Air tight joints in Birch plywood? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Air tight joints in Birch plywood? in the DIY Speakers and Subwoofers forum; Air tight joints in Birch plywood? I have built speakers out of MDF before and used butt joints. If the edges are nice and straight the ...
Old 04-02-08, 02:18 PM   #1 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
eyekode is offline
I have built speakers out of MDF before and used butt joints. If the edges are nice and straight the joints seem pretty air tight and strong (using just glue).
Can/should I use simple butt joints with Birch plywood? I don't plan on using any fasteners.
Another alternative I have is mitered joints with biscuits.
What is the recommended joint?
Old 04-02-08, 03:13 PM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: Air tight joints in Birch plywood?
Butt joints are easier. Mitered joints look nicer. I'd only use mitered joints if the finish required it.
We're all in this together!
Old 04-02-08, 04:37 PM   #3 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
eyekode is offline
Mike P. wrote: View Post
So butt joints in plywood will seal well enough? I am concerned that the multiple plies will be leaky compared to MDF... I am also concerned that they will not be structurally sound (note that I prefer to not use screws, just glue which has worked fine for me with MDF).
Thanks!
Old 04-02-08, 04:42 PM   #4 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
avaserfi is online now
With proper application of glue the seals will be air tight and structurally sound, but use of a biscuit joint as you previously mentioned would further increase strength. Is there a specific reason you are against use of screws? They will not harm the build in anyway and allow for an expedited process. Lastly, it should be noted that quality ply is actually lighter and more dense than traditional MDF.
-Andrew
Old 04-02-08, 05:00 PM   #5 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
How you built with MDF you can do with plywood. As long as the clamping time is long enough for the glue to dry, there won't be a problem.
Old 04-02-08, 05:21 PM   #6 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
avaserfi wrote: View Post
Lighter and denser?
Old 04-02-08, 05:52 PM   #7 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
eyekode is offline
No screws because I want to leave the option of doing a stained finish. The edge of birch plywood can look interesting.
Thanks for the info!
Old 04-02-08, 06:58 PM   #8 (Link)
Alias: Mike
Loc: Chattanooga, TN
User: #5740
Since: Jan 2007
mgboy is offline
Geoff St. Germain wrote: View Post
Lighter and denser?
I must have missed something in physics class.
Old 04-02-08, 07:07 PM   #9 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
Lighter and denser?
Sorry, lighter and more stiff. Apologies.
-Andrew
Old 04-02-08, 11:37 PM   #10 (Link)
Alias: Sam
Loc: Adelaide
User: #11091
Since: Aug 2007
a1161979 is offline
eyekode wrote: View Post
A butt join will be fine, just make sure you clamp them tight as they dry and if you want to run a bead of sealant along the interior joins. Providing you cuts are good (square) and it clamped well as it drys you wont have a problem with air leaking or strength
Old 04-05-08, 06:22 PM   #11 (Link)
Alias: Paul
Loc: SW Ranches, Fl
User: #3355
Since: Oct 2006
aceinc is offline
I concur regarding using caulking, but then again for speakers I'm a belts & suspender kind o' guy. If you really want to go wild & crazy slosh some latex paint around the inside, and let 'er dry.
Paul
Old 04-06-08, 04:38 PM   #12 (Link)
Alias: OJ
Loc: Toronto, Ontario
Owen Bartley's Avatar
User: #3144
Since: Oct 2006
Owen Bartley is offline
Yep, good square cuts, butt joints, glue, and lots of clamps. That should sort you out nicely with either MDF or plywood. And then as has been mentioned, it never hurts to run a bead of caulk or clue around the inside of all your corners, just to make 100% sure you're airtight.
Old 04-27-08, 12:14 AM   #13 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
mdrake is online now
I always use liquid nails around all seems on the inside of my boxes.Just be sure the liquid nails is dry before making a spark.
Matt
Old 04-27-08, 02:24 AM   #14 (Link)
Alias: Sparky
Loc: North Dakota
User: #17212
Since: Feb 2008
sparky77 is offline
Regardless of the caulking you you to seal the enlosure, its a good idea not to instal the speakers for at least 48 hours as the vapors have been known to cause the adhesives in the speakers to let loose.
Old 04-27-08, 01:32 PM   #15 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
eyekode is offline
mdrake wrote: View Post
Matt
I took this advice. Not sure I needed it, my edges were really clean this time (used a router to make sure they were all square). I used biscuits and wood glue. I also used a bead of liquid nails on the inside edge of each joint. I am pretty sure the seams are going to be the least of my air-leakage problems (cut a little too big of a cut-out for the driver ).
Similar Threads
Sanyo Z2 Air Filter Bob in St. Louis Home Theater Projectors 7 08-21-07 10:43 AM
port air speed Hakka DIY Subwoofers 11 05-27-07 01:34 PM
Free to Air Satellite Receiver salvasol Home Theater Components 9 04-02-07 07:21 AM
Software to divide Plywood/MDF Lammy DIY Speakers 3 03-03-07 09:20 PM
Weight of Air? alan monro Home Audio Speakers 2 05-29-06 09:10 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117
