Unibox - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Unibox
Discuss Unibox in the DIY Speakers and Subwoofers forum; Unibox Does anyone know how Unibox determines F3? Is it based off a the SPL at a single point, and can ...
Old 04-14-08, 12:19 PM   #1 (Link)
Alias: HJ
Loc: Algonquin, IL
User: #18151
Since: Mar 2008
hjmiller is offline
Unibox
Does anyone know how Unibox determines F3? Is it based off a the SPL at a single point, and can that reference be changed based upon how you plan to use a cross-over?
Old 04-14-08, 01:06 PM   #2 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
Re: Unibox
hjmiller wrote: View Post
I think it is based off the peak SPL (whatever that might be) excluding things like port resonance. If you want to play with x-over stuff I suggest you get another FRD Consortium product the Passive Crossover Designer (PCD). It can import .FRD and .ZDA files from Unibox and do crossover things with them.
Similar Threads
Question about UNIBOX nuno DIY Speakers 1 01-20-08 08:36 AM
UniBox Sonnie DIY Subwoofers 3 09-13-07 04:45 PM
Mach 5 Audio
