Need new sub, thought i would build one! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss Need new sub, thought i would build one! in the DIY Speakers and Subwoofers forum; Need new sub, thought i would build one! Hello all i am new to this forum and new to DIY. Right now i have 2 Velodyne 12" sub, ...
Old 01-07-08, 02:24 AM   #1 (Link)
Alias: Eric
Loc: Surrey BC Canada
User: #15138
Since: Jan 2008
Eric Mathews is offline
Hello all i am new to this forum and new to DIY. Right now i have 2 Velodyne 12" sub, they are more of a music sub and not a HT sub. The room that i have my theater set up in is used 100% for Movies. I have been looking into an SVS for about 6 months now but they figured, its just a cylinder with a sub i can build that lol. I have my mind set on a sonosub and just picked up a css SDX15. Found out that i live 20 min from their location in Abbotsford BC lol. I have seen a couple of people build the sonosubs with this driver and i was wondering if anyone had any suggestions about size of tube and port length and size. I have read a lot and it seems like Steve is the sonotube god lol. size does not matter at all the whole room is made for it and i got no wife to please!! OHH the amp im using is a pro amp bridged to 560 wrms, im hoping thats enough. thanks in advanced for your wealth of knowledge
Eric
Old 01-07-08, 10:43 AM   #2 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
Re: Need new sub, thought i would build one!
Nice driver choice Eric. You could use more watts for that driver but 500 or so should be fine. You are doing a single driver build, correct? I think that about 330L tuned to 15hz looks about right for this driver. You would use a 6" port or possibly 3 4" ports if you wanted more vent area. Do you have winisd? You can simulate this stuff yourself with it.
Old 01-07-08, 11:52 AM   #3 (Link)
Alias: Eric
User: #15138
Since: Jan 2008
ya im going to be getting winisd tonight and fooling around with it, i had the amp from before thats why im using it. In the future i might make another one, and then ill get a better amp. Is there any differenace between using 3 smaller ports instead of one large one? besides one is easyer to make :P thanks for the fast reply!
Old 01-07-08, 12:18 PM   #4 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
As long as the 3 smaller vents have the same total area of the bigger vent then it's the same. Since you've decided on a sonosub design here is an excellent program that will help.
http://www.subwoofer-builder.com/sonosub.htm
Old 01-07-08, 03:13 PM   #5 (Link)
Alias: Eric
User: #15138
Since: Jan 2008
THANKS!! that is awesome when i get home from work i will down load it. there is so much to learn and you all know so much! thanks again for the feed back.
Eric
Old 01-08-08, 03:54 PM   #6 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
3 4" ports will have slightly more vent area than a single 6" vent. If you want to keep your airspeed as low as possible the more port area the better. That said I don't think that you will have any problems with a single 6er.
Old 01-08-08, 07:49 PM   #7 (Link)
Alias: Eric
User: #15138
Since: Jan 2008
Ricci wrote: View Post
i was looking around for other amps and i cam across a Yorkville AP-3400 for $450
it puts out 1200 wrms x2 @ 4 ohms
http://www.yorkville.com/default.asp...2=120&p_id=115
that is a link the the manual (scroll down and select the AP 3400)
it seems like its got good specs. just wanted to know your opinion on that amp for that price. thanks
Eric
ohh the reason i was looking for a 2 ch, i might build another sub.
Old 01-09-08, 10:04 AM   #8 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
I'm not familiar with that model, but Yorkville has a good rep so I'm sure that it's a solid design. You could probably find a Crown XS1200 on e-bay for about that much, which should be even better. There were 2 that went for about 500 awhile back.
Old 01-10-08, 02:54 PM   #9 (Link)
Alias: OJ
Loc: Toronto, Ontario
Owen Bartley's Avatar
User: #3144
Since: Oct 2006
Owen Bartley is offline
Eric, good driver choice. And if you have no real space or design constraints, and you're used to two smaller subs but want more bottom end for your HT, a nice large enclosure will do you wonders. The LLT seems to be a great option for HT if you can fit it physically, and it sounds like you can, so I'll second Josh's suggestion.
Oh, and don't worry about the amp for now, unless you really want to spend the money on the new one. As long as you're careful when you fire it up, and you increase the volume/gain slowly to make sure you don't clip, you should be ok. And if you get everything up and running and decide you really do need more power, it's easy to get something and sub it in at that point.
Old 01-11-08, 02:26 AM   #10 (Link)
Alias: Eric
User: #15138
Since: Jan 2008
UPDATE!!!
ok im done cutting all my holes, well except for one small one. There is a picture of my rigged up router jig lol. Getting my 24" sonotube on sat then i should be able to finish all the cutting and gluing. thanks for all the help and the info!!
Old 01-11-08, 10:52 AM   #11 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
thxgoon is online now
Coooooooool. I can't wait to hear what you think of this vs your Velodynes. Nice jig btw
Old 01-11-08, 10:42 PM   #12 (Link)
Alias: Eric
User: #15138
Since: Jan 2008
ya the pictures that i took where way bigger, image shack shrinks them too bad lol
Old 05-13-08, 09:03 PM   #13 (Link)
Alias: Eric
User: #15138
Since: Jan 2008
ok so here is the update. i was gone for a couple of months so i couldnt really post but i finished the sub.... but im not very happy with it. im not sure whats wrong but i will post the SPL levels.
ohh and i think the sub is defective because any ware around 30 hz i can hear the voice coil rubbing :S. I didnt know if was supposed to use the "a" or the "c" weighting so i recorded them both. tell me what you think. Oh and im using an old carvin amp rated at 800 RMS into 4 ohms.
"A"
30 - 96
35 - 102
40 - 107
45 - 112
50 - 111
55 - 106
60 - 104
65 - 105
70 - 105
75 - 104
80 - 100
"c"
30 - 83
35 - 85
40 - 95
45 - 91
50 - 90
55 - 88
60 - 86
65 - 87
70 - 88
75 - 88
80 - 85
this was running at JUST under clipping for my amp. i was kinda hoping for a little more then that since my sub box is HUGE. Could that be the problem right there, maybe a standing wave or something. i was thinking i might just rip the sub out and try it in a sealed box. please tell me what you think!!
Eric
ps ill post the pictures i took later
Old 05-13-08, 09:51 PM   #14 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
eyekode is offline
Eric Mathews wrote: View Post
It does seem to roll-off very early. Does your amp have a high-pass filter?
Silly question: at what distance did you take these measurements?
Old 05-13-08, 10:29 PM   #15 (Link)
Alias: Eric
User: #15138
Since: Jan 2008
i took them at about 2 meters, but then again it is in a room so there should be gain from that as well..... i dont know it seems like Ilkka got better results with this sub out side in a 100L sealed box. http://www.hometheatershack.com/foru...-100l-new.html
Old 05-14-08, 03:08 PM   #16 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
Are you sure that it is the VC rubbing that is making the sound you hear? could it be something loose or buzzing around the driver or in the cab? Amp clipping/ have you taken the driver out to check this?
Your roll off does seem kind of early, but you might have a big peak at 40-45hz.
Old 05-15-08, 04:04 PM   #17 (Link)
Alias: Looney
Loc: Topeka, KS
User: #2678
Since: Sep 2006
looneybomber is offline
It's not so much that it's rolling off early, it's that the standing wave at the mic position is causing a huge bump in the 40-50hz area. I would try measuring it outside where room interactions wont be a problem.
Old 05-15-08, 04:27 PM   #18 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
Where are you measuring the sub from? If you are just measuring the driver then you are not going to pick up any output from the port which plays a larger role the lower you go so that would explain a roll off in measurements.
Were both of your A and C measurements taken at full output of your amp? This looks suspicious because C weighted is a flat response on your meter where A weighted is designed to approximated the human ear which is less sensitive at lower frequencies. Thus under A weighting you should be seeing like -30db at 30hz. Strangely in your results not only is your A weighted flatter but also louder. This defies all convention so I would think there is either something wrong with your meeter or inconsistent with your set up. I'd suggest downloading REW and running a few sweeps at the listening position and posting those. They can tell a lot.
What are you dissapointed in sound wise? Have you tried moving the sub to different room locations? With that driver and amp you should be blowing your velodyne out of the water. Move the cone in and out by hand to see if there is any VC rubbing. I suspect that the sound you hear at 30hz is likely a leak or spider noise.
Old 05-15-08, 11:58 PM   #19 (Link)
New Member
Alias: BassThatHz
Loc: Abby, BC, Canada
User: #16407
Since: Feb 2008
BassThatHz is offline
hmmm, I was planning on moving from velodynes to two SDX-15's... Not good news.
I see you're in my area (cool); which velodyne series are you running?
Is there any way you could post a youtube video so we can hear em in action or at least more pics.
Graph seems decent, could you post plots of 25, 20 and 15hz too?
What kind of excursion are you getting during these measurements?
These are dual 2ohm drivers. I assume you hooked it up in series for 4ohm, the thought of running in bridged mode @ 1ohm eek!
I can't think of anything else other than defective amp or driver.
Old 05-16-08, 02:21 AM   #20 (Link)
Alias: Eric
User: #15138
Since: Jan 2008
ya i tryed moving the sub all around the room and in one of the corners was the best place. Both of the measurements where taking at about +6 db on my reciever.... pretty loud if other things where playing and not just the sub. any louder and the amp would start to clip. I have tryed 3 different amps, a QSC, Carvin and an Art. the carvin is what im using now. the sub looks like its moving ALOT, but maybe the box is just the wrong size for my room? so i might pull out the sub and throw it in a sealed box for a test. Ya im running it at 4 ohms lol i dont have an amp that will do 1 ohm. The Velodynes that im using im not sure what model but they are only 125 wrms so i think i should notice a huge difference. right now im running all 3 and it sounds ok, but i was kinda hoping to not have to use my other subs.
Old 05-16-08, 12:19 PM   #21 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
Double check you measurements. Can you post an REW graph? If it's moving a lot then it's making noise, nothing wrong with the driver or amp. Could just be a bad room...
Old 05-21-08, 12:14 AM   #22 (Link)
Alias: Eric
User: #15138
Since: Jan 2008
im starting to think your right MR THX!. i think this is more of a room issue. i went down there again but this time tryed putting the sub on its side in all different areas and it just made it even quieter then in the corner standing. but then once i moved it up i could not hear any noise at really low frequencies anymore!!!! so im thinking it was some dirt or something but its ok now. do you think that maybe the box is just too big? i could pull the sub out and make a sealed box for it. i just cant for the life of me figure out why its not as loud as 2 125 W 12" subs.... like i said before i can see the sub move alot, just must be some kinda standing wave. but moving it around does not make it any better... maybe i need a smaller sub then a 15? thanks for all your help!!
Old 05-21-08, 06:21 AM   #23 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Eric,
A 15 incher won't be specially louder than 2 12" sealed drivers (all paramaters other than size assumed equal), specially when it comes to the heard bandwidth of bass... it looks to me like you need another sub.
From its measurments, would like to say the SDX 15 is an excellent driver. Pls post an REW FR. How much is the enclosure volume? 350L? Did you measure the actual tune? Let us know.
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 05-21-08, 10:10 AM   #24 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
Ya, another possibility is that your new sub is so clean and distortionless that it doesn't sound as a loud. A lot of times high output subwoofers can introduce a lot even ordered harmonic distortion which increases percieved output. Your new sub won't have this. I don't have WinISD atm so can't model your sub but I think your design looks good. You may just need more
Old 05-21-08, 12:20 PM   #25 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
I agree!
