nice presence in the drums. I bet that'll be a lot of fun to listen to, maybe Trigger especially.
Old 11-12-09, 01:00 AM   #8
Alias: James
Loc: Boise, ID
User: #21947
Since: Jun 2008
  Guiria is online now
Those boxes look great. Finishing the box is always the biggest pain for me. I appreciate the detailed post because your steps are well outlined that I think next time I build something I will follow a similar method with roll on primer, paint, etc instead of doing everything with spray paint. Overall very impressive, I would love to hear how that sounds.
Old 11-12-09, 04:05 AM   #9
Alias: Josh
Loc: Maine
User: #44244
Since: Nov 2009
Thank you very much. Just make sure if you roll the paint to go with a 1/4" nap roller for the primer coat (and 1/4" nap ok for finish coat too). The foam roller worked well for the finish coat but I saw other boxes online that used a 1/4" nap roller for the final coat with amazing results. The Polycrylic final step achieved best results with a brush as I read that the foam roller would introduce air bubbles to the clear coat and would not dry to a nice super smooth finish.
Spray paint just wasn't an option for me as it would have cost too much not to mention left an awful smell in my house compared to rolling the paint.
Guiria wrote: View Post
Old 11-12-09, 03:24 PM   #10
Alias: Robert
Loc: Ny, NY
User: #17
  Exocer is offline
Excellent job! I love my single sealed RSS390 with only 450watts going to it, VERY musical in my 4ft^3 sealed box. You will love it.
4 is just awesome! Can't wait to hear your thoughts on these.
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
Old 11-12-09, 03:31 PM   #11
Alias: Josh
Loc: Maine
User: #44244
Since: Nov 2009
Thanks - yeah I am beyond excited to hear these play - kills me to have them sitting in my drum room waiting to be hooked up.
I am going to try and work some kind of package deal with zzounds.com to buy 2 ep4000s and a dcx2496 as an all in one package deal. Once that order goes through I can start wiring the system together. Once it is all put together I will post a couple more pics plus my listening impressions.
I also just picked up a Speaker Company center channel (forgot model # but the big one with the dual 5.25" alum woofers) as well as a pair of their bookshelf 5.25" speakers to use for surround sound. The amps and xover unit are really the last pieces to order along with a pre-amp which I am leaning towards another Yamaha rx-v665. Hoping by xmas (if not sooner) the whole thing will be in place.
Exocer wrote: View Post
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
rss390hf
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
