Sub 18hz driver control - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
DIY Subwoofers
Discuss Sub 18hz driver control in the DIY Speakers and Subwoofers forum; Sub 18hz driver control I'm using an HPA500 power amp in my dual 10" sub build and i'm concerned with cone excursion below tune ...
Old 03-17-08, 02:05 PM   #1 (Link)
Alias: anthony
User: #16309
Since: Feb 2008
  mayhem13 is offline
I'm using an HPA500 power amp in my dual 10" sub build and i'm concerned with cone excursion below tune of 21hz. Can i wire in some type of passive electronics directly between the driver and the amp. Sort of like a high pass filter set to 20hz. If so, what components would i need to make this or can i buy them already assembled? Thanx in advance.
Old 03-17-08, 04:52 PM   #2 (Link)
Alias: Steve
Loc: Shoreview Minnesota
User: #5693
Since: Jan 2007
  ccdoggy is online now
Re: Sub 18hz driver control
Sure you could, but the component would be expencive to support that amount of power.
when you say uts the HPA500 you really mean the HPSA500 right? I cannot confirm it but i remember seeing somewhere that it has a built in subsonic filter that is not adjustable. I am sure someone else can confirm or deny this.
Also I vote you give it a try and see what happens, if you need the filtering then go forward on that front, if you find that its fine then dont worry about it.
Old 03-17-08, 08:08 PM   #3 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
  eyekode is offline
mayhem13 wrote: View Post
You probably want to filter the low level signal not the high level. Note that a passive filter at 20Hz would be stoopid big and stoopid expensive.
Zl = 2*PI*f*L
If you want a single pole filter with the 3db point to be at 20Hz the inductor would be ~70mH!
Edit: I looked it up and a 20mH inductor is ~35$
I have been considering this product: http://www.edesignaudio.com/product_...roducts_id=657
I have not read any reviews of it yet though...
Old 03-17-08, 11:49 PM   #4 (Link)
Alias: deromax
Loc: Shawinigan-sud, PQ, Canad
User: #13218
Since: Nov 2007
  deromax is offline
eyekode wrote: View Post
Except the OP want a subsonic filter, in other word a high pass filter. That would be a capacitor, not an inductor!
Old 03-18-08, 12:13 AM   #5 (Link)
DRB
Alias: Ray
Loc: Vacationland, Florida
DRB's Avatar
User: #17010
Since: Feb 2008
  DRB is offline
SVS used to market the SVS Subsonic Filter SVS01, made by Marchand Electronics. This device was, IIRC, placed between the sub amp and the sub driver in the signal chain. It allowed multiple subsonic filter settings as well as tweaking phase and such.
How's my memory doing today?
"You can tell by the kindness of a dog how a human should be." Don Van Vliet
You can call me Denton. Or Fido.
Old 03-18-08, 08:43 AM   #6 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
  eyekode is offline
deromax wrote: View Post
Ha! you are right, I was being a moron. But the result is the same. You would need stoopid big passives. Here are some 3rd order filters:
http://www.wa4dsy.net/cgi-bin/lc_fil...&funits=HZ&Z=4
Similar Threads
xbox control question ssphoenix Computers | Games | HTPC | Digital Devices 2 03-14-08 11:35 AM
I want to run my buttkicker to stop @ 18hz pietsch288 DIY Subwoofers 9 01-16-08 02:24 AM
Sub Phase Control Warpdrv DIY Subwoofers 2 11-24-07 12:57 PM
Phase control and Subs. tcarcio Home Audio Subwoofers 10 10-28-07 12:08 PM
Acoustic control in a new control room quintosardo Home Audio Acoustics 0 11-07-06 05:18 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
