Sonosub Baseplate distance from sub? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss Sonosub Baseplate distance from sub? in the DIY Speakers and Subwoofers forum; Sonosub Baseplate distance from sub? I'm building two down firing 24 inch sonosubs with 15 inch subwoofers and my question is what's a good general ...
Old 09-01-07, 02:38 PM   #1 (Link)
Alias: jake
User: #10705
Since: Aug 2007
  ramchip007 is offline
I'm building two down firing 24 inch sonosubs with 15 inch subwoofers and my question is what's a good general distance The base plate should be mounted away from the sub? I was guessing around 6 inches, but I don't have much ceiling height, and I don't want to sacrifice any output , thank you
Old 09-01-07, 02:51 PM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Re: Sonosub Baseplate distance from sub?
3 to 4 inches is common. I did 4 inches on twin Shiva sonotubes.
Old 09-01-07, 03:21 PM   #3 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is offline
Yeah, 4" should be fine with a 15".
Old 09-01-07, 05:15 PM   #4 (Link)
Alias: jake
User: #10705
Since: Aug 2007
thanks, time to get the brad nailer.
Old 09-01-07, 10:55 PM   #5 (Link)
Alias: John
Loc: southern new jersey
User: #7732
Since: Mar 2007
  JDRoberts is offline
I used 5" on my 24" sono,seems to work good.
Old 09-01-07, 11:55 PM   #6 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
  Hakka is offline
The surface area of the opening between the endcap and baseplate should be at least equal to the surface area of the driver.
Hakka.
Old 11-29-07, 10:37 AM   #7 (Link)
Alias: James
Loc: somers, ny
User: #13842
Since: Nov 2007
  jr1414 is offline
I'm considering building a sonosub now as well, but was wondering if there is more of a modeled solution to this dimension. I'm sure as you get closer to the driver there is more of a tendency for the air between to act as an "air spring" and somewhat dampen the driver.
When you say the surface area of the opening, are you refering to the cylindrical section between the endcap and baseplate? For a 15" driver this distance between the endcap and baseplate would be approximately 3.75". Yet people seem to be more commonly using 5" in this situation.
Anyone else have a more scientific solution to this question?
Old 11-29-07, 11:23 AM   #8 (Link)
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
  Warpdrv is online now
I was also curious of this calculation...
If I was building my boxes 15" TC2K in a downfiring scenario, with my boxes being 26" W x 36" L, could I actually go with a shorter height... like 3" or even less?
Old 11-29-07, 04:08 PM   #9 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
  Warmon is offline
I asked a similar question in the AVS forum when building my down fired subs. I believe the formula is min opening = [Xmax*2] x SD. This represents the volume of air of the cone fully retracted to fully protracted. If it can't push this volume of air unrestricted, it will act like a bandpass enclosure. You should be safe using 15 for SD and just being sure you've got the min sq inches of volume underneath. Three inches ought to be plenty.
Warmon - "know what I mean Vern"
Old 12-02-07, 07:19 PM   #10 (Link)
Alias: Collo
Loc: Newcastle, Australia
User: #5027
Since: Dec 2006
  collo is offline
I've been meaning to write this up on the sonosub.exe page
The short answer...
gap = nominal diameter / 4 for most drivers or
gap = nominal diameter / 3 for high excursion drivers
The drawing....
The principle....
Air movement generated by the driver shouldn't encounter any reduction in the CSA through which it has to flow
The proof....
The smallest area is represented by the green cylinder, and has a total area of:
gap * circumference = gap * pi * (nominal diameter)
This must equal the Sd of the driver, or in our example, pi * (nominal dia / 2)^2
So ...
gap * pi * (nominal diameter) = pi * (nominal dia / 2)^2
dividing both sides by pi...
gap * (nominal diameter) = (nominal diameter^2) / 4
dividing both sides by nominal diameter...
gap = (nominal diameter) / 4
You could go more accurate by calculating actual diameter from Sd, and factoring in the height of the surround vs driver rebate depth, but this method is going to be fairly close.
If you have a driver with a large Xmax, you would build a bit of leeway in by dividing by 3 instead of 4
This would give you.....
A 10inch driver wants between 2.5 and 3.3 inches gap depending on excursion
A 12inch driver wants between 3.0 and 4.0 inches gap
A 15inch driver wants between 3.8 and 5 inches gap
A 18inch driver wants between 4.5 and 6.0 inches gap
Old 12-02-07, 08:29 PM   #11 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Thanks for the detailed information, Collo. This is a big help for future reference.
Old 12-02-07, 08:34 PM   #12 (Link)
Alias: James
Loc: somers, ny
User: #13842
Since: Nov 2007
  jr1414 is offline
Finally, an answer that seems to have some basis in reality. Is there any difference in a sealed configuration as opposed to a ported configuration. Common sense tells me no, but it's worth asking the question.
Old 12-02-07, 10:28 PM   #13 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
  Josuah is offline
I have 15" drivers. The Hitchhiker's Guide to the Galaxy ended up pushing the grilles off my top-facing drivers (I have sealed sonotubes with drivers at both ends). So this past weekend I ended up redoing the legs and replacing the top grille with the legs and base as well. So now it looks like you can flip the sub either way. I went with 4" legs because I couldn't find screws any longer than 6" at Home Depot. Otherwise I was going to go with 5" legs.
Old 12-03-07, 10:20 AM   #14 (Link)
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
Thanks Collo for that detailed bit of information...
And for us mathematically challenged, the picture is also a work of art...
So back to 4 to 4.5" for my 15" high excursion...
Old 12-03-07, 11:27 AM   #15 (Link)
Alias: Ben
Loc: Pinawa. Manitoba
User: #739
  Bent is offline
would there ever be any reason to run tighter - as in using the baseplate for additional driver loading to raise system Q? or would we be better off to do it electronically?
I ask this, because IIRC correctly, SVS used their (some, maybe not all) baseplates for assisting in loading the driver.
Old 12-03-07, 01:16 PM   #16 (Link)
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
Great question there Bent.... I was curious of that thought as well...
My box design already has a low Q, around .5 or so, so it'll be kinda dry to begin with, but what other effects would that have, I read SVS used a shorter height to increase response to a givin area of response...
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
Is a baseplate necessary for a sonosub? Mattlock DIY Subwoofers - Sealed and Ported 5 11-29-07 10:45 AM
Distance from rear of magnet to cabinet... aceinc SoundSplinter 3 05-02-07 12:28 PM
Distance calculator ? tango Home Theater Projectors 2 03-03-07 05:51 PM
Can REW be used to help set sub distance in receiver? lovingdvd REW Forum 15 01-29-07 01:38 PM
Sub Driver Distance Josuah DIY Subwoofers 2 10-10-06 10:22 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 <
