| DIY Subwoofers Subwoofer Database Addition Suggestions and Discussion ThreadDiscuss Subwoofer Database Addition Suggestions and Discussion Thread in the DIY Speakers and Subwoofers forum; Subwoofer Database Addition Suggestions and Discussion Thread Mike P. had created a Subwoofer Database thread so that it will easier to locate threads here at Home Theater ... |
| | #1 (Link) | ||||
| Subwoofer Database Addition Suggestions and Discussion Thread Mike P. had created a Subwoofer Database thread so that it will easier to locate threads here at Home Theater Shack that reference the various DIY Subwoofer build projects. This thread here will be for submitting additions to that thread and will also serve as the discussion thread for the database thread. This will keep the database thread clean and organized. If you would like to submit a suggestion, include the following:
Your suggestions will be reviewed and added to the database as soon as possible. Thanks! | ||||
| | #2 (Link) | ||||
| Re: Subwoofer Database Addition Suggestions and Discussion Thread Here is a bunch of Dayton builds; Sub Puppies: Dayton 12" Titanic Mark III, 45 L (1.6 cubic feet) sealed, 33.8Hz box tune Dipole Sub, Dual Dayton Clearance 12" drivers (works well with Elemental Designs EHQS-12s too), n/a, n/a Budget Stubby Sonosub, Dayton SD315-88 12" SHIELDED DVC, 127 L (4.5 cubic feet), 26.5 Hz box tune | ||||
| | #4 (Link) | ||||
| Re: Subwoofer Database Addition Suggestions and Discussion Thread There is my 12" Infinity Kappa VQ build which was done because of how well the driver measured in Ikka's testing. | ||||
| | #5 (Link) | |||||
| Re: Subwoofer Database Addition Suggestions and Discussion Thread Quote:
Is "Kappa 12VQ" the proper name for the sub? | |||||
| | #9 (Link) | ||||
| Re: Subwoofer Database Addition Suggestions and Discussion Thread Forgot this one; 8" Transmission Line Sub, Dayton SD215-88 8" Shielded DVC Subwoofer, Length = 90 inches, Sdo = 34 in^2, tuned to 33 Hz. | ||||
| | #19 (Link) | ||||
| Re: Subwoofer Database Addition Suggestions and Discussion Thread Builds that are not yet complete, as in 'ongoing'. They are often 'fresher', any prices, suppliers and solutions are often of a newer date than completed builds in which information can be years old. One example is my build | ||||
