| DIY Subwoofers In Reference 2 What?Discuss In Reference 2 What? in the DIY Speakers and Subwoofers forum; In Reference 2 What? This is another one of those burning questions that everyone wants to know, right?..
You see a lot of subs ... |
| | #1 (Link) | |||
| In Reference 2 What? This is another one of those burning questions that everyone wants to know, right?.. ![]() You see a lot of subs that have "reference" in their name. What does that really mean? When you see it, does that mean this sub / speak is the manufacturer saying, this is the best sounding thing we make? Can it be measured or is it subjective? How is it detemined?..and does "reference" mean anything across product lines? Warmon - "know what I mean Vern" | |||
| | #2 (Link) | |||
| Re: In Reference 2 What? A couple of explanations; 1. There is a "reference level" (or possibly reference levels depending on what certification) for setting up home theater. It comes out to something like 75 or 85 dB at the listening position (I forget the exact levels, I'm sure someone will fill this is). 2. "Reference level" is a term that gets thrown around a lot (kind of like "extreme") so calling a piece of audio equipment "reference" makes it sound cool. 3. Like #2 it could be implying that it is so good it is what all other subs would use as a reference. | |||
| | #3 (Link) | ||||
| Re: In Reference 2 What? Quote:
In the recording process in the studio the levels are set at this level and not touched again so if the director wants a sound to be loud it will be and if he wants it soft then so it will be if you run your system to low the softer sounds wont be heard at all. Reference level also implies the fact that it will allow for peaks of 105 db's at certain times. Generally As a sub goes, it is usually set about 10db higher than the main speakers. 85db of pink noise is quite uncomfortable to listen to as it is fairly loud and should not be done for long periods of time. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i towers, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 | ||||
| | #5 (Link) | |||
| Re: In Reference 2 What? Reference is a term used by reveiwers describing what they're comparing something to. Calling your gere "reference" is just like saying "this is as good as it gets". Obviously, it's usually not a very accurate claim. Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | |||
| | #6 (Link) | ||||
![]() Our calculations are always correct, for we are gigantic brains. | ||||
| | #8 (Link) | |||
| Re: In Reference 2 What? Yep, I agree with the others that think it's just a cool name to use. The implication is that it's such a great sub that others will measure their offerings by it. Any such "reference" sub may or may not be able to play X dB of pink noise at Y% distortion, etc., etc., but there's no rules to this, so associating the "reference" name with any type of performance would be impossible. Thats pretty much it. -- Otto | |||
| Thread Tools | |
Similar Threads | ||||
| Klipsch Reference Owners??? | Kipp Jones | Home Audio Speakers | 60 | 04-02-08 03:06 PM |
| DIYMA Reference 12, sealed | Sidi_UC | DIY Subwoofers | 3 | 10-18-07 10:30 PM |
| A great cable reference | Anthony | Remotes | Cables | Accessories | 2 | 07-31-07 07:25 AM |
| New Reference White Paint? | benven | Projector Screens | DIY Screens | 3 | 07-29-07 09:32 PM |
| Reference Quality | nova | Movies | TV Shows | Hollywood | 12 | 05-15-07 04:27 PM |
