subwoofer port help - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
subwoofer port help
Discuss subwoofer port help in the DIY Speakers and Subwoofers forum; subwoofer port help I am just getting started building my first sub and i've got a couple of questions for those of you ...
Old 02-21-08, 10:02 AM   #1 (Link)
Alias: josh
User: #15511
Since: Jan 2008
ringbearer3791 is offline
subwoofer port help
I am just getting started building my first sub and i've got a couple of questions for those of you whove been through this before. I've modeled everything out in WinISD and it looks like i want to use a 4" port flared on both ends that's a little over 25" long. My box is 8 cu ft after all bracing, driver and port but due to box dimensions i need to bend the port inside the box. is there anyone out there offering ports with a 90 degree bend or will i need to go to the local home depot and get a pvc angle bend? Also, having read Collo's works and discussion of ports, if i want to get ports from precision ports or others, are their ports of compatible thickness with standard pvc so as to be able to use a 90 degree bend i could get from home depot or others?
thanks all. i'll be posting updates and pix as i actually get started on construction.
Josh
Old 02-21-08, 10:31 AM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: subwoofer port help
Parts Express sells 3 and 4 inch elbows in their ""Dayton Create-Your-Own Flared Port Tube System""
http://www.partsexpress.com/webpage....&so=2&desc=ASC
PVC elbows are cheap and easy to work with. There are some pics and a good description on how to glue them in Matt's build.http://www.hometheatershack.com/foru...-im-again.html
We're all in this together!
Old 02-21-08, 11:26 AM   #3 (Link)
Alias: Jared
User: #2200
Since: Aug 2006
JRace is offline
Don't forget the volume displaced by the entire port (including internal volume) should be accounted for in the box design.
If you port takes up 'X'sq ft then you must add that much internal volume.
Old 02-21-08, 11:29 AM   #4 (Link)
Alias: josh
User: #15511
Since: Jan 2008
Thanks Mike, those were the kinds of answers i was looking for.
JRace, thanks for the reminder, i've already got that factored in but it never hurts to continue getting suggestions from those whove gone before me.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
Slot port? mgboy DIY Subwoofers 6 12-31-07 06:56 PM
need help with soonosub port ramchip007 DIY Subwoofers - Sealed and Ported 2 08-28-07 08:58 PM
Port noise mgboy DIY Subwoofers - Sealed and Ported 11 07-29-07 02:31 PM
port elbow WarrenP DIY Subwoofers - Sealed and Ported 6 05-29-07 02:30 PM
Port location? aceinc DIY Speakers 3 05-10-07 05:01 PM
Mach 5 Audio
