Installing a 4" precision port? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss Installing a 4" precision port? in the DIY Speakers and Subwoofers forum; Installing a 4" precision port? Has anyone used one of these things? I have installed a 2" precision port before. Very simple, the outer flare ...
Old 04-04-08, 10:49 PM   #1 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
eyekode is offline
I have installed a 2" precision port before. Very simple, the outer flare has both a flange for bolting/gluing and a nice collar to ease installation. In my case I cut just about a perfect circle matching the collar diameter and the collar provides a large gluing surface.
But the 4" version is another beast. There is no outer collar. Just the flare.
The outer flare is huge on this thing. It goes out to 7 1/4". I figure I will have to cut ~6.5" hole to mount it. And because there is no collar it will only be held on by screws and glue on the flange.
Anyone have tips for mounting one of these in a horizontal orientation?
Thanks!
Salem
Old 04-04-08, 11:18 PM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: Installing a 4" precision port?
There are 2 different size flared ends. The smaller one is the inside (the box) flare and the bigger one is the outside (the box) flare. The smaller flare is the template for your cut out. Test it on a piece of cardboard to verify. I used a bead of putty and screws to mount mine.
We're all in this together!
Old 04-04-08, 11:35 PM   #3 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
eyekode is offline
Mike P. wrote: View Post
Thanks Mike. Did you also provide support for the flare within the cabinet? For example cutting a ~4" hole in a brace within the cabinet?
Old 04-05-08, 05:02 AM   #4 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
I've seen what you mentioned, personally I've used a "half circle" brace for the tube to rest on.
Old 05-02-08, 07:10 PM   #5 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
eyekode is offline
I ended up using what you recommended. After test-fitting the port I measured how high I needed to make the brace. I left a little height so I could put a gasket under it. I then cut a small piece of scrap for the port to rest on. I cut the top of the scrap into a half circle. I used some closed cell foam tape to go between the brace and the port. Works like a charm. Not 100% sure I even needed the brace, but it seems like a good idea to take the pressure off the flange.
Old 05-02-08, 08:05 PM   #6 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Good to hear it all worked out for you!
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
Port Material? bumpnzx3 DIY Subwoofers - Sealed and Ported 4 03-18-08 04:50 PM
Episode 21 - $99 the end of the War?, "The Contract", They Might Be Giants "Factory" eugovector Real HT Info Podcast 10 11-13-07 06:07 PM
need help with soonosub port ramchip007 DIY Subwoofers - Sealed and Ported 2 08-28-07 08:58 PM
15" LLT design/port resonance Hakka DIY Subwoofers - Sealed and Ported 3 05-25-07 07:50 PM
Port Resonance Zene DIY Subwoofers - Sealed and Ported 16 02-01-07 09:38 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
