Questions before building sono. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported
Discuss Questions before building sono. in the DIY Speakers and Subwoofers forum; Questions before building sono. Hello, I wanna start my sono build and I have a few small questions : A) when cutting the inner ...
Old 03-09-08, 06:07 AM   #1 (Link)
Alias: Itay
Loc: Israel
User: #1560
Itay is offline
A) when cutting the inner endcaps, do they need to be the same as the inner diameter
of the tube, or a little bigger so it would fit with some pressure ?
b) when attaching the endcaps to the tube itself, do you use just glue or somthing
else also ?
Thanks !
Old 03-09-08, 06:14 AM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: Questions before building sono.
You want to achieve a tight fit. I used carpenters glue to glue the tube to the endcaps. Some brands of tubes have a transparent release film on the inside that glue will not stick to. This film needs to be removed, it peels off easily.
We're all in this together!
Old 03-09-08, 07:29 AM   #3 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is online now
You definitely don't want the OD of the endcaps bigger than the ID of the tube or else they will never fit in, even with a LOT of force. You'll permanently deform the tube before you'll get it to stretch much (which is why it works so well as a subwoofer enclosure).
Keep your tolerances tight enough and you can achieve an air tight fit without any need for adhesives.
Old 03-09-08, 08:17 AM   #4 (Link)
Alias: Itay
Loc: Israel
User: #1560
Itay is offline
I do have the "transparent release film" on the inside. good thing you told me.
My tube is 500mm ID so the inner endcap should be 500mm ?
Old 03-09-08, 08:37 AM   #5 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Yes. Using glue on the endcaps can't hurt. Better safe then sorry, in my opinion.
Old 03-09-08, 09:25 AM   #6 (Link)
Alias: Itay
Loc: Israel
User: #1560
Itay is offline
Thanks !
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Sealed and Ported »
Similar Threads
Ultra Newbie building HT - many questions INCINERATE Home Theater Design and Construction 21 02-27-08 06:56 AM
Do I need a crossover For my SONO SUB? ramchip007 DIY Subwoofers - Sealed and Ported 3 09-03-07 12:50 PM
Sono in garage:( Nick77 DIY Subwoofers 3 11-07-06 05:41 PM
New to forum RLP15 sono Nick77 SoundSplinter 0 10-19-06 05:32 PM
BFD Questions! House Curve Questions! RyanJNielson BFD Forum 5 09-05-06 09:34 AM
Mach 5 Audio
