Possible New LLT project - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Possible New LLT project in the DIY Speakers and Subwoofers forum; Possible New LLT project a1161979 wrote: Do you have any enclosure plans for the new default LLT driver yet steve If you want to ...
Old 04-09-08, 05:58 PM   #26 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
Re: Possible New LLT project
a1161979 wrote: View Post
If you want to get one, better hurry - pre order sale ends tomorrow...
Warmon - "know what I mean Vern"
Old 04-11-08, 07:20 PM   #27 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is online now
Sorry, I've been very busy this week. The Maelstrom X works well in anything from 400-700 liters. Tell me what size you want to go and I'll tell you what port length and tuning looks best for that volume.
Regarding the FiCar IB18, how can a driver designed for IB (a giant closed box) perform well in a vented system?
The characteristics needed for a good IB and LLT driver are similar - high Vas, lowish Bl, low Fs, lots of displacement.
Old 04-11-08, 11:50 PM   #28 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
mdrake is offline
Why a low Bl, I thought Bl, helped stop and start the woofer "magnet strength"? I always always under the impression that a higher Bl was better because it help give the woofer better transient response,especially when using a larger cone. Am I missing something?
Matt
Old 04-12-08, 11:22 AM   #29 (Link)
Alias: Steve
User: #263
You need a loose suspension in order to achieve the ideal FR rolloff that mates well with a <15hz tune. A tight suspension, even in an infinitely large enclosure, will result in a very peaky range around tuning. Also, since a LLT or IB offers little no no resistance to cone movement, the magnet strength becomes less important. High Bl is much more important in small sealed subs, as that magnet strength is needed to compress the air inside the enclosure.
Old 05-14-08, 11:34 PM   #30 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
mdrake is offline
I just now saw that reply. THANKS that was a VERY helpful explanation!!!!!! To many years in car audio.
Matt
Old Yesterday, 10:51 PM   #31 (Link)
New Member
Alias: kstich
Loc: BC
User: #23456
Since: Jul 2008
kstich is offline
Hi Steve,
Sorry for re-opening this discussion, but I just got a Maelstrom_X and wanted to run the LLT alignment by you. I have read your LLT Explained thread. Thanks and great job!
Here is what I have modeled so far:
Volume: 424.8 L
Tune: 16 Hz
Port Dia: 8"
Port Length: 29.27" (one end flanged)
This appears to give relatively flat response to below 20 Hz without being too large. When I put the volume and tuning into the sonosub.exe program, the port length calculated is very close 29.75".
I modeled another larger ESB3 alignment and came up with 679.6 L tuned to 12 Hz, but that is awfuly large, and the -3 dB point is higher. I am leaning towards the 424.8L sonosub. What are your thoughts on these designs? Thanks in advance...
Old Yesterday, 11:25 PM   #32 (Link)
Alias: Steve
User: #263
Looks really good - I would increase port length to 36" though to knock the tune down a bit lower. Remember there will be room gain, so you don't want an anechoic response that stays naturally flat all the way down to tuning when tuning is below ~25hz
Similar Threads
My 15" TC2000 LLT End Table Project tundraSQ DIY Subwoofers - Sealed and Ported 56 05-04-08 06:21 AM
Another 18" LLT mlstrass SoundSplinter 9 04-27-08 12:07 PM
TC 2K LLT NateTTU DIY Subwoofers - Sealed and Ported 16 12-26-07 11:39 PM
IB and LLT in one g75 DIY Subwoofers 10 08-30-07 04:17 PM
Dual RL-p15 D2 LLT Sub Project... Sonnie SoundSplinter 172 06-06-07 02:52 AM
Mach 5 Audio
