Why not adding some sound deadener inside an enclosure? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss Why not adding some sound deadener inside an enclosure? in the DIY Speakers and Subwoofers forum; Why not adding some sound deadener inside an enclosure? Well, I was thinking, maybe adding a couple of layers(2-3) of some second skin damplifier pro or wtv over the ...
Old 02-11-08, 12:02 AM   #1 (Link)
Alias: SQBubble
Loc: MTL, QC, CA
User: #13347
Since: Nov 2007
SQBubble is offline
Well, I was thinking, maybe adding a couple of layers(2-3) of some second skin damplifier pro or wtv over the wood inside the enclosure and then add a pink fiberglass or some egg-like foam layer over them ...
wouldn't that help rigidity and get rid of annoying inside resonating frequencies? as it'll make each side pretty heavy enough to keep the pressure well inside the box, intact and clean.
what do you guys think of that?
discuss plz
Samsung 24" LCD Widescreen 245BW
X-Fi Elite Pro Soundcard
B&W 685
AA hAvoc 18" with 2 PR1816 in 7.3cu.ft@18.5hz
Crown XTi1000
Crown XTi2000
the big summer upgrade(new big sized bookshelves with new sub setup)
**Soon to be a new MTM DIY project**
Old 02-11-08, 12:17 AM   #2 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is online now
Re: Why not adding some sound deadener inside an enclosure?
I've personally never experienced any resonances with my poly batting-lined sonosub
Old 02-11-08, 10:51 AM   #3 (Link)
Alias: Robert
Loc: Southaven, MS
User: #1964
Since: Aug 2006
Robert_J is offline
This has been brought up time and time again over the years I have been on the DIY forums and it is agreed upon that it is a waste of time. If you can search the archives at HTF, Dan Wiggins has a great explanation why it is a waste.
-Robert
Old 02-11-08, 11:26 AM   #4 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Fiberglass or egg crate foam damps the resonances. Rigidity is acheived by proper bracing of the cabinet.
Old 02-11-08, 11:47 AM   #5 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
avaserfi is online now
I am not entirely sure why it is so widely used, but I would like to point out that egg crate foam does not sufficiently dampen a cabinet. Many people use such foams on the internal areas of the subwoofers and loudspeakers and to be honest I am not sure why as in most all cases* its absorbency coefficient is very poor especially when compared effective alternatives like OC703/705 or a reasonably high density mineral board (6-8lb).
*There are some foams specifically designed to be used for acoustic dampening purposes and these generally measure far better than most other foams (think Auralex or Echobusters), but are usually still not as effective as other mentioned alternatives.
Proper internal dampening of a cabinet is necessary fully remove standing wave issues which can cause resonance as well as other possible issues.
-Andrew
Old 02-11-08, 01:43 PM   #6 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
No question there are better dampening materials. So far I've built 7 HT subs and have had no issues with resonance using egg crate foam. Although egg crate foam may have a poor absorbency coefficient, it does do the job.
Old 02-12-08, 10:39 AM   #7 (Link)
Alias: PHIL
Loc: SHERMAN, TX
ISLAND1000's Avatar
User: #8655
Since: May 2007
ISLAND1000 is offline
SQBubble wrote: View Post
discuss plz
"annoying" What're those?
Yes, add sound deadening. Anything that reduces, absorbs, or lowers the level of reflected sound INSIDE the enclosure theoretically helps, including bracing. Ported, IB, LLT, etc. subs only use the "tuned" and 'Q' function of the enclosure.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
adding subwoofer to my pc jrs2008 Computers | Games | HTPC | Digital Devices 3 01-16-08 07:12 AM
DLS-5000R / CHT-15R inside pics mike c Home Audio Subwoofers 5 01-03-08 06:03 PM
My first session with my new FBQ2496 - Results inside... RazorX BFD Forum 11 11-28-07 10:54 AM
Advise on Heat Build up inside TV .... salvasol Video Displays and Processors 3 03-21-07 06:02 PM
Whoa! Inside The Apocalyptic Brick?Scary! Roger Movies | TV Shows | Hollywood 0 08-28-06 11:53 AM
Mach 5 Audio
