Low budget dual 12"sealed with LT - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss Low budget dual 12"sealed with LT in the DIY Speakers and Subwoofers forum; Low budget dual 12"sealed with LT I wanted to replace my old DIY dual 10" woofer setup but my lovely loans officer was imposing strict budgetary ...
Old 01-19-08, 09:33 PM   #1 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
I wanted to replace my old DIY dual 10" woofer setup but my lovely loans officer was imposing strict budgetary constraints so the likes of SS,Fi and other hi performance woofers were beyond my reach.Having seen Ikkas promising measurements of the Infinity Perfect 12 in a sealed box I snagged a pair of similarily spec'd Reference 1242w's for $60 the pair on Ebay. http://manuals.harman.com/INF/CAR/Bo...ch%20Sheet.pdf I know these drivers have limitations but I figured by using a using a pair I should be able to get enough clean output for my needs.They will only be used to augment my main LCR speakers and will not be used for the LFE channel.
The sealed enclosure will have a net volume of 75 liter and an f3 in the low 40's.An LT circuit will be used to add approx 6db of boost so as to extend the f3 down to about 28 hz.I could have added more boost to extend response further but I settled on the modest 6db for 2 reasons.The drivers will not run out of excursion as quickly and the enclosure will be corner loaded (and it has a shallow rolloff) so room gain should help lift the response at the very bottom.
As the pics show I wanted to keep panel resonance low so I braced the cabinet heavily and the drivers are mounted opposed which should reduce vibration even further.
I will bore you with some pics of the bracing scheme.
Old 01-20-08, 10:26 AM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: Low budget dual 12"sealed with LT
They are definitely well braced! What amp will you be using to drive them?
Old 01-20-08, 10:55 AM   #3 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Mike P. wrote: View Post
Undecided but likely a Bryston PP120 or my ASP250 ICE Power module.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
Need some thoughts on a large dual 15", dual ported design. erikhtb SoundSplinter 43 05-24-07 05:56 PM
Super low budget home theater rabies_70 Home Theater Equipment 1 04-12-07 05:58 PM
Very low budget sub. mgboy DIY Subwoofers - Sealed and Ported 53 02-05-07 09:48 PM
Low budget, high WAF IB, in-wall system report lcaillo DIY Subwoofers - Infinite Baffle 11 10-25-06 01:53 PM
My low budget gear :-) Exocer Home Theater Equipment 8 10-10-06 06:58 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
