Input needed (Dayton RSS315HF-4 12" sub) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss Input needed (Dayton RSS315HF-4 12" sub) in the DIY Speakers and Subwoofers forum; Input needed (Dayton RSS315HF-4 12" sub) -------------------------------------------------------------------------------- I'm in the process of building a powered sub for my system.I am more of a music lover but ...
Old 09-28-07, 02:31 PM   #1 (Link)
New Member
Alias: Music trini
Loc: Trinidad,West indies
User: #11949
Since: Sep 2007
haydenx is offline
Post Input needed (Dayton RSS315HF-4 12" sub)
I'm in the process of building a powered sub for my system.I am more of a music lover but watch a few movies once in a while. I whant the sub to be just as good for movies as it is for music.
After some research I came up with the decision to use the Dayton RSS315HF-4 Driver and the Oaudio 500w BASH Subwoofer Amplifier.
I used WINISD Alpha to simulate a design and after different designs I decieded to use a 4.525 ft3 ported enclosure and a box tuning of 20.48 HZ using a 4"X14.77 double flared precision port.Tripple internal brace and port/driver displacement compensated for.Any reccomemdation will be appreciated
Old 10-22-07, 12:54 AM   #2 (Link)
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
WillyD is offline
Re: Input needed (Dayton RSS315HF-4 12" sub)
Good choice of driver!
And that amp is a good one, but its not exactly necessary. The subsonic filter has a bit of boost to it.
I like the 350W amp here, which has a changeable subsonic filter (the 20Hz Q=.6 setting would be good).
http://www.rythmikaudio.com/amplifiers.html
Or even the 300W amp at Oaudio.
But 4.5ft^3 and the precision port are good to go with!
Old 10-22-07, 07:16 PM   #3 (Link)
New Member
Alias: Music trini
User: #11949
Since: Sep 2007
haydenx is offline
which is the better of the two amps?
Old 10-23-07, 12:04 AM   #4 (Link)
Alias: Warner
User: #4451
Since: Nov 2006
warnerwh is offline
Very many people here use Pro Audio amps like the Behringer 2500. It has lots of power and is under 300 bucks. Only downside is a noisy fan but that's a cheap and easy fix. Considering the price it's a steal. Another thing I like is that it's not mounted to our bad *** subwoofer.
If I were you I'd use the 15" RS 390HiFi and you really need 2. You get far more for your money. Any subwoofer that is to do any HT duty needs to be at least a 15" serious duty type. I say this because I just built a single driver sub with the RL-P 15". It is "adequate". I mean it does it's job, shakes the entire house and scares you and moves you.
Our living room is only 12x20 opening into our dining room. If you have a large space that means more driver and power.
I read in another thread TC Sounds still has a 12" driver with 20mm Xmax.
The 12" RS driver is an excellent driver however I feel that driver is inadequate for the job big time.
Old 10-24-07, 08:42 PM   #5 (Link)
Alias: Brent
Loc: Wilmington, NC
brent_s's Avatar
User: #7037
brent_s is offline
Haydenx, you might want to consider a smaller box or lower tune to get more roll off on the bottom end. My model says your proposed alignment will be about 1.5db down at 20hz with an f3 at 18hz. However, s/w models assume no room gain. Depending on room placement, I've measured 6-10db of gain at 20hz in my 24x16x9 dedicated room as compared to the models. With your alignment, I'd essentially have a 10db peak at 20hz that probably starts rising further up in the 30s somewhere. That type of boost may be something you prefer, but many would consider it a bloated sounding bottom end.
Is your residential construction the poured concrete or concrete block like I observed in St. Lucia? If so, I would expect it to more efficiently reinforce gain than standard US drywall construction.
Food for thought.
-Brent
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
New Dayton (small) power amp mgboy DIY Subwoofers 2 09-24-07 10:35 PM
12" Pioneer VS. 15" Dayton mgboy DIY Subwoofers 3 02-09-07 02:08 PM
Dayton Rs28a on sale again Exocer DIY Speakers 0 11-04-06 01:52 AM
New Products, your input needed! Brian Bunge DIY Speakers 14 10-31-06 02:59 PM
Input -level setting "approved DVDs"? Greybeard191 REW Forum 3 09-13-06 10:14 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
