want to make llt sonosub - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss want to make llt sonosub in the DIY Speakers and Subwoofers forum; want to make llt sonosub I just completed a sub based on the ardrie sealed box (18X18X18) for a tempest driver. works very nice although ...
Old 08-29-07, 04:39 PM   #1 (Link)
New Member
Alias: vich
Loc: calgary, alberta, canada
User: #11157
Since: Aug 2007
old_joe is offline
I just completed a sub based on the ardrie sealed box (18X18X18) for a tempest driver. works very nice although it is better for music. and fits the WAF very well being small. I am in the planning stage for a large sub for when i get the basement home theater finished. As I have the OK from the Captain to go any size I want I was thinking on a 24" sonotube and using the 15" tempest in that. Modeling doesnt seem to show any advantage to making it tall but why not? If I get the gist of TTL I should be able to go 60" between endcaps and use a 6" port tuned to below 15 10 - 12? ,
that gives me 444l without accounting for port size. I have a 8 foot ceiling and like I said size is not an issue.
thanks for any input
old joe
Old 08-29-07, 10:34 PM   #2 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
Re: want to make llt sonosub
I'd use something better than the Tempest if possible. A 15" driver in a LLT typically won't want to see any more than 320 liters - there isn't much to gain beyond that. An 18" can use 600-700 liters. Not many options either way in the 450 liter range, at least not that I know of.
Old 08-30-07, 11:51 AM   #3 (Link)
New Member
Alias: vich
User: #11157
Since: Aug 2007
old_joe is offline
yeah maybe im getting ahead of myself. I will probaly go with patmans sonotube sub 2. "http://www.io.com/~patman/sunosub2.html"
and take a look round for an 18" driver. I saw a site where the guy did a tv platform with 4 drivers. It was huge but because the tv sat on it it blended in.
thanks for the sanity check.
vic
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
Sonosub LLT on its side? coctostan DIY Subwoofers - Sealed and Ported 14 09-13-07 09:00 AM
Do they make this kind of cable? _brad_ REW Forum 1 04-04-07 08:29 AM
Now You Can Make Your Own Headphone Amp on Squidoo geekwithfamily Home Theater, Audio and Video News 0 10-28-06 11:40 AM
Make your own component video switch HDBeat Home Theater, Audio and Video News 0 09-05-06 09:40 PM
Do cables make a difference? Roger Home Theater, Audio and Video News 0 05-19-06 08:13 AM
Mach 5 Audio
