Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Torrent Audio Mistral 12 DVC
Discuss Torrent Audio Mistral 12 DVC in the DIY Speakers and Subwoofers forum; Torrent Audio Mistral 12 DVC I'm looking to build a sealed sub for a 100% music application. I see that the Mistral 12 DVC (db-500) ...
Views: 543 - Replies: 7
Old 02-24-08, 12:52 PM   #1
Alias: Jon
Loc: Elkhart, IN
User: #17008
Since: Feb 2008
  jwh7399 is offline
I'm looking to build a sealed sub for a 100% music application. I see that the Mistral 12 DVC (db-500) is $89. Has anyone used this sub in a sealed enclosure?
This sub is going to be used with the BAMTM speakers from Zaphaudio. I will either use a plate amp or my crown xls802d to power it.
http://www.torrentaudio.com/mistral12dvc-p-73.html
Thank you,
Jon
Old 02-24-08, 01:12 PM   #2
Alias: Geoff
Geoff St. Germain's Avatar
Loc: Winnipeg, Canada
User: #4919
Since: Dec 2006
  Geoff St. Germain is offline
Re: Torrent Audio Mistral 12 DVC
There are a couple of threads on AVSforum.com about sealed TC Sounds DB-500s (same driver as the Mistral). I've mostly seen this driver used in ported enclosures, not to say that it doesn't work well sealed.
Old 03-02-08, 01:16 PM   #3
Alias: Jon
Loc: Elkhart, IN
User: #17008
Since: Feb 2008
  jwh7399 is offline
What are your thoughts on this driver in 3.35 cubic foot sonotube tuned to 20.3hz?
I would wire the sub in series for an 8 ohm load and power it with 500w from the crown XLS amp.
16" sonotube with a 4" flared port.
Old 03-02-08, 06:40 PM   #4
Alias: Geoff
User: #4919
Since: Dec 2006
Yeah, that looks good. I'd try to get a bigger port in there, or multiple smaller ones. The port airspeed with 500W is a little high for my liking.
Old 03-02-08, 10:07 PM   #5
Alias: Jon
Loc: Elkhart, IN
User: #17008
Since: Feb 2008
  jwh7399 is offline
How does this sound?
3.63 cu.ft.
20.3 hz
2 ports, 3" in diameter, flared at both ends
Old 03-03-08, 12:14 AM   #6
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
That's close to what Matt built with a TC-12DB-500. He had good results.
http://www.hometheatershack.com/foru...-feedback.html
We're all in this together!
Members DIY Subwoofer Database
Old 03-03-08, 01:47 PM   #7
Alias: Ken
ktaillon's Avatar
Loc: CT
User: #7968
Since: Apr 2007
  ktaillon is offline
Have you looked at the RSS265 10" woofer? Works well in a sealed enclosure, they also make a 12" in 8 or 4 ohms.
http://www.partsexpress.com/pe/showd...number=295-462
Old 03-03-08, 03:18 PM   #8
Alias: Geoff
User: #4919
Since: Dec 2006
If you're looking at sealed I think that 3 cu ft fully stuffed would work well for a low Q alignment. If you're looking for a higher Q then you can get down to around 1 cu ft.
I think that for the money the Mistral is better than the RS subs.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
