TC3000 Box Design Help - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss TC3000 Box Design Help in the DIY Speakers and Subwoofers forum; TC3000 Box Design Help Hey a guy wants me to build him a box for his TC3000 QVC 15" and I was wondering a ...
Old 02-22-08, 05:54 PM   #1 (Link)
Alias: only126db
Loc: CA
User: #17224
Since: Feb 2008
only126db is offline
Hey a guy wants me to build him a box for his TC3000 QVC 15" and I was wondering a few things.
First the specs I found for the sub on their site(archive) seem a little odd since it's a quad coil at 1.2ohm each.
1) RES... 4.63 ????
2) No Xmax
Then box size specified as 4.2cu ft with 25sq in x 30" long port ???
That seems very impractical doesnt it???
Any help is greatly appreciated.
TC-3000
58 Fixed QVC 15"
59 Qms 6.10
60 Res Ω 4.63
61 BL (Tm) 27.10
62 Mms (grams) 373.00
63 Cms µN/M 136.00
64 Sd (m^2) 0.0820
65 Lp (mH)
66 Ls (mH)
67 Rp Ω
68
69 Constants
70 c (m/s) 341.00
71 d (kg/m³ 1.20
72 K 0.00E-01
73
74 Calculated
75 Vas (liters) 127.60
76 Fs (Hz) 22.35
77 Qes . 0.330
78 Qts . 0.313
79 n0 0.04E-01
80 SPL (dB) 1watt 84.55 88.19
Old 02-22-08, 06:28 PM   #2 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
Re: TC3000 Box Design Help
The TC-3K is largely a sealed box driver. For your queries:
1) RES (series resistance of VCs) = 4 x 1.2 = 4.6 (I guess they actually measured 4.63)
2) Xmax = 30mm on the TC-3K
If I were porting this driver 25 sq in would be the minimum I would consider. A 25 sq in x 30" port on a 4.2 cu ft box gives a tuning frequency of around 22 Hz.
How much power are you going to have available for the driver? I believe it can handle around 2 kW thermally (and with a high pass filter in the box you're considering it will easily take that mechanically). When you start getting up into the 2 kW range with that enclosure with that port the port velocity starts getting up to around 20% of the speed of sound which is going to be easily audible. Of course in order to get the port velocity down to around 10% you need to go with a port that has twice the area and twice the length. I think that is the biggest problem with using a ported enclosure with this driver. It is more suited for either a sealed or passive radiator enclosure.
Old 02-22-08, 06:37 PM   #3 (Link)
Alias: only126db
Loc: CA
User: #17224
Since: Feb 2008
Geoff St. Germain wrote: View Post
not a whole lot of room for a port in a box of the specified size (18x18x22.5) internal with that large a motor is there....
Old 02-22-08, 06:40 PM   #4 (Link)
Alias: Geoff
User: #4919
Since: Dec 2006
Well, you could alter the dimensions of the box to get one of the sides to be long enough for the port, but I still think it isn't a good idea (see the edit in my post above).
Old 02-22-08, 09:27 PM   #5 (Link)
Alias: only126db
Loc: CA
User: #17224
Since: Feb 2008
What I did was emailed dude and told him my cocerns about port area, length and positioning and explained about going sealed and he agreed so we will see.
As for a material for a home sub box, I was thinking of going 1 1/4" mdf with possibly a veneer or paint...who makes a good easy to apply veneer?
Old 03-08-08, 03:38 PM   #6 (Link)
Alias: only126db
Loc: CA
User: #17224
Since: Feb 2008
Well for anyone who cares...I built the guy the box...3.66 cu ft sealed made of
1" MDF...came out great...he flaked on me.....now I have a huge box and nothing to go int it....I am now out the $$$ it cost for materials and my labor....
Basically I was doing it for $120....
Old 03-08-08, 04:10 PM   #7 (Link)
Alias: Geoff
User: #4919
Since: Dec 2006
That's unfortunate. Maybe you can find someone else looking for a box that size for a 15" driver.
Old 03-08-08, 05:48 PM   #8 (Link)
Alias: only126db
Loc: CA
User: #17224
Since: Feb 2008
Yeah got it up for sale....has to be local cause of size and weight shipping is around $120!!!
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
question about sub box design h0bo4life DIY Subwoofers 7 03-23-08 08:44 PM
TC3000, TC2000, SDX, or RLP 15" for HT sub bamaboy DIY Subwoofers - Sealed and Ported 3 02-03-08 02:40 PM
Sub Box Design Danny DIY Subwoofers 15 06-14-07 10:54 PM
My Box Design Danny DIY Subwoofers 14 02-21-07 08:11 AM
Guide to Sub box Design Danny DIY Subwoofers 12 05-13-06 10:48 AM
Mach 5 Audio
