Tempest X Sonotube Build Thread - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss Tempest X Sonotube Build Thread in the DIY Speakers and Subwoofers forum; Tempest X Sonotube Build Thread Well Folks, the build has begun. I am building a pair of 300L sonotubes tuned to 17hz as per Kevin ...
Old 01-26-08, 07:01 PM   #1 (Link)
Alias: Maceo23
Loc: Houston, TX
User: #7526
Since: Mar 2007
Maceo23 is online now
Well Folks, the build has begun. I am building a pair of 300L sonotubes tuned to 17hz as per Kevin Haskins advise. I'm using 24" tubes with 8" flared ports. Today has basically been a whole day of cutting circles. Hopefully tomarrow I'll finish with the last of the circle and start gluing and painting. Pics are soon to come when I figure out how to load them on here.
Old 01-26-08, 07:35 PM   #2 (Link)
Alias: Maceo23
Loc: Houston, TX
User: #7526
Since: Mar 2007
Re: Tempest X Sonotube Build Thread
Here are a few preliminary pics.
Old 01-26-08, 07:50 PM   #3 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Good choice of sub. Looking forward to your build pictures.
Old 01-27-08, 11:40 PM   #4 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
thxgoon is offline
Goodie goodie goodie, I love build threads
Nice design, I can't wait to hear what you think of it.
Old 01-28-08, 07:10 AM   #5 (Link)
Alias: Maceo23
Loc: Houston, TX
User: #7526
Since: Mar 2007
I HATE CUTTING CIRCLES!!! It feels like that all I've benn doind all weekend. I have all 4 caps glued and ready for finishing. I really managed to get a lot done. I also finished gluing the insulation to the inside of the tube and the carpet on the outside. Really, all I have left, before final assembly, is to make and attach the feet, and to paint. I just have one question. I was wondering if I need to wrap the outside of the port with insulation also. If you know, let me know. I'll post some pics tonight.
Old 01-28-08, 07:15 AM   #6 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Wrapping the outside of the port with insulation is not necessary. Looking forward to your pics!
Old 01-28-08, 07:34 PM   #7 (Link)
Alias: Maceo23
Loc: Houston, TX
User: #7526
Since: Mar 2007
Here's a few more pics.
Old 01-28-08, 07:49 PM   #8 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
thxgoon is offline
Looking good!
I wish I had planned into my design being able to tuck the carpet under the top cap like that. The carpet on my left sub fell off during one particularily bassy movie
Old 01-29-08, 08:52 PM   #9 (Link)
Alias: Maceo23
Loc: Houston, TX
User: #7526
Since: Mar 2007
Well, I am at the point of figuring out how I'm going to attach the dowel feet to the end cap and base plate. I was wondering if anyone has a trick to making the alignment and attachment a little easier, and what kind of hardware I should use. I have some 3" wood screws that I was planning on, but if anyone has a better and easier idea, I'm all ears.
Old 01-30-08, 10:58 AM   #10 (Link)
New Member
Alias: Kent
User: #14655
Since: Dec 2007
zeug is offline
Hi,
Great looking build. I am contimplating a very similar build with a Tempest-X for my first sub. For the money, I dont think there is a better choice.
I personally would use a Lag bolt instead of a long screw for the feet. 1/4" lag would be much stronger.
Keep the pictures coming. I need the motivation to get started with my project.
Kent
Old 01-30-08, 12:21 PM   #11 (Link)
New Member
Alias: Leonardo
Loc: E!lkins, WV
User: #15589
Since: Jan 2008
Leonardo is offline
Maceo23 wrote: View Post
Why don't you stack the floor plate on top of the end cap (or vice versa) and drill your pilot holes with a long bit? Don't forget to drill smaller pilot holes in the dowels.
I agree about the 1/4" lag bolts.
For my dowels, I clamped a stop to a chop saw. This ensures that they are all square and exactly the same length.
Old 01-30-08, 12:51 PM   #12 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Leonardo wrote: View Post
I built mine by stacking the pieces and drilling pilot holes. Lag bolts are fine, screws work just as good if you also use wood glue, and the screws are easier to countersink. Never had a problem with mine.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
Blaser HT build Thread Blaser Home Theater Design and Construction 82 06-11-08 12:00 PM
Four 18" Fi IB Woofer Build Thread NickTF Fi Audio 42 04-13-08 03:33 PM
Sound Splinter RL-p18 Giveaway build thread Mongrel714 SoundSplinter 115 02-09-08 07:12 PM
Dave's Dual RL-P18 Sonotube Design/Build Thread Avus_M3 SoundSplinter 55 02-07-08 01:51 PM
Calling All Sonotube Builders For A Little Help On My Tempest X Build Maceo23 DIY Subwoofers - Sealed and Ported 12 01-23-08 12:56 PM
Mach 5 Audio
