SDX-15 Baffle Screws - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss SDX-15 Baffle Screws in the DIY Speakers and Subwoofers forum; SDX-15 Baffle Screws The hole at the front of the SDX-15 will accomodate a 1/4"-20 screw. Unfortunately the edge of the surround or ...
Old 06-18-08, 02:30 PM   #1 (Link)
Alias: Polhub
User: #20672
Since: May 2008
polhub is offline
The hole at the front of the SDX-15 will accomodate a 1/4"-20 screw. Unfortunately the edge of the surround or a gasket is preventing the screw from going all the way thru the baffle. I tried putting some pressure on the screw but it would not go.
The speaker is pretty heavy and 10-32 screws seem pretty small. Should I push harder or drill the gasket out?
Old 06-18-08, 02:54 PM   #2 (Link)
Alias: Kevin
Loc: Dublin, OH
User: #8492
Since: Apr 2007
Kevin_Wadsworth is offline
Re: SDX-15 Baffle Screws
I used #10 screws without a problem to hold by SDX-15 drivers. They've been in for a couple months now.
Old 06-19-08, 11:54 AM   #3 (Link)
Alias: Looney
Loc: Topeka, KS
User: #2678
Since: Sep 2006
looneybomber is offline
polhub wrote: View Post
Without getting out a drill, the 1/4" screws will not fit.
Similar Threads
(1)SDX 15" SEALED OR (2)ED 13k in 4ft3?? tys DIY Subwoofers - Sealed and Ported 9 06-27-08 11:48 AM
SDX-15 Father's Day Sale Mike P. DIY Subwoofers 1 06-25-08 06:10 PM
Sonosub SDX-15 sil180sr Classifieds - Speakers and Subwoofers 1 06-07-08 07:52 PM
2x CSS SDX-15 => which amp? daxie DIY Subwoofers 16 06-06-08 03:44 PM
SDX-15 vs. RL-P18 Bradley DIY Subwoofers 33 11-24-07 04:17 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
