| DIY Subwoofers - Sealed and Ported Torrent Audio Mistral 12 DVCDiscuss Torrent Audio Mistral 12 DVC in the DIY Speakers and Subwoofers forum; Torrent Audio Mistral 12 DVC I had initially planned on building a sonosub. I had modelled it using sonosub.exe. I came up with around 3.6 ... |
| | #51 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC I had initially planned on building a sonosub. I had modelled it using sonosub.exe. I came up with around 3.6 cu.ft. tuned to 20hz with two 3" ports 25" long. I guess I'de like to build the best sub I can with what I have. I have a Mistral 12 and a 4ohm db-500 svc but don't know enough to make an intelligent decision on which driver to use and for what. I'm almost ashamed to admit that I also bought 2 of the TC sounds 12" closeout drivers from PE and I don't even know what to do with the first two that I already had! Oh well, hopefully the Mistral and the db-500 will help me learn enough to do something nice with the twin "closeouts". I haven't even built a sub yet and I'm an addict! ![]() ![]() | |||
| | #52 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC That looks OUTSTANDING!!! Very nice work! The driver is going to look awesome next to that finish. It's almost a shame to put a grill over that, but we all know how little fingers like to poke and pull on stuff. Excellent job! | |||
| | #53 (Link) | ||||
| Re: Torrent Audio Mistral 12 DVC Quote:
So... you have 4 drivers and no box? Hehe .Oh, I have your plan: 4 sonosubs. One in each corner of the room .jk, I would not do this. I had two subs for a while. I think that unless you are very flexible in placement of the subs it is difficult to avoid making big nulls in your room. You are not going to like this, but for similar cost I would go with a Maelstorm sealed in 4cu. Add a little eq and it could probably beat all four of your current drivers. You might even be able to ebay the 4 subs and get enough for the Maelstrom. But it really comes down to your goals. How loud do you want? How low do you need to go? Is this for Music? Hometheater? Both? Are you putting them in more then one room? What size cabinet can you live with? | ||||
| | #54 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC Ok, so I actually ran the numbers and a single Maelstrom will not beat your 4 drivers . Especially not sealed. Ported it is 3db down from your 4 drivers but only requires half the box volume (8cu vrs 16cu).Sealed it would take a lot of EQ and ~4x the power but only a ~4cu box. Oh man, I have a problem too . My meager 100db @ 20hz is really sufficient, but it is fun to dream. | |||
| | #55 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC I'de like to build one just for music and 3 for HT. 2 of the 3 will be in the same room(twins). None of them need to be really loud(small children). I think the HT would be fine down to 20hz and the music sub maybe 30hz. I can live with any size cabinet that I need to. I think when the kids get a bit older I'll do a 15" or 18" monster. | |||
| | #57 (Link) | ||||
For music you could seal the db-500 in a 4cu box or a smaller stuffed box to reach a Q of ~.5. This driver should work great with a plate amp. Then as you said you could use the twins for your HT room. This is assuming the drivers can actually play low. I am not sure this is true. I remember modeling them when I saw the price, but I don't remember being too excited... What are the T/S parameters? | ||||
| | #58 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC These are the t/s from PE Specifications: *Power handling: 600 watts continuous *VCdia: 2" *Le: 2.49 mH *Impedance: 2 ohms per coil *Re: 4.2 ohms (coils wired in series) *Frequency range: 21-500 Hz *Fs: 21 Hz *SPL: 89.3 dB 2.83 V/1m *Vas: 4.66 cu. ft. *Qms: 4.25 *Qes: 0.41 *Qts: 0.38 *Xmax: 22 mm The subs came with sheets that list the actual measured parameters for each driver, but we are in the process of moving and the subs are at the new house. | |||
| | #62 (Link) | ||||
This models very similar to the db-500 for a sealed alignment. For a ported alignment the db-500 looks to be ~2db higher at the cut off frequency (~20hz) using the same box volume and port. But the clearance sub still looks pretty good. And I am not sure I trust the Mistral's T/S parameters to be as good as they claim. My initial measurements in room have the f3 at ~24Hz not the predicted 19hz. This could just be an anomaly of my room. I still have to measure the sub outside to be sure. | ||||
| | #63 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC I really like the BASH amps and the O-Audio amps because they are much more efficient then a typical class A/B amp. But I am partial to low-power because I only have 1 15amp circuit running to my entertainment center. The same circuit is shared by 3 PC's! | |||
| | #64 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC I like the Oaudio amps, It just seems that the Dayton amps have more bang per buck. I should think about what I'll be running on the same circuit before I get nuts and start ordering things. ![]() | |||
| | #67 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC What make the Oaudio a good buy IMO is the built-in parametric equalizer. You'd have to pay another 100 bucks or so to get this functionality by adding another device. Warmon - "know what I mean Vern" | |||
| | #69 (Link) | ||||
| | #70 (Link) | ||||
* The amp really cannot deliver 525w RMS * Unless the port system is really overbuilt compression detunes the box making the port less efficient. I.e. the model is not complete enough to truly predict the behavior with large signals. * They put high pass filters in the signal chain to protect the drivre. | ||||
| | #71 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC I would say we do not know the driver parameters as well. And from the other side, a sub can take a lot of power when it comes to program materials (probably more than what modelling suggest, I prefer to work on RMS values). Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #72 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC So, the db-500 and an Oaudio 500w amp with PEQ in a sealed configuration would be a suitable combination for a music only sub? What is the typical tuning frequency of a music only sub? Is there an optimal box size/frequency specifically for this driver? | |||
| | #73 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC These are the T/S parameters from TC: 12" dB-500 SVC Qts 0.447 Qes 0.481 Qms 6.347 Fs 24Hz Res 3.25Ω Ls 2.36 Lp 3.51 Rp 2.91Ω Dia 241mm Vas 71.5l mms 169g cms 244um/M bl 13.3Tm Spl 86dB | |||
| | #75 (Link) | |||
| Re: Torrent Audio Mistral 12 DVC The bass boost includes sub-sonic filtering. And the PEQ could be used to further tailor response: http://www.oaudio.com/docs/manual.pdf Many suggest a Q of .505 for best transient response. Put these parameters in WinISD pro and adjust the box volume to find the Q you want. Note that you can also stuff a sealed sub to lower Q. This can be modeled in WinISD by adjusting Qa. I have heard a fully stuffed box has Qa ~10. | |||
