Port Material? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Port Material?
Discuss Port Material? in the DIY Speakers and Subwoofers forum; Port Material? I went to Lowes today because I needed another box of screws and wood glue for my current sub build. ...
Old 03-04-08, 09:30 PM   #1 (Link)
Alias: Josh
Loc: St. Louis, Missouri
User: #13522
Since: Nov 2007
bumpnzx3 is offline
Port Material?
I went to Lowes today because I needed another box of screws and wood glue for my current sub build. While there, I noticed some expandable/flexible aluminum tubing. I believe it was to be used as duct work. Would this work well for port material? Seemed to be about half the price of PVC and a 1/4 the weight. It seemed fairly sturdy- at least enough to handle air pressure from the 250watts going to each of my subs. Thoughts?
Old 03-04-08, 10:14 PM   #2 (Link)
Alias: mrstampe
Loc: Pearland, TX
mrstampe's Avatar
User: #13368
Since: Nov 2007
mrstampe is offline
Re: Port Material?
Resonance from a thin metal tube of HVAC duct would be substantial, I would think. You need enough damping factor inherent to the material and from its wall thickness to avoid turning the port into something like a trumpet, sax, etc. PVC and sonotube have that advantage over very thin metal.
Mark
Pearland, TX (Houston)
Old 03-18-08, 04:43 PM   #3 (Link)
Alias: Jim
Loc: Cibolo, Texas
Zembonez's Avatar
User: #18335
Since: Mar 2008
Zembonez is offline
Re: Port Material?
The density and stability of the PVC is worth the minimal upcharge. Odd resonances from the tin duct would likely color the sub output... and probably not favorably!
Zembonez "always evolving" HT / Denon AVR 3806 / Denon DVD-1920 / 2 Adcom GFA 545 II / Adcom GFA 535 II / Adcom ACE 515 Line Conditioner / 4 Vintage Advent 6003 / 2 Sonance S624T / Opt Pro Linaeum Center - 2 Image Dynamics DVC 12 Subs / 4 Layer Laminated Custom MDF Enclosure / Kimber & Grayson Interconnects / AudioQuest Cables / Vintage Sony PS-3750 TT / Grado Prestige Silver / Lots of vinyl / Way too many DVDs and CDs / Etc.
Old 03-18-08, 04:48 PM   #4 (Link)
Alias: Josh
User: #13522
Since: Nov 2007
bumpnzx3 is offline
Re: Port Material?
i went ahead with the pvc a week or so ago. it's all cut/glued. i just need to get back out to my shop and do the finish work done on this little project.
Old 03-18-08, 04:50 PM   #5 (Link)
Alias: Jim
Loc: Cibolo, Texas
Zembonez's Avatar
User: #18335
Since: Mar 2008
Zembonez is offline
Re: Port Material?
I saw that I was a little "late to the party" there. Didn't know if you had proceeded or not. Good deal. I think you made the right decision. Hope the sub is nice and tight.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
subwoofer driver material dieselpower1966 Home Audio Subwoofers 2 02-20-08 09:43 AM
Da-Lite Screen Material Review mechman Projector Screens | DIY Screens 63 12-29-07 12:20 PM
Has anyone tried screen material sold on ebay? Scuba Diver Projector Screens | DIY Screens 12 10-29-07 12:17 AM
Breakdown of various acoustic treatment material rean1mator Home Audio Acoustics 3 02-12-07 02:08 PM
Acoustic Material Ciscokid Home Audio Acoustics 8 01-30-07 06:17 PM
Mach 5 Audio
