new drivers for older sub - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss new drivers for older sub in the DIY Speakers and Subwoofers forum; new drivers for older sub Hey guys, I have a question. I have an older front firing Yamaha ysp-150 amp. it measures 24" tall x ...
Old 02-11-08, 10:18 AM   #1 (Link)
Alias: john
Loc: rhode island
User: #13802
Since: Nov 2007
dieselpower1966 is offline
Red face new drivers for older sub
Hey guys,
I have a question. I have an older front firing Yamaha ysp-150 amp. it measures 24" tall x 10" wide x 17" deep.
it has 2 - 8" drivers with a 4" wide x 8" long port tube and powered by a 150 watt amp. I do not know what the cubic interior space is or what the sub is tuned at.
so here's my quetions
would it be worthwhile to change the drivers? I cannot go larger so they would have to remain 8" drivers.
also would it be worth while to change the plate amp? right now I'm not looking to build a box I'm trying to stay with the existing box for now.
if you could, please give me some brand ideas for the drivers and the amp plate.
thanks
dieselpower1966
Old 02-13-08, 11:32 AM   #2 (Link)
Alias: john
Loc: rhode island
User: #13802
Since: Nov 2007
Re: new drivers for older sub
wow I'm simply amazed..
none of the experts from the shack has any comments on my question.
I think I'm dumbfounded.
LOL
Old 02-13-08, 11:37 AM   #3 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
avaserfi is offline
Sorry, I missed this thread. If you wanted to change out the drivers it would be possible, but internal volume would need be known. If you found the thickness of each wall (some might be of differing thicknesses) it wouldn't be very hard to figure out.
Once this is done other drivers could be modeled in an enclosure of the same size. Depending on the drivers used you might need to change the amp.
Why are you looking to upgrade i.e., what about the sub doesn't please you? Also, how much are you willing to spend? In the end it will probably be a better idea to buy a new sub rather than just switching the drivers out as a properly designed speaker/sub would have a cabinet designed for the drivers used.
-Andrew
Old 02-13-08, 11:50 AM   #4 (Link)
Alias: Rodny
Loc: Millbrook AL
Rodny Alvarez's Avatar
User: #158
Rodny Alvarez is offline
Hey John!!
The box is about 1.70cft and tune to around 40hz.
If you thinking about buying a amp and subs, you maybe better buying a use sub for around $300 to $400
You can probably change the subs and re-tune the box, just depend on the subs you buy, make sure you buy the subs with the same ohms.
You can check some subs here.......................
http://www.partsexpress.com/webpage....ctGroup_ID=847
Old 02-13-08, 11:51 AM   #5 (Link)
Alias: john
Loc: rhode island
User: #13802
Since: Nov 2007
thanks for responding Andrew,
the thickness of the walls are 3/4" particle board, I do not how to calculate the internal volume.
I'd like to change the drivers and the amp if it's only a good investment in sound and performance. I don't know what the sub is tuned at, I don't know how to figure that either, I'll guess 30hz? on the low notes below the tuning I get a "whump" sound", i guess that would be the drivers bottoming out, I did not remove either driver so I don't know if they are wired in series, parallel, or if one is like a slave. any idea where to get the program to model different drivers and amps? any other infor would be appreciated.
John
Old 02-13-08, 11:58 AM   #6 (Link)
Alias: john
Loc: rhode island
User: #13802
Since: Nov 2007
thank you Rodney,
the Dayton Rss210HF looks like a very nice driver with response down to 27hz, priced $91.93 ea. seems like a deal. is there a program that I could use to model this driver in my sub enclosure?
what do you think about maybe using the amp that came with the sub and just changing the drivers? the amp is rated at 150 watts rms
thanks
John
Old 02-13-08, 12:15 PM   #7 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
avaserfi is offline
Looking at the sub you have and your willingness to spend a couple hundred dollars I would recommend buying two subs to achieve maximum performance that will far exceed your current set up. Either two Dayton Sub 100 or two Dayton Sub 120 units properly placed will achieve more headroom and a better low frequency response than your current sub even with an upgrade.
-Andrew
Old 02-15-08, 09:20 AM   #8 (Link)
Alias: john
Loc: rhode island
User: #13802
Since: Nov 2007
Well I did it, or I should say that my Wife did it!!
for Valentines Day, she bought me 2 Outlaw LFM-2 !!!!!!!!
God I'm SPOILED The delivery should be Monday...
I will post my impressions and hopefully photos when they are set up,
now the only question is what to do with my Yamaha Sub.
John
Old 02-17-08, 07:58 AM   #9 (Link)
Alias: john
Loc: rhode island
User: #13802
Since: Nov 2007
wow is this really annoying.
I know that Outlaw Audio is in Massachusetts, just outside of New Hampshire.
I was under the impression that they had a manufacturing plant and warehouse there. It turns out that they don't... All they have up there are engineers, designers, and sales men. All of their products are manufactured in Carson, California.
So three days after ordering the LFM-2's They are still in California.
Like I said I thought Outlaw did everything themselves in Massachusetts, if they had, my subs would be here tomorrow. But alas, I guess I missed the fine print on their website.
Everything that I read on the LFM-2's is great. They better be worth the wait.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
Samsung Bd-up5000 And Older Denon Reciever ewarren High Definition | HD-DVD | Blu-ray 1 12-28-07 05:30 PM
Replacement Driver for older ported Sub dtb300 DIY Subwoofers 23 12-18-07 12:56 PM
ID Drivers? Josuah DIY Subwoofers 5 10-30-07 04:50 PM
Can blue ray or HD dvd players older old DVDs Scuba Diver High Definition | HD-DVD | Blu-ray 4 10-27-07 06:24 PM
Outboard processors for older receivers w/ 5.1 input? gopheralex Home Theater Components 3 08-27-07 03:21 PM
Mach 5 Audio
