| DIY Subwoofers Please help me design a PR subwooferDiscuss Please help me design a PR subwoofer in the DIY Speakers and Subwoofers forum; Please help me design a PR subwoofer gluing together
2.25" walls... |
| | #52 (Link) | |||
| Re: Please help me design a PR subwoofer i have a problem. in my zeal to brace the crap out of the box ... i ended up doubling the walls instead of bracing the walls ... now i have a net volume of 3.05 cubic feet instead of the targetted 3.5 cubes. (drivers included assuming .1 and .15 volume displacement of the two drivers) on the weight side of things: enclosure weight is 99lbs. + 59lbs active driver + 12lbs. PR + steel weights 44lbs. | |||
| | #59 (Link) | |||
| Re: Please help me design a PR subwoofer uh oh, there's air leaking out of the PR - from the sides, like the PR isn't flat to the baffle ... will try to fix it later/tomorrow in case you guys have some ideas for: cutout too big? too small? or how to make a flange? please chime in ![]() ![]() | |||
| | #60 (Link) | |||
| Re: Please help me design a PR subwoofer found the problem ... one part of the cone is not attached properly (glue dried up?) what kind of glue do i use? will mighty bond work? (super glue) or is that too hard? http://www.allproducts.com/philippines/rci/p01.html what about shoe glue? http://www2.bostik.com.ph/products/d...px?Mode=0&ID=2 http://www2.bostik.com.ph/products/d...px?Mode=1&ID=2 ![]() ![]() Last edited by mike c; 05-14-08 at 05:42 AM. | |||
| | #61 (Link) | |||
| Re: Please help me design a PR subwoofer I guess it would depend on what the surround is made of. Give Audiopulse a call and see what they suggest. My guess would be a weatherstripping adhesive used to attach plastic and rubber mouldings to car panels-3M makes one in black. | |||
| | #63 (Link) | |||
| Re: Please help me design a PR subwoofer mike, this jeff, i bought the other tc passive, hey my passive is having the same problems. nearly 40 to 50% of that surrond it lose. let me know what glue you are going to use. after i saw your post i went and checked mine and sure enough, the surround is flapping in the wind. WOW | |||
| | #66 (Link) | |||
| Re: Please help me design a PR subwoofer Nice vids. By the way it doesn't look like that is anything with very low frequency content being played as the PR is barely moving. Wait until you really get that PR moving around tuning. You are going to have some serious vibration going on! Those weights will fly off the top of that cab. | |||
| | #67 (Link) | |||
| Re: Please help me design a PR subwoofer yeah, that's why i removed some of the weights off the PR ... to tune higher and give it a little bit more work. im thinking the 3.5 cube net volume is already pretty big and perhaps the 13av isnt compressing on that volume enough to make the heavy PR move. and then there's the way more massive cone area on the PR ... kinda like having dual 6" ports on a 13" driver ![]() ill check what the f3 is in room, and decide if i can tune it even higher ![]() but first i need to get two more guys to move it to the desired location ![]() | |||
| | #70 (Link) | |||
| Re: Please help me design a PR subwoofer The Pr won't be doing much of anything above 22 hz, about half the excursion of the main drive unit which your video shows. Things will really start moving around 17.5 hz. Above that, it's just allowing greater extension of the drive unit. Decreasing box volume will effectively raise the F3. If you can give this baby some really low freq's, you will get to appreciate the advantages of what you've built. | |||
| | #71 (Link) | ||||
| Re: Please help me design a PR subwoofer Quote:
ill try some test tones soon ![]() | ||||
| | #72 (Link) | |||
| Re: Please help me design a PR subwoofer I mean what frequency is being sent to the woofer. The passive does virtually nothing above tuning. If you are sending a nice 30 hz signal to the woofer, the passive is just hanging around saying, "I'm ready". Try sending test tones at and below tuning- It will move. The passive is not just being moved by the back pressure of the woofer, but being driven with frequencies at or below tuning. The driver will move very little at the tuning. Try different frequencies and notice cone movement of each component and when the driver moves least and passive really wails, that is the tuning frequency. Robert Last edited by robertcharles123; 05-19-08 at 01:37 AM. | |||
| | #73 (Link) | |||
| Re: Please help me design a PR subwoofer i tried black hawk down (famous for sub 10hz frequencies) but im thinking the SMS-1 bypass mode still filters the low end ... i actually forgot to try with no SMS-1 in the chain (or at least moving the subsonic filter to 10hz) ill find out if the SMS-1 affects the low end when i burn the test tones to disc. | |||
| | #74 (Link) | |||
| Re: Please help me design a PR subwoofer I really like UniBox for modeling a PR subwoofer's performance. It makes it easy to see just what the contribution by the PR to the sound output is. This is what my DIY sub project showed in UniBox: pr_response.JPG With a 15 Hz tuning point the driver and the PR's contributed equally at 21 Hz, but the driver was 10 dB higher in output than the PR's at ~30 Hz. | |||
