| DIY Subwoofers Correct speaker phase in push pull subwooferDiscuss Correct speaker phase in push pull subwoofer in the DIY Speakers and Subwoofers forum; Correct speaker phase in push pull subwoofer I recently built a push pull T-line sub woofer following someone else's design. Both our designs have both 4 ohm ... |
| I recently built a push pull T-line sub woofer following someone else's design. Both our designs have both 4 ohm drivers facing the same direction (one mounted outside the enclosure and the other facing the same direction but mounted inside the enclosure (in a I< I< fashion). The originator of the design states that these two drivers should be wired out of phase. It seems to me that they should be wired in phase. which is correct? If the speakers were instead mounted in a I< >I fashion or a I> I<, it would seem that they should then be wired out of phase with each other. Would appreciate advice and an explanation. Bengui | ||||
| | #2 | ||||
| Re: Correct speaker phase in push pull subwoofer The cones must move in the same direction, so you would wire them reverse polarity if facing each other or facing away from each other, which is the usual way an isobaric is done. Since you opted to have both cones facing the same direction they would be wired normally. | ||||
| | #4 | ||||
| Re: Correct speaker phase in push pull subwoofer I'm going on the assumption that the design is isobaric. The usual isobaric has the drivers face to face, separated by only a spacer between their frames, and in that case reverse polarity is a necessity. I could make a better judgement by seeing the design. | ||||
| | #5 | ||||
| Re: Correct speaker phase in push pull subwoofer Hi Bill, Unlike the typical isobaric type, my design has both driver cones facing the same direction, . When a positive charge is applied to the positive driver terminals, both cones move forward in unison. Bengui | ||||
| | #6 | ||||
| Re: Correct speaker phase in push pull subwoofer So, what exactly are the advantages to a push-pull system? Do you have to double the volume of the enclosure, like you would if you just had two drivers on the same face? | ||||
| | #7 | ||||
| Re: Correct speaker phase in push pull subwoofer IMO, for an isobaric, none. The cab volume is halved, but the sensitivity and output is that of only one driver. Back when 3mm was a long xmax and Vas values of 25 cu ft were common isobarics had some value, but modern drivers rendered them obsolete. There is another version of 'push pull', a standard reflex with two drivers facing opposite directions, which is supposed to result in cancelled harmonic distortion. I've never seen corroborating measurements of it though. | ||||
| | #8 | ||||
| Re: Correct speaker phase in push pull subwoofer I wasn't referring to either of the alignments you mentioned. Look at this: ![]() That's what I was referring to, and I do believe the OP was referring to having drivers on either end of the box, facing the direction. ![]() Opposed configurations (drivers facing opposite on either ends/sides of the enclosure) due provide resonance control, but I'm not sure if there's any sort of distortion reducing effects - I'd imagine there might be. Last edited by mgboy; 06-25-08 at 07:02 PM.. Reason: Excuse my poor drawings. | ||||
| | #9 | |||||
| Re: Correct speaker phase in push pull subwoofer Quote:
| | #11 | ||||
| Re: Correct speaker phase in push pull subwoofer That's why I asked to see details, as push-pull could mean either. | ||||
| | #12 | ||||
| Re: Correct speaker phase in push pull subwoofer Hello again, The original sub design that I used can be found on the following: http://www.teresaudio.com/haven/subs/subs.html Cheers, Bengui | ||||
| | #13 | |||||
| | #14 | ||||
| Re: Correct speaker phase in push pull subwoofer Yes. The would be wired reverse polarity as shown, but if both drivers are outward facing per the OPs version they'd be wired normally. They would be moving in opposite directions, but only because they're on opposite sides of the box. Both are moving either inward or outward simultaneously. BTW, that's not an isobaric alignment. | ||||
