Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
opinions of sealed sonosubs?
Discuss opinions of sealed sonosubs? in the DIY Speakers and Subwoofers forum; opinions of sealed sonosubs? I am just exploring options on which box to build for yt TC200. i think I have ready everything there ...
Views: 549 - Replies: 7
Old 02-24-08, 08:00 PM   #1
Alias: tim
Loc: vermont
User: #7545
Since: Mar 2007
  tundraSQ is offline
I am just exploring options on which box to build for yt TC200. i think I have ready everything there is to read about LLT options....but I have not read anything about sealed sonosubs. Would putting a TC2000 in a sealed sonotube work? I'm thinking it might be worth it to try if I could find a 3' sonotube drop someplace.
Old 02-24-08, 09:46 PM   #2
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is offline
Re: opinions of sealed sonosubs?
A sonosub doesn't have to be ported - using a cylindrical subwoofer enclosure yields benefits no matter what alignment yo use.
Old 02-25-08, 05:16 PM   #3
Alias: tim
Loc: vermont
User: #7545
Since: Mar 2007
  tundraSQ is offline
I was thinking about doing a PR sealed sonosub...which would make the sub around 7 cu ft. I am thinking about this because I have never built either a sonosub or a PR sub...so why not try both at once? I have done aperiodic subs in a car once and LOVED them.
Can anyone suggest a box size and a driver to use as the PR? I was going to contact Danny over at GR research....
Old 02-27-08, 11:17 AM   #4
Gold Supporter
Alias: Kevin
Loc: Nazareth, PA
User: #17281
Since: Feb 2008
  zero the hero is offline
GR sells passive radiators, but they are not designed for horizontal use, so they won't work in a Sonotube. (unless you're laying it on it's side, which I was considering...)
Old 02-27-08, 07:42 PM   #5
Alias: tim
Loc: vermont
User: #7545
Since: Mar 2007
  tundraSQ is offline
zero the hero wrote: View Post
Yes , that is true....plu i have read that the TC2000 is not recommended as a down firing sub either. I'm not convinced that a PR sub will sound better than a LLT anyway. So i may just go LLT in a box and fire horizontal.
Old 02-28-08, 03:12 AM   #6
Alias: Steve
User: #263
What would have led you to think it ever might have? A PR will have a sharper rolloff (degraded transient response) and more suspension linearity issues to worry about. The only advantage offered by using PRs is being able to get reflex output without using a large enclosure, but by not using a large enclosure, you still end up missing out on certain performance characteristics. In other words, using PRs in a smaller enclosure does not replace a proper LLT, and in no scenario can I see it performing better.....you'd be lucky to get it to perform nearly as well to be honest.
Old 02-28-08, 06:47 AM   #7
Gold Supporter
Alias: Jean-Pierre
imbeaujp's Avatar
Loc: Beaumont, Quebec, CANADA
User: #12596
Since: Oct 2007
  imbeaujp is offline
I think you can not use a passive radiator down firing.
Here is a quote from Acoustic Elegance web site :
The PR should never be down-firing, the high Mms will cause the diaphragm to be displaced downward immediately. The spiders will eventually be stretched permanently by this treatment, and the unit will need to be rebuilt.
On my oppinion, passive Radiator are a good option if you want a small sub with extended low end. I agree with Steve that a proper LLT will perform with more impact than a small sealed sub, even with passive radiator. But LLT impose you to deal with a BIG cabinet. That was not "wife acceptable" in my case...
Old 02-28-08, 07:54 PM   #8
Alias: tim
Loc: vermont
User: #7545
Since: Mar 2007
  tundraSQ is offline
OK...so if I hear what you guys are saying I should think very hard abotu a LLT I am thinking about a "box" with the woofer and port on the same wall....say if the box was 24x24x36 ( it won't be but this gives you a visual)....I am picturing the sub top center on the 24x24 baffle and the port bottom center on the same 24x24 baffle. I am going to corner load this and fire it out into the room at an angle.
Can I get you guys to sign off on this, or suggest further refinements?
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
