| DIY Subwoofers Sub design application question....Discuss Sub design application question.... in the DIY Speakers and Subwoofers forum; Sub design application question.... I've been looking into the shiva-x driver at the diycable.com website and I'm a little confused at the proposed size ... |
| | #1 (Link) | |||
| I've been looking into the shiva-x driver at the diycable.com website and I'm a little confused at the proposed size enclosures that they recommend with a 17" port. With their proposed enclosures the air velocities which they indicate are much lower than what Winisd calculates. What application are they using? Last edited by tdamocles; 04-20-08 at 09:25 AM. | |||
| | #3 (Link) | |||
| Re: Sub design application question.... they are only change the box volume and lot off poly-fill But if you whant to go so try a box of 4,414 cu ft 4,331x 25,66 in for the vent and the velocity off the vent is around 30 and normal off poly-fill | |||
| | #5 (Link) | |||
| Okay...I didn't see the 250watts. This is an ongoing effort trying to learn sub building. I see that one can change the high pass filter parameters. How does order, and q affect the outcome? | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Green Glue Application | Anthony | Home Audio Acoustics | 8 | 04-29-08 01:29 PM |
| question about sub box design | h0bo4life | DIY Subwoofers | 7 | 03-23-08 08:44 PM |
| Live Application | stevestudio | REW Forum | 6 | 01-25-07 09:24 AM |
| HT speaker design question | BoomieMCT | DIY Speakers | 4 | 01-24-07 12:00 PM |
