| DIY Subwoofers Noob DIY Sub advice pleaseDiscuss Noob DIY Sub advice please in the DIY Speakers and Subwoofers forum; Noob DIY Sub advice please Hello,
I would like to build a compact sub woofer am looking to spend around $200. I am going the ... |
| | #1 (Link) | |||
| Noob DIY Sub advice please Hello, I would like to build a compact sub woofer am looking to spend around $200. I am going the DIY route for two reasons.. one I live in India and it's very difficult to get quality speakers here. I am also quite keen to go through the whole building your own speaker process. I am a complete noob and I have no prior experience but I do have access to an excellent carpenter and also my uncle who is fairly proficient (he built a refrigerator in his younger days!) and speaker components so I can go to them for help on this project. However, he is quite old and his knowledge quite dated so he can only help me in putting it together if I have everything i need. I would however need your help and probably a fair amount of hand holding to get me through this and I would appreciate if you can help me out. I will be hooking up this sub woofer to my PC and will use it for music and movies. I have a pair of Swan M200 and this sub-woofer will be an add on. Can you please tell me what components I need and where i can get them? (US online stores are fine as I have my cousin there and I can ask him to pick them up for me). Any guides on putting the components together would also be very helpful. Whew! that was a long post thank you for patience and help ![]() | |||
| | #3 (Link) | |||
| Re: Noob DIY Sub advice please Bascially you need a driver (the cone + motor), an amp (what provides the power) and an enclosure (the box). Given a $200 budget here are some suggestions of componants to look at. Please note I have no idea what shipping to India costs. Drivers Torrent Audio Minstral 12" (basically the old TC-Sounds dB-500) ($89) Mach-5 Audio MAW-12 ($96) Dayton 12" Shielded DVC ($42) Amps Dayton 240 Watt sub amp ($99) Dayton 240 Watt sub amp with bass boost ($99) Personally I'd put the Minstral in a sealed 1.5 cubic foot box with the Dayton amp with bass boost. That would be a decent sub. | |||
| | #4 (Link) | |||
| Re: Noob DIY Sub advice please Thanks for the welcome and really quick response Mike! at the risk of sounding incredibly ignorant and stupid.. I really hadn't thought about the Amplifier.. Can you help me out? is $200 a fair budget for an Amp and a Subwoofer or do you think I need to up my budget? I know this a very subjective question but what you recommend for someone starting out? | |||
| | #8 (Link) | ||||
| Re: Noob DIY Sub advice please Quote:
You will still need the enclosure, mounting screws, a grill (optional), feet, paint, etc. You may want to get a few pounds of polyfill (stuffing) from PE for tuning, although you can probably use some local materials as well. | ||||
| | #13 (Link) | |||
| Re: Noob DIY Sub advice please I am planning on using this design http://www.aespeakers.com/phpbb2/vie...php?f=4&t=1611for the enclosure. What do you guys think? | |||
| | #14 (Link) | |||
| Re: Noob DIY Sub advice please This amplifier might be a good choice for you. It is switchable for 220 volt use. http://www.apexjr.com/VegaARPHU2003.htm Find it at http://www.apexjr.com on sale for $85. Joe L. | |||
| | #15 (Link) | ||||
We're all in this together! | ||||
| | #16 (Link) | ||||
![]() http://www.apexjr.com/Cerwinfullrange.htm Warmon - "know what I mean Vern" | ||||
| | #18 (Link) | ||||
(I'm figuring 50% efficiency of amp, even though it should be 60% to 70% ... if it is rated at 250 watt out, it should be drawing a bit less than 400 to 500 watts at peak) | ||||
| | #19 (Link) | |||
| Re: Noob DIY Sub advice please I spoke to Parts Express the Dayton is rated at only 110 volts. I guess I will just have to use a step down, I have one rated at 1kva so am guessing it should be fine. | |||
| | #20 (Link) | |||
| Re: Noob DIY Sub advice please Quick update guys, my cousin is coming in August and I can finally order my stuff, the Minstral is no longer available and the Mach - MAW-12 is out of stock. Can you recommend a different driver? Thanks! | |||
| | #21 (Link) | |||
| Re: Noob DIY Sub advice please This looks like the same sub as the Mistral: http://www.torrentaudio.com/xo12-p-101.html Another nice/cheap sub is the Dayton RSS315HF: http://www.partsexpress.com/pe/showd...number=295-464 Actually I have heard pretty good things about most of the Dayton subs. And the Titanic is on sale right now... I would reconsider the apexjr amp for 220v. Seems like a better option then a stepdown transformer. | |||
