IB vs Sealed... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
IB vs Sealed...
Discuss IB vs Sealed... in the DIY Speakers and Subwoofers forum; IB vs Sealed... At what point does a large sealed enclosure become equivalent to an infinite baffle? Can I use a sealed and ...
Old 04-05-08, 05:10 PM   #1 (Link)
Alias: Paul
Loc: SW Ranches, Fl
User: #3355
Since: Oct 2006
aceinc is offline
IB vs Sealed...
Can I use a sealed and sound proofed closet? What size?
I suspect the answer depends on the capabilities & quantities of drivers, but I was hoping for some rule of thumb.
Paul
Old 04-05-08, 06:08 PM   #2 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
Re: IB vs Sealed...
The rule of thumb I've seen is between 10 and 100 times the Vas value of the driver (or sum of the drivers). You could use a closet, depending on the size of the closet and the Vas of the chosen driver(s).
Old 04-05-08, 06:16 PM   #3 (Link)
Alias: Bob_99
Loc: New Hampshire
Bob_99's Avatar
User: #460
Bob_99 is online now
Re: IB vs Sealed...
I believe that over on the Cult forum they specify 4 to 10 the total Vas value (all the drivers). I've not seen the 100 times recomendation before but then again I'm still low on the learning curve when it comes to DIY subs.
Bob
"There is always hope, even if it is just a fool's hope."
Old 04-05-08, 06:26 PM   #4 (Link)
Alias: Geoff
User: #4919
Since: Dec 2006
Re: IB vs Sealed...
There was a discussion on AVS recently (more of an argument) with some of the guys from the cult on it. They were saying 10 times, 25 times and even 100 times. From modeling the difference between 10 time and 100 times doesn't appear very noticeable.
Old 04-05-08, 10:50 PM   #5 (Link)
Alias: Sam
Loc: Adelaide
User: #11091
Since: Aug 2007
a1161979 is offline
Re: IB vs Sealed...
Geoff St. Germain wrote: View Post
I have read on the cult to model an IB in 10,000L not sure if this helps Surely in application the difference between 25X and 50X and so on wouldnt be boticeable after EQ or maybe even before, in fact all i can see if affecting is power handling
Old 04-05-08, 11:20 PM   #6 (Link)
Alias: Brian
Loc: Oklahoma City
User: #5872
Since: Jan 2007
bonehead848 is offline
Re: IB vs Sealed...
Bob
That is what I also heard. 4 is given as the absolute minimum value.
Old 04-06-08, 11:53 AM   #7 (Link)
Alias: Paul
Loc: SW Ranches, Fl
User: #3355
Since: Oct 2006
aceinc is offline
Re: IB vs Sealed...
So a driver with a .95 cu ft vas would want a sealed box that's about 26" on a side, if it were a cube. Basically about 10 cubic feet.
The driver that has that vas is the titanic 10". The question then becomes how would that driver in an IB compare to other configurations such as ported, or LLT, etc.?
This is more of an intellectual exercise, as I will not be building another sub for a while. But I have a pair of the titanic 10" drivers, that may be part of that endeavour.
Paul
Old 04-06-08, 12:47 PM   #8 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
Re: IB vs Sealed...
An IB is just a large sealed sub, and therefore porting still has many advantages over it - namely better FR linearity into lower frequencies, lower distortion, and greater headroom.
Old 04-06-08, 11:57 PM   #9 (Link)
Alias: Sam
Loc: Adelaide
User: #11091
Since: Aug 2007
a1161979 is offline
Re: IB vs Sealed...
SteveCallas wrote: View Post
As well as disadvantages such as larger box size's, lower power handling and higher group delay
Old 04-11-08, 07:15 PM   #10 (Link)
Alias: Steve
User: #263
Re: IB vs Sealed...
A LLT will have much better power handling than an IB, and it will achieve greater output levels with the same amount of power vs an IB. Increases in group delay below 20hz that remain less than one cycle are inconsequential.
Old 04-11-08, 09:11 PM   #11 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
Re: IB vs Sealed...
aceinc wrote: View Post
Sounds like an interesting experiment. Keep us posted...
Warmon - "know what I mean Vern"
Old 04-12-08, 11:30 PM   #12 (Link)
Alias: Sam
Loc: Adelaide
User: #11091
Since: Aug 2007
a1161979 is offline
Re: IB vs Sealed...
What about port resonance steve
Old 04-13-08, 10:51 AM   #13 (Link)
Alias: Steve
User: #263
Re: IB vs Sealed...
What about it? With a typical 4th order 80hz crossover, the signal to the sub is reduced enough at the recommended minimally safe first resonance frequencies that it becomes inconsequential.
Old 05-11-08, 11:16 PM   #14 (Link)
Alias: jagman
Loc: Sacramento, CA
User: #1455
jagman is offline
Re: IB vs Sealed...
A properly placed IB may or may not need more EQ than an LLT. An LLT has extra output in the low end, but has group delay. Saying the effect below 20Hz is minimal doesn't mean much to me since the sub is crossed over at 80Hz. Most people who've heard IBs seem to think the sound is very clean and that things just sound real. Most who've heard LLTs seem to think the sound is more powerful. The issue with IBs is you need more driver displacement to reach equal SPL when compared to LLTs, but you need less power. This means IBs tend to be more expensive (potentially a lot more expensive). The biggest practical concerns with IBs are where to put them (difficult to test) and actually mounting the drivers in your wall/floor/ceiling. With LLT's, the biggest practical concern is locating the beastly enclosures in your room. Like most things in life, both options are good when done right, it just depends what type of sound you personally favor and what works for your room (or what your SO will allow ).
Old 06-05-08, 08:57 PM   #15 (Link)
Alias: Penngray
Loc: FL
User: #6840
penngray is offline
Re: IB vs Sealed...
I have twin TC2K 15" ported subs (11 cf, 8" port, just finished recently) and I have an IB array (4 Q18s).
It takes less power to power my IB to High SPL levels then it does to power my LLTs.
My LLTs are tuned to 16 Hz, my IB can hit under 10 Hz easily.
My LLT build took a lot more wood (almost $200), lot more teadious effort, rounding sanding and so on, about 5x the amount of time.....IB array, $50, 4 routed holes, extra bracing in the attic best Sub system I own.
BTW, This thread asked about Sealed vs IB but Steve always has to chime in with his LLT stuff...its like he needs to convince himself daily that his design are better....blah...No one wants HUGE SILOs!!! They are so 80s!
Old 06-08-08, 06:16 AM   #16 (Link)
Alias: Eccentric
Loc: Gold Coast, Qld,Australia
User: #10564
Since: Jul 2007
Jason Schultz is offline
Re: IB vs Sealed...
Penngray said
penngray wrote: View Post
I'm sure it does take less power to make 4 18 inch subs produce a givern spl when compared to 2x 15's.
Old 06-08-08, 05:49 PM   #17 (Link)
Alias: Steve
User: #263
Re: IB vs Sealed...
Back off pal, in the post before mine it was asked:
I answered his question.
Old 06-08-08, 06:20 PM   #18 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is online now
Re: IB vs Sealed...
Guys.... Let's keep this thread clean pls
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Similar Threads
Going LLT from sealed fireanimal DIY Subwoofers - Sealed and Ported 37 04-20-08 06:02 PM
3-Way Sealed ktaillon DIY Speakers 4 03-19-08 11:30 AM
2 'Splinters sealed Prozakk SoundSplinter 25 12-21-07 12:44 PM
SEALED Subwoofer Q? Ricci DIY Subwoofers - Sealed and Ported 9 12-07-07 12:11 PM
rls15 sealed fumoffu SoundSplinter 26 11-27-07 09:06 PM
Mach 5 Audio
