Sealed Box, Plate Amp, how to install? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss Sealed Box, Plate Amp, how to install? in the DIY Speakers and Subwoofers forum; Sealed Box, Plate Amp, how to install? I just finished making a sealed box with a speaker I had laying around. (Cheap's good, Free is better) and ...
Old 06-13-07, 05:56 PM   #1 (Link)
New Member
Alias: tim
User: #9366
Since: Jun 2007
sherlocktk is offline
I just finished making a sealed box with a speaker I had laying around. (Cheap's good, Free is better) and I was running it off an old amplifier for bookshelf speakers. Although it sounds great, the amp just does not fit in anywhere, so I bought a plate amp from parts express, and it got delivered today. When I mount, do I just cut a hole and screw it in, or should i build a mini box, mount on the inside and screw to existing MDF? (here are pics to illustrate?)
Option A.
Option B.
Old 06-13-07, 06:01 PM   #2 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Re: Sealed Box, Plate Amp, how to install?
Just cut a hole and screw it in. The amp should have a gasket built in, if not use felt around the opening for a good seal.
Old 06-14-07, 02:07 AM   #3 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
I'm doing the same thing -- building a sub with a plate amp. I've cut a hole and will be using some closed cell foam to get a good airtight seal around it.
You just have to remember to take into account the interior volume you'll be using with your plate amp in the design of the plate amp.
JCD
Old 06-14-07, 08:33 AM   #4 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
JCD wrote: View Post
JCD
Personally I don't think you need to worry about the internal volume of the plate amp...it is really neglegable. I've never seen anyone take that into consideration unless they actually build the box around it.
Old 06-14-07, 10:56 AM   #5 (Link)
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
User: #53
JCD is offline
Darren wrote: View Post
It is small.. and probably doesn't make that much of a difference.. but I'm learning I'm a little more anal than I thought I was. I think in the end, I added about 1/2" to the length of the box to compensate for the space used.
JCD
Old 06-14-07, 11:11 AM   #6 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Being anal ain't all that bad. I'm accused of it myself most of the time!
Old 06-14-07, 08:55 PM   #7 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
I think we all are or we probably would'int be on all these Audio/Video fourms.
Old 06-15-07, 11:09 AM   #8 (Link)
New Member
Alias: tim
User: #9366
Since: Jun 2007
So I just busted out the sawzall and cut a hole and screwed the plate amp in. My rew graph did not change at all from when I had the external amp, and the plate amp, so I guess it really is negligable.
To check for leaks, I put the sub on 15 hz, and turn it up so the speaker is moving good, I could not feel any leaks around the plate amp, (or anywehre else) so I think all is well. Thanks for all the suggestions.
Old 06-15-07, 12:49 PM   #9 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Sweet, sounds like you are good to go.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
Rythmik Audio A350 Plate Amp woozy_one Classifieds - Audio Equipment 5 07-24-07 12:35 PM
Cutout Dimensions for BASH 300W Plate Amp from PE Wildcard26 DIY Subwoofers 2 06-14-07 05:51 PM
WTB: Plate\Pro amp for subs (Low watt) mgboy Classifieds - Audio Equipment 1 04-03-07 06:06 PM
REL Britannia B1 Amp Plate. t0mmyt DIY Subwoofers 10 10-06-06 03:38 PM
flush fit sub install bobgenie Home Audio Acoustics 7 07-29-06 11:55 PM
Mach 5 Audio
