| DIY Subwoofers Is this a good DIY sub deal?Discuss Is this a good DIY sub deal? in the DIY Speakers and Subwoofers forum; Is this a good DIY sub deal? I just finished building 4 of Ed Frias' "AR.com" bookshelf speakers. With only 6.5" mids, they need a subwoofer to ... |
| | #1 (Link) | |||
| Is this a good DIY sub deal? I just finished building 4 of Ed Frias' "AR.com" bookshelf speakers. With only 6.5" mids, they need a subwoofer to fill out the bass range. My room is about 14'x18'x8' with a hard floor and walls. I play mostly acoustic music like jazz, newage and classical and some rock. So I have no clue where to start, how much it will cost, what 'level' of quality I need, etc. I'll use this 4.1 system mostly for music and playing my keyboard and computer sounds through, so I'm interested in fidelity over loudness. What do you think? Like, is this a good deal for about $400 incl. shipping? http://www.partsexpress.com/pe/pshow...00-760&scqty=1 Or..... could I buy this driver: http://www.partsexpress.com/pe/showd...number=295-460 and this amp: http://www.partsexpress.com/pe/showd...number=300-804 and build my own cabinet for even less? I have no clue what size cabinet I would need or how to build it. But give me a plan to work from and I'll build it! :-) Thanks! Bryan | |||
| | #2 (Link) | |||
| Re: Is this a good DIY sub deal? Those aren't bad and I do dearly love PE (I run two 12" Titanics myself) but if I were spending $400 right now I'd buy a Tempest-X ($185) or Shiva-X ($165) and a 500W Oaudio amp ($240). DIYcable is having free shipping this weekend too. If you are interested in music only and are sticking with PE I'd use the Reference HF line of subs before I'd use the Titanics. As far as building a sub - I'd say go for it. If this is for music only I'd probably build a sealed sub just to save some space (also easier to make). You'd have to pick a driver before I can give you suggestions on what size to build. | |||
| | #3 (Link) | |||
| Re: Is this a good DIY sub deal? Well, remember that $400 includes the cabinet too, so I'm actually looking for a driver/amp package to be around $250 or less. And I think 10" will do OK for my application - mostly music - no need for LFE or Home Theater use - so 40Hz is probably all I need. I'll build a HT sub at some other time when I upgrade my Onkyo HTIAB setup. So, a sealed cabinet would be good. I'm sure I can find software to tell me the enclosure size I need given the driver's specs. I guess what I'm looking for is plans or a process to follow to build it. Oh and one other "sub" question, 4 ohm vs. 8 ohm... what is the difference besides 8 ohm costing less? Given the same exact speaker in a 4 ohm or 8 ohm version, which is 'better?' Thanks! Last edited by cassb; 03-23-08 at 08:34 PM. | |||
| | #4 (Link) | ||||
| Re: Is this a good DIY sub deal? Quote:
4ohm drivers take higher current. Most sub amps are rated for 4 ohms. If you hook an 8 ohm driver up to it you'll only get about half the listed power. | ||||
| | #5 (Link) | |||
| Re: Is this a good DIY sub deal? I'm frozen in my tracks by all the choices for a DIY sub. All I want is a sealed sub, about a 250w plate amp, and a 10" or 12" driver for music. I will build the enclosure myself from 3/4" MDF from Home Depot if I can find out how to build it. I want to spend around $150 for the driver and around $100 for the amp. What do I do!? Help! ![]() | |||
| | #6 (Link) | |||
| | Re: Is this a good DIY sub deal? This would make a good combination and would fit into your budget. http://www.torrentaudio.com/mistral12dvc-p-73.html http://www.partsexpress.com/pe/showd...number=300-805 The sub would also work in a ported enclosure if you decide to change it in the future. We're all in this together! | |||
| | #7 (Link) | ||||
| | #8 (Link) | ||||
It seems the heavier magnet on the Mistral would make it less sensitive or transient or whatever? I really don't know. If list prices are any indicator, then the Mistral is a better 'deal' at $90 vs. the Dayton at $115. But price means pretty much nothing.Thanks for your help! Bryan | ||||
| | #9 (Link) | |||
| Re: Is this a good DIY sub deal? In regards to your questions concerning building a box of the right size. I'd suggest WinISD as a modeling program. It's freeware for download and definitely use the WinISD Pro version. It's pretty simple to use, particularly for a sealed setup and will show you everything you need to know to decide what size box you want to use. Another program i use in conjunction with WinISD is BoxNotes. This is a simple program that let's you play with box dimensions once you've figured out the total enclosure volume you want and it has the added benefit of creating a cut list for you once you've decided on the dimensions. Hope this is helpful. __________________________ 46" Sony 720p LCD Denon AVR-4306 Snell K5 fronts Snell KIII rears Snell XA55 center Snell PS 10 Sub (TC LMS4000 coming soon!) Oppo 981hd APC H15 power conditioner | |||
| | #10 (Link) | ||||
If you wanted something more multi-purpose then I'd go with the Minstral. | ||||
| | #11 (Link) | ||||
| | #13 (Link) | ||||
Width = 16.5” Height = 25.5” Depth = 10.4” So, I'm good to go. Now I just have to get the parts! | ||||
| | #14 (Link) | ||||
| | #15 (Link) | ||||
| | #16 (Link) | ||||
I'm jumping in to this thread for advice and to wish the OP good luck and post your progress. | ||||
| | #17 (Link) | ||||
| | #19 (Link) | |||
| Re: Is this a good DIY sub deal? You got it, my friend. Edit: Won the SA240 auction on eBay, and bought the RSS315 new at PartsExpress. Should arrive next Tuesday. I'll be getting some MDF this weekend! Last edited by cassb; 03-28-08 at 02:37 PM. | |||
| | #20 (Link) | ||||
I'm glad you started this thread. I'm not a pro at winISD. I was told that the net volume of 53L would yield a Q of .707 and more L's means lower Q, shallower roll-off, and more efficiency. If it's too big, I'll put in more bracing or a diagonal shelf across one or two corners to lower the volume. But I also have more questions than answers. Good luck with your build, evad Last edited by evad; 03-28-08 at 02:49 PM. Reason: spelling | ||||
| | #21 (Link) | |||
| Re: Is this a good DIY sub deal? Also bigger will allow for more cone movement-in some cases with enough power beyond xmax and near or at xmech(read broken) but i doubt you'll hit that at 240 watts. Any reason you didn't get the bass boost. If your f3 is around 37hz, the bass boost i think comes in at 30hz considering parametric across a bandwith this should even out your output down low. | |||
