| DIY Subwoofers - Sealed and Ported Decided: sonosub, Help!Discuss Decided: sonosub, Help! in the DIY Speakers and Subwoofers forum; Decided: sonosub, Help! I am gonna build a sonosub! I have a crown cs2000 and a bfd on the way. I have steered ... |
| | #1 (Link) | |||
| Decided: sonosub, Help! I am gonna build a sonosub! I have a crown cs2000 and a bfd on the way. I have steered away from ib (wife wasn't happy about cutting the ceiling). So far i'm looking at 320L, 24" dia. 14.5 htz tune (per steve). any other suggestions? my driver, as of right now will be a css sdx15 or a tc2000 15. or would I be better with an 18". like ficar or mach5? if 15 is best, then is the sdx a better driver? both are the same price delivered until monday. I'm ordering tomorrow. what benefits would I get with an 18 over a 15? I know I know, I have alot of questions but I want to do it right. | |||
| | #2 (Link) | |||
| Re: Decided: sonosub, Help! If you don't mind the price and enclosure size increase, I'd definitely go with an 18". You'd be going from 320 effective liters to 650 though, it's a respectable difference ![]() As for the 15s, the SDX uses XBL^2, a low distortion motor technology, and should have lower inductance than the TC. Looking at Ilkka's measurements, the high inductance of the TC is its glaring weakpoint, causing a rise in distortion above 60hz. | |||
| | #3 (Link) | ||||
| Re: Decided: sonosub, Help! Quote:
| | #4 (Link) | |||
| Re: Decided: sonosub, Help! Well, I found some sonotube by the foot here in houston(white cap const.). 7.50 a foot, 35 bucks for the 24 by 50"! That'll work. Hey steve, I have a sheet of 3/4" birch plywood, would that work? This way I could stain it. Oh, the sdx15 is on it's way. I hope this thing will outdo my hsu 3.3 and svs 25-31. Last edited by lvisneau; 08-06-07 at 03:46 PM. | |||
| | #5 (Link) | ||||
brucek | ||||
| | #8 (Link) | |||
| Re: Decided: sonosub, Help! ok, is it possible for me to use 4" or 8" instead of 6? the only 6 i've been able to find here seems too heavy. It's around 20#. I did a cutout in the top recess and even though it is tight, I think that no matter what glue I use the port will come loose. the 6" i have is industrial grade pvc 1/4" thick. Is there a way to use this or should I rethink this? Home depot has 4" pvc and 8" sono but no 6". | |||
| | #12 (Link) | ||||
the const. supply co. did not have any either. maybe i'll contact them today to see if I can order some. | ||||
| | #18 (Link) | |||
| Re: Decided: sonosub, Help! Won't be long now. You'll soon find those previously mentioned commercial subs to be nothing more than children's toys If you didn't already seal in the top cap, and didn't flush mount the port to the very top of the top cap, you would benefit from creating a roundover to act as a flare. | |||
| | #19 (Link) | ||||
| Re: Decided: sonosub, Help! Hey another sono build!.. nice to see and looking good. Quote:
Hey Steve. Yeah if a guy has the space and inclination to build one, it's quite the sub! So what driver was finally decided upon?.. SDX? | ||||
| | #20 (Link) | |||
| Re: Decided: sonosub, Help! Yeah, I already flush mounted it. will this be a bad thing? should I redo it? I have another 6" piece. If it's just a small deal I won't sweat it. Im gonna install the wire lugs and wrap the port today, I'm still waiting on the driver. | |||
| | #21 (Link) | |||
| Re: Decided: sonosub, Help! If you choose? a guy can build inner flares for pennies not counting the bit of course. Anything under 3/4 round really isn't worth it. Should you redo it though?.. not necessarily imo. It takes a lot of air to cause a 6" port to chuff, many of us like to do it none the same. This is three of the inner flares I spoke of. ![]() | |||
